COAWST Compiling cowastM failed
whiteliu
#1 Unread post by whiteliu »
Dear seniors,
I am attempting to compile the project in COAWST. (ubuntu 22.04 + gfortran + mpich2)
The same setting can be compiled and runned normally for the case of "Rip_current".
However, I got an error while compiling the case of "Sandy" as shown below.
cd /home/white/COAWST/diy/Sandy/Build; /usr/bin/mpif90 -c -frepack-arrays -fallow-argument-mismatch -O3 -ffast-math -O3 -ftree-vectorize -ftree-loop-linear -funroll-loops -w -ffree-form -ffree-line-length-none -frecord-marker=4 -fconvert=big-endian -I/usr/include -I/usr/local/include/ -I/home/white/COAWST/WRF/main -I/home/white/COAWST/WRF/external/esmf_time_f90 -I/home/white/COAWST/WRF/frame -I/home/white/COAWST/WRF/share master.f90
master.f90:26:11:
26 | USE module_wrf_top, ONLY : wrf_init
| 1
Fatal Error: Cannot open module file ‘module_wrf_top.mod’ for reading at (1): No such file or directory
compilation terminated.
make: *** [Master/Module.mk:25: /home/white/COAWST/diy/Sandy/Build/master.o] Error 1
Attached are the coawst.bash file and the compilation messages in build.log.
Could anyone please provide guidance on how to resolve this issue? Thanks.
coawst.bash
(20.97 KiB) Downloaded 807 times
build.log
(526.78 KiB) Downloaded 645 times
Re: COAWST Compiling cowastM failed
For compile errors with coawst, please submit them to
https://github.com/jcwarner-usgs/COAWST/issues
i took a quick look at your compile log. there are lots of issues.
first, it shows
"f951: Warning: Nonexistent include directory ‘/main’ [-Wmissing-include-dirs]
f951: Warning: Nonexistent include directory ‘/external/esmf_time_f90’ [-Wmissing-include-dirs]
f951: Warning: Nonexistent include directory ‘/frame’ [-Wmissing-include-dirs]
f951: Warning: Nonexistent include directory ‘/share’ [-Wmissing-include-dirs]
f951: Warning: Nonexistent include directory ‘/share’ [-Wmissing-include-dirs]"
so maybe you dont have the full set of code?
second it then says
No environment variable NETCDF set.
Stopping
You need to set the NETCDF env var.
I suggest you look in the COAWST user doc. there is lots of good information in there on how to set up your env and to run the sandy case.
if you have more troubles for the coupling then post that on the coawst site.
-john
whiteliu
#3 Unread post by whiteliu »
Thanks John.
Follow the user manual, install netCDF-C 4.9.2 and netCDF-FORTRAN 4.6.1 to the same directory, and set the NETCDF, NETCDF_INCLUDE and NETCDF_LIB paths in the bash file. It worked!!!
By the way, in coawst.bash,
move "export =${MY_ROMS_SRC}/WRF" before "make mct_params" to avoid Warning below:
