Roms can not write down the .rst file
zhqianj
#1 Unread post by zhqianj »
Hello everyone
I am new to ROMS, and I encounter the following issure. It states that: DEF_RST - Illegal output type, io_type = 0. Many many thanks for your help.
The log file states:
Model Input Parameters: ROMS/TOMS version 4.0
Tuesday - July 6, 2021 - 10:22:00 AM
tide_bore
Operating system : Linux
CPU/hardware : x86_64
Compiler system : gfortran
Compiler command : /usr/bin/mpif90
Compiler flags : -frepack-arrays -O3 -ffast-math -
OCN Communicator : 1140850688, PET size = 4
Input Script : ./roms_tidebore.in
SVN Revision : 1077
Local Root : /mnt/e/numerical_model/roms_1053
Header Dir : /mnt/d/tidal_bore/tidalbore_small
Header file : tide_bore.h
Analytical Dir : /mnt/d/tidal_bore/tidalbore_small
Resolution, Grid 01: 698x178x10, Parallel Nodes: 4, Tiling: 2x2
25000 ntimes Number of timesteps for 3-D equations.
60.000 dt Timestep size (s) for 3-D equations.
5 ndtfast Number of timesteps for 2-D equations between
30 nRST Number of timesteps between the writing of data
into restart fields.
to standard output.
10 nHIS Number of timesteps between the writing fields
into history file.
into quicksave file.
F LtracerSponge(02) Turning OFF sponge on tracer 02:
for tracer 02:
for turbulent energy.
1.0000E-03 rdrg2 Quadratic bottom drag coefficient.
1.0000E-01 Dcrit Minimum depth for wetting and drying (m).
1.0000E+00 theta_s S-coordinate surface control parameter.
1.0000E+00 theta_b S-coordinate bottom control parameter.
1.000 Tcline S-coordinate surface/bottom layer width (m) used
for tracer 02:
for 3D momentum.
of State.
0.0000E+00 Scoef Saline contraction coefficient (1/PSU).
F LtracerSrc(02) Turning OFF point Sources/Sinks on tracer 02:
F LtracerCLM(02) Turning OFF processing of climatology tracer 02:
F LnudgeTCLM(02) Turning OFF nudging of climatology tracer 02:
1 inp_lib Using standard NetCDF library for input files.
1 out_lib Using standard NetCDF library for output files.
Output Restart File:
Output History File: tidebore_his.nc
Input Grid File: tidebore_grd.nc
Tidal Forcing File: tidebore_tideforcing.nc
Input Forcing File 01: tidebore_frc.nc
Input Lateral Boundary File 01: tidebore_bry.nc
ROMS I/O variables Metadata File: /mnt/e/numerical_model/roms_1053/ROMS/External/varinfo.dat
Input/Output USER File: MyFile.dat
Generic User Parameters:
1.0000E+00 user(01) User parameter 01.
