I have recently donwloaded the trunk and installed Roms (Revision 1188) on a new system where all dependencies are compiled via Intel oneAPI DPC++/C++ Compiler version 2023.2.0 .
I would like first to run the upwelling test case in serial. I am able to compile Roms without problems (see summary below) obtaining the executable romsS file
GNU Build script command: build_roms.sh -j 4
ROMS source directory: /home/marcello/RomsAug23
ROMS build directory: /home/marcello/RomsAug23/Projects/test_upwelling/expSer_Aug23/Build_roms
ROMS Application: UPWELLING
Fortran compiler: ifort
Fortran flags: -fp-model precise -heap-arrays -ip -O3 -traceback -check uninit
Model Input Parameters: ROMS/TOMS version 4.2
Tuesday - August 8, 2023 - 3:04:00 PM
forrtl: severe (153): allocatable array or pointer is not allocated
Image PC Routine Line Source
romsS 0000000000804626 get_metadata_mod_ 977 get_metadata.f90
romsS 00000000006D4CFA mod_ncparam_mp_in 1165 mod_ncparam.f90
romsS 000000000060B49A read_phypar_ 240 read_phypar.f90
romsS 00000000005F3C69 inp_par_mod_mp_in 85 inp_par.f90
romsS 000000000040FD0F roms_kernel_mod_m 86 roms_kernel.f90
romsS 000000000040F81B MAIN__ 75 master.f90
romsS 000000000040F60D Unknown Unknown Unknown
libc.so.6 00007F887CE29D90 Unknown Unknown Unknown
libc.so.6 00007F887CE29E40 __libc_start_main Unknown Unknown
romsS 000000000040F525 Unknown Unknown Unknown
I am very likely doing something stupid and will appreciate any help.
Thanks in advance,
marcello
