cluster distribution parameter in floats.in
cuixuan
Location: Institute of Oceanology,Chinese Academy of Science
#1 Unread post by cuixuan »
I am trying to release some floats through floats.in. However, I do not understand what the Fdx, Fdy, Fdz mean. It is said that "The user can use any of these parameters to design any cluster distribution in routine init_floats.F". Where is init_floats.F located? Can anyone help me with that? :D
Re: cluster distribution parameter in floats.in
#2 Unread post by wilkin »
There is some additional, admittedly very succinct, documentation at https://www.myroms.org/wiki/floats.in
As an example, the code below will initialize 15 floats at i = 3 (Fx0 =3), j = 2 (Fy0 = 2) and k = 1:2:31 (Fz0 = 1, Fdz = 2):
!   C      Initial horizontal coordinate type (0: grid units, 1: spherical)
!   T      Float trajectory type (1: Lagrangian, 2: isobaric, 3: Geopotential)
!   N      Number floats to be released at (Fx0,Fy0,Fz0)
!   Ft0    Float release time (days) after model initialization
!   Fx0    Initial float X-location (grid units or longitude)
!   Fy0    Initial float Y-location (grid units or latitude)
!   Fz0    Initial float Z-location (grid units or depth)
!   Fdt    Float cluster release time interval (days)
!   Fdx    Float cluster X-distribution parameter
!   Fdy    Float cluster Y-distribution parameter
!   Fdz    Float cluster Z-distribution parameter
POS = G, C, T, N,   Ft0,    Fx0,    Fy0,    Fz0,    Fdt,    Fdx,    Fdy,   Fdz
      1  0  1  15   0.00    3.00    2.00    1.0     0.00     0.00   0.00   2.00
The initialization is in terms of i,j,k because C = 0.
For physical x,y,z space use C = 1.
Note you can mix coordinate type because it is set for each line in floats.in.
