cannot work parallel nodes
kobl1201
#1 Unread post by kobl1201 »
Hi
when i work out ROMS model, I try to use 2 cpu, but the cpu continues to work with 1.
When i set paralle node =1, the model work out well.
which option can I check??
It is my run.sh file
#!/bin/bash
#PBS -V
#PBS -q batch
#PBS -l nodes=2:ppn=1
#PBS -N ROMS
ulimit -s unlimited
ulimit -c unlimited
cd $PBS_O_WORKDIR
cp -f $PBS_NODEFILE .
echo $PBS_NODEFILE > ./test.prt
echo "job started"
date
NP=`/usr/bin/wc -l $PBS_NODEFILE | awk '{ print $1 }'`
echo "$NP" >> test.prt
mpirun -np 2 -machinefile $PBS_NODEFILE ./romsM ocean_ub_3k_new.in >> test.prt
date
echo "job finished"
Model Input Parameters: ROMS/TOMS version 4.2
Sunday - August 6, 2023 - 5:40:38 PM
Sunday - August 6, 2023 - 5:40:39 PM
Ulleung Basin 1 km-ETOPO5
Operating system : Linux
CPU/hardware : x86_64
Compiler system : ifort
Compiler command : /usr/local/mpi/intel18/mvapich2-2.2/bin/mpif90
Compiler flags : -O3
OCN Communicator : 1140850688, PET size = 1
Input Script : ocean_ub_3k_new.in
SVN Revision : 1177
Local Root : /ghome/kobl1201/ROMS/trunk
Header Dir : /ghome/kobl1201/ROMS/trunk/Projects
Header file : ulleungbasin.h
Analytical Dir : /ghome/kobl1201/ROMS/trunk/Projects
Resolution, Grid 01: 240x225x31, Parallel Nodes: 1, Tiling: 1x2
ROMS/TOMS: Wrong choice of grid 01 partition or number of parallel nodes.
NtileI * NtileJ = 2
must be equal to the number of parallel processes = 1
Change -np value to mpirun or
change domain partition in input script.
Found Error: 06 Line: 210 Source: ROMS/Utility/inp_par.F
Found Error: 06 Line: 125 Source: ROMS/Drivers/nl_roms.h, ROMS_initialize
SVN Revision : 1177
NtileI * NtileJ = 2
Primary job terminated normally, but 1 process returned
a non-zero exit code.. Per user-direction, the job has been aborted.
mpirun detected that one or more processes exited with non-zero status, thus causing
the job to be terminated. The first process to do so was:
Process name: [[56596,1],0]
Exit code: 128
Re: cannot work parallel nodes
NtileI * NtileJ = 2
if you set to run with -np X, where X is an integer, then you need to change ocean.in values of NtileI and NtileJ so that
NtileI * NtileJ = X
an example is
-np 2
NtileI=1
NtileJ=2
