ROMS BLOWUP MaxDensity
markus.qs
#1 Unread post by markus.qs »
I'm having a difficult time trying to run the ROMS model on a local lake. The error states that the blow-up is because of the maxdensity, here 7.3*10⁵. How do I correct it?
Below is some of the output from ROMS:
Minimum X-grid spacing, DXmin = 1.21456751E-01 km Water points = 1.21619998E-01 km
Maximum X-grid spacing, DXmax = 1.21961210E-01 km Water points = 1.21961210E-01 km
Minimum Y-grid spacing, DYmin = 5.96607629E-02 km Water points = 5.97458276E-02 km
Maximum Y-grid spacing, DYmax = 5.99181318E-02 km Water points = 5.99181318E-02 km
Minimum Z-grid spacing, DZmin = 3.33486014E-02 m Water points = 5.43715807E-02 m
Maximum Z-grid spacing, DZmax = 3.33111113E+01 m Water points = 3.33111113E+01 m
Minimum barotropic Courant Number = 1.32849609E-02
Maximum barotropic Courant Number = 1.26711469E-01
Maximum Coriolis Courant Number = 1.25369904E-03
Horizontal mixing scaled by grid area squared root, MAXVAL(grdscl) = 8.54850153E-02 km (Water points)
AND THE ERROR:
Found Error: 01 Line: 314 Source: ROMS/Nonlinear/main3d.F
Found Error: 01 Line: 301 Source: ROMS/Drivers/nl_roms.h, ROMS_run
REASON: MaxDensity = 7.3E+25
WRT_RST_NF90 - wrote re-start fields (Index=2,2) in record = 1
Fyi, the bathymetry is smoothed and ROMS manage to run the first timestep before blown-up.
Best regard
Markus QS
ymamoutos
Re: ROMS BLOWUP MaxDensity
#2 Unread post by ymamoutos »
Greetings
Is it possible to post your log file?
What are the options you are using
at the *.h? What is your dt and dtfast?
Giannis
markus.qs
#3 Unread post by markus.qs »
Thanks for the reply
I figured it out eventually. The shortwave radiation values generated from the forcingfile were way to high, and therefore the total energy became extremely negative after just one time step
Sorry for the disturbance
ast212183
#4 Unread post by ast212183 »
hello markus.qs ,
can you please tell what changes have you made to the header file/input file in order to solve the issue. I am very new to ROMS and I am also getting similar error.
number of time records written in HISTORY file = 1
number of time records written in RESTART file = 1
Analytical header files used:
ROMS/Functionals/ana_btflux.h
REASON: MaxDensity = 3.7E+02
