ERROR while compiling executable
Sobhan_yousefi1994
#1 Unread post by Sobhan_yousefi1994 »
Hello there...
I am new to ROMS and when I was compiling roms via code bellow:
$ ./build_roms.sh -j 2
after a while, Finally. I've received the error bellow:
stats.f90:177:35:
  177 |       CALL get_hash (Cwrk, Npts, S.checksum)
      |                                   1
Error: Syntax error in argument list at (1)
cd /home/ubuntu/roms_project/sobhan/Build_romsG; /usr/bin/gfortran -c -frepack-arrays -fallow-argument-mismatch        -g -O0 -fbounds-check -fbacktrace -fcheck=all -finit-real=nan -ffpe-trap=invalid,zero,overflow frc_adjust.f90
stats.f90:377:35:
  377 |       CALL get_hash (Cwrk, Npts, S.checksum)
      |                                   1
cd /home/ubuntu/roms_project/sobhan/Build_romsG; /usr/bin/gfortran -c -frepack-arrays -fallow-argument-mismatch        -g -O0 -fbounds-check -fbacktrace -fcheck=all -finit-real=nan -ffpe-trap=invalid,zero,overflow def_dim.f90
stats.f90:586:35:
  586 |       CALL get_hash (Cwrk, Npts, S.checksum)
      |                                   1
make: *** [ROMS/Utility/Module.mk:14: /home/ubuntu/roms_project/sobhan/Build_romsG/stats.o] Error 1
GNU Build script command:      build_roms.sh -j 2
ROMS source directory:         /home/ubuntu/roms/trunk
ROMS build  directory:         /home/ubuntu/roms_project/sobhan/Build_romsG
ROMS Application:              UPWELLING
Fortran compiler:              gfortran
Fortran flags:                 -frepack-arrays -fallow-argument-mismatch -g -O0 -fbounds-check -fbacktrace -fcheck=all -finit-real=nan -ffpe-trap=invalid,zero,overflow
what is the reason of these errors?
robertson
Re: ERROR while compiling executable
#2 Unread post by robertson »
Yes, this is indeed a syntax error caused by a typo: S.checksum should be S%checksum.
Thank you for reporting this error. The correction has been made, please update your code.
Sobhan_yousefi1994
#3 Unread post by Sobhan_yousefi1994 »
thank you Mr. Robertson. It worked.