Tile partition information for Grid 01: 698x178x10 tiling: 2x2
tile Istr Iend Jstr Jend Npts
0 1 349 1 89 310610
1 350 698 1 89 310610
2 1 349 90 178 310610
3 350 698 90 178 310610
(interior points only)
tile Xmin Xmax Ymin Ymax grid
0 0.50 349.50 0.50 89.50 RHO-points
1 349.50 698.50 0.50 89.50 RHO-points
2 0.50 349.50 89.50 178.50 RHO-points
3 349.50 698.50 89.50 178.50 RHO-points
0 1.00 349.50 0.50 89.50 U-points
1 349.50 698.00 0.50 89.50 U-points
2 1.00 349.50 89.50 178.50 U-points
3 349.50 698.00 89.50 178.50 U-points
0 0.50 349.50 1.00 89.50 V-points
1 349.50 698.50 1.00 89.50 V-points
2 0.50 349.50 89.50 178.00 V-points
3 349.50 698.50 89.50 178.00 V-points
HaloSizeI(1) = 722
HaloSizeJ(1) = 202
TileSide(1) = 355
TileSize(1) = 33725
Tracer Advection Scheme: NLM
Variable Grid Horizontal Vertical
temp 1 Upstream3 Centered4
Akima4 Fourth-order Akima advection
Centered2 Second-order centered differences advection
Centered4 Fourth-order centered differences advection
HSIMT Third High-order Spatial Inteporlation at Middle Time Advection with TVD limiter
MPDATA Multidimensional Positive Definite Advection Algorithm, recursive method
Splines Conservative Parabolic Splines Reconstruction Advection (only vertical; not recommended)
Split_U3 Split third-order Upstream Advection
Upstream3 Third-order Upstream-biased Advection (only horizontal)
zeta 1 Closed Closed Chapman Imp Closed
ubar 1 Closed Closed Flather Closed
vbar 1 Closed Closed Flather Closed
u 1 Closed Closed Radiation Closed
v 1 Closed Closed Radiation Closed
temp 1 Closed Closed Radiation Closed
tke 1 Closed Closed Radiation Closed
tide_bore tide_bore
ANA_BSFLUX Analytical kinematic bottom salinity flux
ANA_BTFLUX Analytical kinematic bottom temperature flux
ANA_INITIAL Analytical initial conditions
ASSUMED_SHAPE Using assumed-shape arrays
BOUNDARY_ALLREDUCE Using mpi_allreduce in mp_boundary routine
COLLECT_ALLREDUCE Using mpi_allreduce in mp_collect routine
DEBUGGING Internal debugging switch activated
DOUBLE_PRECISION Double precision arithmetic numerical kernel.
GLS_MIXING Generic Length-Scale turbulence closure
LIMIT_BSTRESS Limit bottom stress to maintain bottom velocity direction
KANTHA_CLAYSON Kantha and Clayson stability function formulation
MASKING Land/Sea masking
MPI MPI distributed-memory configuration
NONLINEAR Nonlinear Model
!NONLIN_EOS Linear Equation of State for seawater
N2S2_HORAVG Horizontal smoothing of buoyancy and shear
POWER_LAW Power-law shape time-averaging barotropic filter
PRSGRD31 Standard density Jacobian formulation (Song, 1998)
PROFILE Time profiling activated
K_GSCHEME Third-order upstream advection of TKE fields
RAMP_TIDES Ramping tidal forcing for one day
REDUCE_ALLREDUCE Using mpi_allreduce in mp_reduce routine
RI_SPLINES Parabolic Spline Reconstruction for Richardson Number
RHO_SURF Include difference between rho0 and surface density
RST_SINGLE Single precision fields in restart NetCDF file
SOLVE3D Solving 3D Primitive Equations
SPLINES_VDIFF Parabolic Spline Reconstruction for Vertical Diffusion
SPLINES_VVISC Parabolic Spline Reconstruction for Vertical Viscosity
SSH_TIDES Add tidal elevation to SSH climatology
TS_FIXED Diagnostic configuration, no evolution of tracer
UV_ADV Advection of momentum
UV_COR Coriolis term
UV_U3HADVECTION Third-order upstream horizontal advection of 3D momentum
UV_C4VADVECTION Fourth-order centered vertical advection of momentum
UV_QDRAG Quadratic bottom stress
UV_TIDES Add tidal currents to 2D momentum climatologies
VAR_RHO_2D Variable density barotropic mode
WET_DRY Wetting and drying activated
Process Information:
Node # 0 (pid= 17943) is active.
Node # 1 (pid= 17944) is active.
Node # 2 (pid= 17945) is active.
Node # 3 (pid= 17946) is active.
