Hi! I have spent some time trying to get to know ROMS, but unfortunately I can't seem to configure/run the model on my case (which is a freshwater lake). I am very new to modeling, and I suspect that this error could be easily fixed - by someone who is not me, apparently.
When trying to run, I get this error message:
INP_PAR:FIND_FILE - empty file name string for standard input script KeyWord: SSFNAME
Found Error: 05 Line: 434 Source: ROMS/Utility/inp_decode.F, find_file
READ_PHYPAR - Grid 01, could not find input file: Oops unassigned file name. Check standard input script...
Found Error: 04 Line: 6728 Source: ROMS/Utility/read_phypar.F
Found Error: 04 Line: 201 Source: ROMS/Utility/inp_par.F
Found Error: 04 Line: 124 Source: ROMS/Drivers/nl_roms.h, ROMS_initialize
I have tried to look through my headerfile and .in-file, without luck, and I cannot find where SSFNAME is set.
My headerfile looks like this:
** Options for Closed Basin (Lake) forced with wind.
** Application flag: NORSJO_TEST
** Input script: ocean_n_test.in
#define SPLINES_VDIFF
#define SPLINES_VVISC
#define TS_MPDATA
#define FLOATS
#define SSW_BBL
#ifdef SSW_BBL
# define SSW_CALC_UB
# define SSW_CALC_ZNOT
# undef SSW_LOGINT
#define GET_GRID
#define GET_STATE
#define ANA_SMFLUX
#define ANA_SSFLUX
#define GLS_MIXING
#if defined GLS_MIXING
# define RI_SPLINES
The .in-file is of course long and full of possible errors, but my input-files are included like this:
GRDNAME == /home/birgit/ROMS_scripts/Grid/norsjo.nc
ININAME == /home/birgit/ROMS_scripts/Init/norsjo_init.nc
NFFILES == 1 ! number of forcing files
FRCNAME == /home/birgit/ROMS_scripts/Forcing_data/Scripts/Output/norsjo_forcing_150.nc
! Output NetCDF file names, [1:Ngrids].
RSTNAME == /home/birgit/my_roms_projects/norsjo/norsjo_rst.nc
HISNAME == /home/birgit/my_roms_projects/norsjo/norsjo_rst.nc
AVGNAME == /home/birgit/my_roms_projects/norsjo/norsjo_avg.nc
Do any of you guys have an idea on where to start?
Sincerely, Birgit
INP_PAR, PHYPAR: Problems finding input file.
Re: INP_PAR, PHYPAR: Problems finding input file.
Do you have a line for SSFNAME? That is a newish requirement.INP_PAR:FIND_FILE - empty file name string for standard input script KeyWord: SSFNAME
Thank you for answering, I had to add the SSFNAME. Now I am one step closer to making the model run!
My error now looks like this:
GET_GRID - Illegal output type, io_type = 0
Found Error: 03 Line: 90 Source: ROMS/Utility/get_grid.F
Found Error: 03 Line: 82 Source: ROMS/Utility/set_grid.F
GET_STATE - Illegal output type, io_type = 0
Found Error: 03 Line: 151 Source: ROMS/Utility/get_state.F
Found Error: 03 Line: 417 Source: ROMS/Nonlinear/initial.F
Found Error: 03 Line: 200 Source: ROMS/Drivers/nl_roms.h, ROMS_initialize
Thread # 0 CPU: 5.059
Total: 5.059
Allocation and array initialization .............. 5.059 (99.9936 %)
Total: 5.059 99.9936 %
Unique kernel(s) regions profiled ................ 5.059 99.9936 %
Residual, non-profiled code ...................... 0.000 0.0064 %
All percentages are with respect to total time = 5.059
Dynamic and Automatic memory (MB) usage for Grid 01: 150x150x30 tiling: 1x1
tile Dynamic Automatic USAGE
0 270.10 42.40 312.50
TOTAL 270.10 42.40 312.50
Found Error: 03 Line: 85 Source: ROMS/Utility/close_io.F, close_file_nf90
Found Error: 03 Line: 381 Source: ROMS/Utility/close_io.F, close_out
REASON: No error
ERROR STOP
Error termination. Backtrace:
#0 0x7f338807ad21 in ???
#1 0x7f338807b869 in ???
#2 0x7f338807cf97 in ???
#3 0x55dc167099bf in myroms
at /home/birgit/my_roms_projects/norsjo/Build_romsG/master.f90:101
#4 0x55dc16709a18 in main
at /home/birgit/my_roms_projects/norsjo/Build_romsG/master.f90:50
I made my grid with pygridgen, and I thnk the grid itself should be fine. I use "#define GET_GRID" in my headerfile, and have the correct path to the grid in my .in-file. Do you have an idea of what i missed?
(Also, thanks for being so tolerant with all our questions!!)
Total: 5.059
REASON: No error
ERROR STOP
ROMS is telling you what it is wrong:
Make sure that your roms.in is up to date.GET_GRID - Illegal output type, io_type = 0
Is it in the roms.in or in the grid file? My grid file has:
// global attributes:
:type = "ROMS grid file" ;
I don't think so. This is because of the PIO library support changes to ROMS. For some reason, inp_type in roms.in is zero. It is weird because it is initialized to zero internally if the user doesn't specified a value.
Hey,
I also beleive that I didn't make my roms.in-file correctly. Even if I am aware of the error message "GET_GRID - Illegal output type, io_type = 0", it is not clear to me how to "make sure my roms.in is up to date". My grid-file is included like this:
Do I have to state anything more for ROMS to read the file? I tried looking at multiple other example roms.in-files, but cannot find anything that seems obvious to me.
Again, thank you for your time!
Start from one of the example roms.in files in a recent version of the code, and work your way through adding the options you want. This is a safe way to make sure the file is complete, and that you have taken active control of all the options you set.it is not clear to me how to "make sure my roms.in is up to date". My grid-file is included like this:
I notice you have in your .h #define TS_MPDATA. Advection scheme options are now set in roms.in and that #define does nothing.
