The tide level of my model does not match TPXO9
tao
#1 Unread post by tao »
I used the data from TPXO9 to generate a tidal forcing file. I defined the following cpp option and ran it for 90 days. There is a big deviation between the tidal level change of the site and the forecast data of TPXO9. Could someone please help me find out what the problem is? Appreciate any suggestions。
** Options for Tidal test case.
** Application flag: test_case
** Input script: test_case.in
#define ANA_FSOBC
#define ANA_INITIAL
#define ANA_M2OBC
#define ANA_M3OBC
#define ANA_SMFLUX
#define ANA_SSFLUX
#define ANA_STFLUX
#define ANA_TOBC
#define ASSUMED_SHAPE
#define BOUNDARY_ALLGATHER
#define COLLECT_ALL
#define CHARNOK
#define CRAIG_BANNER
#define DOUBLE_PRECISION
#define GLS_MIXING
#define LIMIT_BSTRESS
#define KANTHA_CLAYSON
#define MIX_GEO_TS
#define MPI
#define NONLINEAR
#define N2S2_HORAVG
#define PERFECT_RESTART
#define POWER_LAW
#define PROFILE
#define K_GSCHEME
#define RADIATION_2D
#define REDUCE_ALLREDUCE
#define RI_SPLINES
#define RST_SINGLE
#define SPLINES_VDIFF
#define SPLINES_VVISC
#define SSH_TIDES
#define STATIONS
#define UV_U3HADVECTION
#define UV_C4VADVECTION
#define UV_TIDES
#define VAR_RHO_2D
#define VISC_GRID
#define WET_DRY
smchen
Re: The tide level of my model does not match TPXO9
#2 Unread post by smchen »
My tide-related CPPs are
#define SSH_TIDES
#define UV_TIDES
#define ADD_FSOBC
#define ADD_M2OBC
You can try adding ADD_FSOBC and ADD_M2OBC.