GET_GRID_NF90 - angle between XI-axis and EAST: angler
(Grid = 01, File: tidebore_grd.nc)
(Min = 3.26211878E-01 Max = 3.33637132E-01)
GET_GRID_NF90 - bathymetry at RHO-points: h
(Min = 1.00000000E+00 Max = 3.24228767E+01)
GET_GRID_NF90 - Coriolis parameter at RHO-points: f
(Min = 7.26867133E-05 Max = 7.42329861E-05)
GET_GRID_NF90 - reciprocal XI-grid spacing: pm
(Min = 4.92013714E-03 Max = 4.94395978E-03)
GET_GRID_NF90 - reciprocal ETA-grid spacing: pn
(Min = 5.24281944E-03 Max = 5.33272306E-03)
GET_GRID_NF90 - longitude of RHO-points: lon_rho
(Min = 1.19707389E+02 Max = 1.21209230E+02)
GET_GRID_NF90 - longitude of U-points: lon_u
(Min = 1.19708388E+02 Max = 1.21208232E+02)
GET_GRID_NF90 - longitude of V-points: lon_v
(Min = 1.19707686E+02 Max = 1.21208934E+02)
GET_GRID_NF90 - longitude of PSI-points: lon_psi
(Min = 1.19708684E+02 Max = 1.21207936E+02)
GET_GRID_NF90 - latitude of RHO-points lat_rho
(Min = 2.98942272E+01 Max = 3.05974376E+01)
GET_GRID_NF90 - latitude of U-points: lat_u
(Min = 2.98945205E+01 Max = 3.05971403E+01)
GET_GRID_NF90 - latitude of V-points: lat_v
(Min = 2.98950304E+01 Max = 3.05966189E+01)
GET_GRID_NF90 - latitude of PSI-points lat_psi
(Min = 2.98953238E+01 Max = 3.05963216E+01)
GET_GRID_NF90 - mask on RHO-points: mask_rho
(Min = 0.00000000E+00 Max = 1.00000000E+00)
GET_GRID_NF90 - mask on U-points: mask_u
GET_GRID_NF90 - mask on V-points: mask_v
GET_GRID_NF90 - mask on PSI-points: mask_psi
10 0.0000000 0.0000000 0.000 0.000 0.000 0.000
9 -0.1000000 -0.0889041 -0.100 -0.100 -1.497 -2.894
8 -0.2000000 -0.1848065 -0.200 -0.200 -3.104 -6.007
7 -0.3000000 -0.2864445 -0.300 -0.300 -4.800 -9.301
6 -0.4000000 -0.3921616 -0.400 -0.400 -6.561 -12.723
5 -0.5000000 -0.5000000 -0.500 -0.500 -8.356 -16.211
4 -0.6000000 -0.6078384 -0.600 -0.600 -10.150 -19.700
3 -0.7000000 -0.7135555 -0.700 -0.700 -11.911 -23.122
2 -0.8000000 -0.8151935 -0.800 -0.800 -13.608 -26.416
1 -0.9000000 -0.9110959 -0.900 -0.900 -15.215 -29.529
0 -1.0000000 -1.0000000 -1.000 -1.000 -16.711 -32.423
Time Splitting Weights for Grid 01: ndtfast = 5 nfast = 7
1 0.0119306869089341 0.2000000000000000 0.0119306869089341 0.2000000000000000
2 0.0475049776008206 0.1976138626182132 0.0594356645097548 0.3976138626182132
3 0.1047629417620785 0.1881128670980491 0.1641986062718333 0.5857267297162623
4 0.1760826281731956 0.1671602787456334 0.3402812344450289 0.7528870084618957
5 0.2416469636634479 0.1319437531109943 0.5819281981084767 0.8848307615728900
6 0.2602974116474963 0.0836143603783047 0.8422256097559730 0.9684451219511947
7 0.1577743902440272 0.0315548780488054 1.0000000000000002 1.0000000000000002
ndtfast, nfast = 5 7 nfast/ndtfast = 1.40000
1.000000000000 1.084198606272 0.542099303136 1.000000000000 1.000000000000
Power filter parameters, Fgamma, gamma = 0.28400 0.00000
Minimum X-grid spacing, DXmin = 2.02267018E-01 km Water points = 2.02270761E-01 km
Maximum X-grid spacing, DXmax = 2.03246367E-01 km Water points = 2.03244460E-01 km
Minimum Y-grid spacing, DYmin = 1.87521457E-01 km Water points = 1.87577543E-01 km
