How do I set the time in the bulk file
jc_Sun
Location: Institute of Oceanology of the Chinese Academy
#1 Unread post by jc_Sun »
I'm having a problem running ROMs, which tells me that there is a problem with the timing. The driver field file I use is CFVR data, and the time is datenum(NECPTime-1980010100:00:00). Do I need to convert it into ROMS readable time? How do I set it?
MULTIFILE_INFO_S2D - Error while processing forcing multi-files:
data does not include initialization time = 0001-01-01 00:00:00.00
0040-07-30 00:00:00.00 0040-09-02 18:00:00.00 roms_blk_CFSR_Y2019M8.nc
Found Error: 04 Line: 481 Source: ROMS/Utility/check_multifile.F, multifile_info_s2d
Found Error: 04 Line: 188 Source: ROMS/Utility/check_multifile.F
Found Error: 04 Line: 656 Source: ROMS/Nonlinear/initial.F
Found Error: 04 Line: 197 Source: ROMS/Drivers/nl_roms.h, ROMS_initialize
jbettencourt
Re: How do I set the time in the bulk file
#2 Unread post by jbettencourt »
It seems you need to check two things:
  • In your forcing file, the units attribute of the time variable to see if it matches with the time data.
  • In your input file, the initialisation time of the model, that is the value of TIMEREF and DSTART.
jc_Sun
#3 Unread post by jc_Sun »
jbettencourt wrote: Mon Sep 19, 2022 7:00 am Hi,
In my forcing file, the units attribute of the time variable as shown below. And do the values of TIMEREF and DSTART need to be checked in the in file?
wind_time
Dimensions: wind_time
Datatype: double
Attributes:
long_name = 'wind_time'
units = 'days'
field = 'Uwind_time, scalar, series'
Uwind
Dimensions: xrho,yrho,wind_time
Datatype: double
Attributes:
long_name = 'surface u-wind component'
units = 'meter second-1'
field = 'Uwind, scalar, series'
coordinates = 'lon lat'
time = 'wind_time'
Vwind
Datatype: double
Attributes:
long_name = 'surface v-wind component'
field = 'Vwind, scalar, series'
time = 'wind_time'
Pair_time
Dimensions: Pair_time
Datatype: double
Attributes:
long_name = 'Pair_time'
units = 'days'
field = 'Pair_time, scalar, series'
Pair
Dimensions: xrho,yrho,Pair_time
Datatype: double
Attributes:
long_name = 'surface air pressure'
units = 'millibar'
field = 'Pair, scalar, series'
time = 'Pair_time'
jbettencourt
#4 Unread post by jbettencourt »
Your units attribute should be like "days since 1980-01-01 00:00:00", so that the model can have a reference time from which to count the time units. In the input file, you should set TIMEREF to an appropriate reference time, that could be the same as the one in the forcing file, and then set DSTART accordingly.
jc_Sun
#5 Unread post by jc_Sun »
jbettencourt wrote: Mon Sep 19, 2022 7:49 am Your units attribute should be like "days since 1980-01-01 00:00:00", so that the model can have a reference time from which to count the time units. In the input file, you should set TIMEREF to an appropriate reference time, that could be the same as the one in the forcing file, and then set DSTART accordingly.
Hi jbettencourt
Thanks a lot for your replay, i'll take that in account
Have a nice day
jc_Sun
#6 Unread post by jc_Sun »
[/code]
According to your proposal, I have changed the units into days since 19800101, as shown in the picture below, but I was also prompted to make a new error.
 wind_time
           Datatype:   double
           Attributes:
                       units     = 'days since 1980-01-01'
    Uwind
           Datatype:   double
           Attributes:
                       time        = 'wind_time'
Found Error: 04   Line: 354      Source: ROMS/Utility/get_2dfld.F, get_2dfld_nf90
 GET_2DFLD_NF90 - error while reading variable: Uwind   at TIME index = 8
 Found Error: 04   Line: 112      Source: ROMS/Utility/get_2dfld.F
 Found Error: 04   Line: 169      Source: ROMS/Nonlinear/get_data.F
 Found Error: 04   Line: 670      Source: ROMS/Nonlinear/initial.F
jbettencourt
#7 Unread post by jbettencourt »
I think this means that the error is with the Uwind variable data in the file.
jc_Sun
#8 Unread post by jc_Sun »
jbettencourt wrote: Tue Sep 20, 2022 6:39 am
I'm sorry I left a little bit out, but it's related to the grid.But how to deal with that? The latitude and longitude of my bulk file is shown below.
REGRID - input gridded data does not contain model grid:
          Gridded:  LonMin =  117.0000 LonMax =  124.0000
                    LatMin =   37.0000 LatMax =   41.0148
          Model:    LonMin =    0.0000 LonMax =    0.0000
                    LatMin =    0.0000 LatMax =    0.0000
lon
           Datatype:   double
           Attributes:
                       long_name = 'longitude'
                       units     = 'degrees_east'
                       field     = 'xp, scalar, series'
    lat
           Datatype:   double
           Attributes:
                       long_name = 'latitude'
                       units     = 'degrees_north'
                       field     = 'yp, scalar, series'
jbettencourt
#9 Unread post by jbettencourt »
Can you post the log file?
jc_Sun
#10 Unread post by jc_Sun »
jbettencourt wrote: Tue Sep 20, 2022 11:52 am Can you post the log file?
This si my log file.
output.txt
(33.08 KiB) Downloaded 232 times
jbettencourt
#11 Unread post by jbettencourt »
From what I could gather, the problem might be that your forcing fields grid is inconsistent with your model grid. Your model grid appears to be defined in cartesian coordinates:
 ANA_GRID    - x-location of RHO-points: x_rho
                   (Grid = 01, Min = -5.00000000E+02 Max =  8.35000000E+04)
ANA_GRID    - y-location of RHO-points: y_rho
                   (Grid = 01, Min = -5.00000000E+02 Max =  6.15000000E+04)
while your forcing fields appear to be defined on spherical coordinates:
If you look at the last two lines of the error message above, you'll see that the model doesn't have information about the spherical coordinates of the model grid (Lon and lat min/max are zero).
To use spherical coordinates in the model grid, you should activate the SPHERICAL CPP flag in the application header file and then define the spherical coordinates in ana_grid.h.
jc_Sun
#12 Unread post by jc_Sun »
jbettencourt wrote: Wed Sep 21, 2022 6:43 am From what I could gather, the problem might be that your forcing fields grid is inconsistent with your model grid. Your model grid appears to be defined in cartesian coordinates:
Thank you for your reply and have a nice day!
