In realistic simulations using Roms 3.0, the starting date (of the simulation) may be not necessarily the same in the input NetCDF forcing and initial files, because the frequency and starting date of each original data base are not necessarily the same.
1) Could someone tell me where the starting date of a simulation should be set ? (in the "ini" file ? or into another file of ROMS 3.0 ? ) If the answer is "in the ini file" then my question is "is there a way to set a starting date different from those of initial and forcing files ?
2) Also, is it possible to set an "ending date" of the simulation ? or do I have to depend on NTIMES ?
bye and have all a great 2008
defininig the starting date
Re: defininig the starting date
The key is consistency from the ROMS point of view. ROMS will check to make sure that the forcing times surround your current model time. It gets the current model time from the ini file.
The ascii input file is also relevant. You do need to depend on NTIMES, but also check the DSTART and the TIME_REF. For instance, many of our runs have:
I then set my time in the initial file to match 21185 days if I'm planning to actually start at that time. Also, I've been known to adjust the first forcing time to set it to match, even if it was days or weeks later.
DSTART = 21185.0d0 ! days
TIME_REF = 19000101.0d0 ! yyyymmdd.dd
Kate,
It would be very nice to go there specially if the training were oriented to ocean-atmosphere coupling because I am working with a meteorologist staff. In that case, I suppose one week would be a short time, I would prefer a more intensive training of two or more weeks and/or a visit for work there for some months.....
Bye
Bye