Maximum Y-grid spacing, DYmax = 1.90737066E-01 km Water points = 1.90722487E-01 km
Minimum Z-grid spacing, DZmin = 1.00000000E-01 m Water points = 1.00000000E-01 m
Maximum Z-grid spacing, DZmax = 3.48859427E+00 m Water points = 3.48859427E+00 m
Minimum barotropic Courant Number = 2.70752784E-01
Maximum barotropic Courant Number = 1.54350222E+00
Maximum Coriolis Courant Number = 4.45333339E-03
ANA_INITIAL - vertically integrated u-momentum component: ubar
(Grid = 01, Min = 0.00000000E+00 Max = 0.00000000E+00)
ANA_INITIAL - vertically integrated v-momentum component: vbar
ANA_INITIAL - free-surface: zeta
ANA_INITIAL - u-momentum component: u
ANA_INITIAL - v-momentum component: v
ANA_INITIAL - potential temperature: temp
(Grid = 01, Min = 1.40000000E+01 Max = 1.40000000E+01)
ANA_INITIAL - :
GET_NGFLD_NF90 - tidal period
GET_2DFLD_NF90 - tidal elevation amplitude
(Grid = 01, Min = 0.00000000E+00 Max = 2.71615040E+00)
GET_2DFLD_NF90 - tidal elevation phase angle
(Grid = 01, Min = 0.00000000E+00 Max = 6.27040629E+00)
GET_2DFLD_NF90 - tidal current inclination angle
(Grid = 01, Min = 0.00000000E+00 Max = 6.22587082E+00)
GET_2DFLD_NF90 - tidal current phase angle
GET_2DFLD_NF90 - maximum tidal current, ellipse major axis
(Grid = 01, Min = 0.00000000E+00 Max = 1.88859173E+00)
GET_2DFLD_NF90 - minimum tidal current, ellipse minor axis
(Grid = 01, Min = -3.80372082E-01 Max = 1.31444068E-01)
GET_2DFLD_NF90 - surface u-momentum stress, 0001-01-01 00:00:00.00
(Grid=01, Rec=1, Index=1, File: tidebore_frc.nc)
(Tmin= 0.0000 Tmax= 180.0000) t = 0.0000
(Min = 0.00000000E+00 Max = 0.00000000E+00) regrid = F
GET_2DFLD_NF90 - surface v-momentum stress, 0001-01-01 00:00:00.00
GET_2DFLD_NF90 - surface net heat flux, 0001-01-01 00:00:00.00
GET_NGFLD_NF90 - free-surface eastern boundary condition, 0001-01-01 00:00:00.00
(Grid= 01, Rec=1, Index=2, File: tidebore_bry.nc)
GET_NGFLD_NF90 - 2D u-momentum eastern boundary condition, 0001-01-01 00:00:00.00
GET_NGFLD_NF90 - 2D v-momentum eastern boundary condition, 0001-01-01 00:00:00.00
Maximum grid stiffness ratios: rx0 = 2.000000E-01 (Beckmann and Haidvogel)
rx1 = 4.273600E+00 (Haney)
Initial domain volumes: TotVolume = 6.0672671833E+09 m3
MinCellVol = 3.8235622845E+03 m3
MaxCellVol = 1.3439476784E+05 m3
Max/Min = 3.5149098627E+01
NL ROMS/TOMS: started time-stepping: (Grid: 01 TimeSteps: 000000000001 - 000000025000)
GET_2DFLD_NF90 - surface u-momentum stress, 0001-01-16 00:00:00.00
(Grid=01, Rec=2, Index=2, File: tidebore_frc.nc)
(Tmin= 0.0000 Tmax= 180.0000) t = 15.0000
GET_2DFLD_NF90 - surface v-momentum stress, 0001-01-16 00:00:00.00
GET_2DFLD_NF90 - surface net heat flux, 0001-01-16 00:00:00.00
GET_NGFLD_NF90 - free-surface eastern boundary condition, 0001-01-16 00:00:00.00
(Grid= 01, Rec=2, Index=1, File: tidebore_bry.nc)
GET_NGFLD_NF90 - 2D u-momentum eastern boundary condition, 0001-01-16 00:00:00.00
GET_NGFLD_NF90 - 2D v-momentum eastern boundary condition, 0001-01-16 00:00:00.00
0 0001-01-01 00:00:00.00 0.000000E+00 2.666835E+01 2.666835E+01 9.713888E+09
