I’m encountering a confusing error. I initially built an inaccurate model, so I replaced the original grid, ini file, obc file, and tide file. However, I encountered the following error right at the first step of running the model:
Note: The following floating-point exceptions are signalling: IEEE_INVALID_FLAG, IEEE_DIVIDE_BY_ZERO
To address this issue, I have tried the following:
Checked each input file carefully and found no NaN values
Reduced DT to 50/10
Increased NDTFAST to 40
Set all boundaries to clo
Removed the tide and station sections from the .h file and recompiled
Unfortunately, none of these attempts resolved the problem.
I’m attaching my run log, .in file, and .h file below. I would really appreciate any suggestions you might have.
Apologies if my English is not very good, and I hope I haven’t caused any offense.