(000,000,00) 0.000000E+00 0.000000E+00 0.000000E+00 0.000000E+00
DEF_HIS_NF90 - creating history file, Grid 01: tidebore_his.nc
WRT_HIS_NF90 - wrote history fields (Index=1,1) in record = 1
Found Error: 03 Line: 85 Source: ROMS/Utility/def_rst.F
Found Error: 03 Line: 576 Source: ROMS/Nonlinear/output.F
Found Error: 03 Line: 518 Source: ROMS/Nonlinear/main3d.F
Found Error: 03 Line: 301 Source: ROMS/Drivers/nl_roms.h, ROMS_run
Elapsed wall CPU time for each process (seconds):
Node # 0 CPU: 0.938
Total: 3.969
Average: 0.992
Minimum: 0.938
Maximum: 1.031
Allocation and array initialization .............. 0.922 (23.2283 %)
Ocean state initialization ....................... 0.062 ( 1.5748 %)
Reading of input data ............................ 0.734 (18.5039 %)
Computation of global information integrals ...... 0.062 ( 1.5748 %)
2D/3D coupling, vertical metrics ................. 0.172 ( 4.3307 %)
Omega vertical velocity .......................... 0.062 ( 1.5748 %)
Total: 2.016 50.7874 %
Unique kernel(s) regions profiled ................ 2.016 50.7874 %
Residual, non-profiled code ...................... 1.953 49.2126 %
All percentages are with respect to total time = 3.969
MPI communications profile, Grid: 01
Message Passage: 2D halo exchanges ............... 0.016 ( 0.3937 %)
Message Passage: 3D halo exchanges ............... 0.016 ( 0.3937 %)
Message Passage: data broadcast .................. 0.938 (23.6220 %)
Message Passage: data reduction .................. 0.047 ( 1.1811 %)
Message Passage: data gathering .................. 0.375 ( 9.4488 %)
Message Passage: data scattering.................. 0.516 (12.9921 %)
Total: 1.906 48.0315 %
Dynamic and Automatic memory (MB) usage for Grid 01: 698x178x10 tiling: 2x2
tile Dynamic Automatic USAGE MPI-Buffers
0 142.73 22.18 164.91 11.87
1 143.14 22.18 165.31 11.87
2 144.27 22.18 166.45 11.87
3 144.68 22.18 166.86 11.87
TOTAL 574.83 88.70 663.53 47.48
Found Error: 03 Line: 85 Source: ROMS/Utility/close_io.F, close_file_nf90
Found Error: 03 Line: 121 Source: ROMS/Utility/close_io.F, close_inp
number of time records written in HISTORY file = 1
Analytical header files used:
ROMS/Functionals/ana_btflux.h
Found Error: 03 Line: 381 Source: ROMS/Utility/close_io.F, close_out
ROMS/TOMS - Output error ............ exit_flag: 3
Node # 1 CPU: 1.031
Node # 2 CPU: 1.016
Node # 3 CPU: 0.984
REASON: No error
The .in file I used is :
! Application title.
TITLE = tide_bore
! C-preprocessing Flag.
MyAppCPP = tide_bore
VARNAME = /mnt/e/numerical_model/roms_1053/ROMS/External/varinfo.dat
! Number of nested grids.
Ngrids = 1
NestLayers = 1
GridsInLayer = 1
! these parameters correctly.
Lm == 698 ! Number of I-direction INTERIOR RHO-points
Mm == 178 ! Number of J-direction INTERIOR RHO-points
N == 10 ! Number of vertical levels
NtileI == 2 ! I-direction partition
NtileJ == 2 ! J-direction partition
! Set horizontal and vertical advection schemes for active and inert
! tracers. A different advection scheme is allowed for each tracer.
! For example, a positive-definite (monotonic) algorithm can be activated
! for salinity and inert tracers, while a different one is set for
! temperature. [1:NAT+NPT,Ngrids] values are expected.
! Keyword Advection Algorithm
! A4 4th-order Akima (horizontal/vertical)
! C2 2nd-order centered differences (horizontal/vertical)
! C4 4th-order centered differences (horizontal/vertical)
! HSIMT 3th-order HSIMT-TVD (horizontal/vertical)
! MPDATA recursive flux corrected MPDATA (horizontal/vertical)
! SPLINES parabolic splines (only vertical)
! SU3 split third-order upstream (horizontal/vertical)
! U3 3rd-order upstream-biased (only horizontal)
! The user has the option of specifying the full Keyword or the first
! two letters, regardless if using uppercase or lowercase. If nested
! grids, specify values for each grid (see glossary below).
Hadvection == U3 \ ! temperature
U3 ! salinity
C4 ! salinity
! Adjoint-based algorithms can have different horizontal and schemes
! for active and inert tracers.
ad_Hadvection == U3 \ ! temperature
U3 ! salinity
C4 ! salinity
LBC(isFsur) == Clo Clo Cha Clo ! free-surface
LBC(isUbar) == Clo Clo Fla Clo ! 2D U-momentum
LBC(isVbar) == Clo Clo Fla Clo ! 2D V-momentum
LBC(isUvel) == Clo Clo Rad Clo ! 3D U-momentum
LBC(isVvel) == Clo Clo Rad Clo ! 3D V-momentum
LBC(isMtke) == Clo Clo Rad Clo ! mixing TKE
LBC(isTvar) == Clo Clo Rad Clo \ ! temperature
Clo Clo Rad Clo ! salinity
! conditions keywords.
ad_LBC(isFsur) == Per Clo Per Clo ! free-surface
Per Clo Per Clo ! salinity
! conservation, except if tidal forcing is enabled. [1:Ngrids].
VolCons(west) == F ! western boundary
! Time-Stepping parameters.
NTIMES == 25000
DT == 60.00
NDTFAST == 5.00
! Number of timesteps for computing observation impacts during the
! analysis-forecast cycle.
NTIMES_ANA == 720 ! analysis interval
NTIMES_FCT == 720 ! forecast interval
ERstr = 1
ERend = 1
Nouter = 1
Ninner = 1
Nintervals = 1
! Input/Output parameters.
NRREC == 0
LcycleRST == T
NRST == 30
NSTA == 1
NFLT == 1
NINFO == 1
! Output history, quicksave, average, and diagnostic files parameters.
LDEFOUT == T
NHIS == 10
NDEFHIS == 0
NQCK == 0
NDEFQCK == 0
NTSAVG == 1
NAVG == 30
NDEFAVG == 0
NTSDIA == 5
NDIA == 0
NDEFDIA == 0
LcycleTLM == F
NTLM == 720
NDEFTLM == 0
LcycleADJ == F
NADJ == 720
NDEFADJ == 0
NSFF == 720
NOBC == 720
! GST output and check pointing restart parameters.
LmultiGST = F ! one eigenvector per file
Ritz_tol = 1.0d-15
TNU2 == 0.0d0 0.0d0 ! m2/s
TNU4 == 2*0.0d0 ! m4/s
ad_TNU2 == 0.0d0 0.0d0 ! m2/s
ad_TNU4 == 0.0d0 0.0d0 ! m4/s
VISC2 == 0.001d0 ! m2/s
VISC4 == 0.0d0 ! m4/s
ad_VISC2 == 0.0d0 ! m2/s
ad_VISC4 == 0.0d0 ! m4/s
! Logical switches (TRUE/FALSE) to increase/decrease horizontal viscosity
! and/or diffusivity in specific areas of the application domain (like
! sponge areas) for the desired application grid.
LuvSponge == F ! horizontal momentum
LtracerSponge == F F ! temperature, salinity, inert
AKT_BAK == 5.0d-6 1.0d-6 ! m2/s
AKV_BAK == 5.0d-5 ! m2/s
! Upper threshold values to limit vertical mixing coefficients computed
! from vertical mixing parameterizations. Although this is an engineering
! fix, the vertical mixing values inferred from ocean observations are
! rarely higher than this upper limit value.
AKT_LIMIT == 1.0d-3 1.0d-3 ! m2/s
AKV_LIMIT == 1.0d-3 ! m2/s
AKK_BAK == 5.0d-6 ! m2/s
AKP_BAK == 5.0d-6 ! m2/s
TKENU2 == 0.0d0 ! m2/s
TKENU4 == 0.0d0 ! m4/s
GLS_P == 3.0d0 ! K-epsilon
GLS_M == 1.5d0
GLS_N == -1.0d0
GLS_Kmin == 7.6d-6
GLS_Pmin == 1.0d-12
GLS_CMU0 == 0.5477d0
GLS_C1 == 1.44d0
GLS_C2 == 1.92d0
GLS_C3M == -0.4d0
GLS_C3P == 1.0d0
GLS_SIGK == 1.0d0
GLS_SIGP == 1.30d0
CHARNOK_ALPHA == 1400.0d0 ! Charnok surface roughness
RDRG == 3.0d-04 ! m/s
RDRG2 == 1.0d-03 ! nondimensional
Zob == 0.02d0 ! m
Zos == 0.02d0 ! m
BLK_ZQ == 10.0d0 ! air humidity
BLK_ZT == 10.0d0 ! air temperature
BLK_ZW == 10.0d0 ! winds
! Minimum depth for wetting and drying.
DCRIT == 0.10d0 ! m
! Various parameters.
WTYPE == 1
LEVSFRC == 15
LEVBFRC == 1
Vtransform == 1 ! transformation equation
Vstretching == 1 ! stretching function
THETA_S == 1.0d0 ! surface stretching parameter
THETA_B == 1.0d0 ! bottom stretching parameter
TCLINE == 1.0d0 ! critical depth (m)
RHO0 = 1025.0d0 ! kg/m3
BVF_BAK = 1.0d-5 ! 1/s2
! NetCDF units attribute.
DSTART = 0.0d0 ! days
TIDE_START = 0.0d0 ! days
TIME_REF = 0.0d0 ! yyyymmdd.dd
! internally, [1:Ngrids].
TNUDG == 2*0.0d0 ! days
ZNUDG == 0.0d0 ! days
M2NUDG == 0.0d0 ! days
M3NUDG == 0.0d0 ! days
OBCFAC == 0.0d0 ! nondimensional
R0 == 1027.0d0 ! kg/m3
T0 == 14.0d0 ! Celsius
S0 == 35.0d0 ! nondimensional
TCOEF == 1.7d-4 ! 1/Celsius
SCOEF == 0.0d0 ! nondimensional
GAMMA2 == 1.0d0
! Logical switches (TRUE/FALSE) to activate horizontal momentum transport
! point Sources/Sinks (like river runoff transport) and mass point
! Sources/Sinks (like volume vertical influx), [1:Ngrids].
LuvSrc == F ! horizontal momentum transport
LtracerSrc == F F 12*F ! temperature, salinity, inert
! Logical switches (TRUE/FALSE) to read and process climatology fields.
! See glossary below for details.
LsshCLM == F ! sea-surface height
Lm2CLM == F ! 2D momentum
Lm3CLM == F ! 3D momentum
! Logical switches (TRUE/FALSE) to nudge the desired climatology field(s).
! If not analytical climatology fields, users need to turn ON the logical
! switches above to process the fields from the climatology NetCDF file
! that are needed for nudging. See glossary below for details.
LnudgeM2CLM == F ! 2D momentum
DstrS == 0.0d0 ! starting day
DendS == 0.0d0 ! ending day
KstrS == 1 ! starting level
KendS == 1 ! ending level
Lstate(isFsur) == F ! free-surface
Lstate(isTvar) == F F ! NT tracers
! Logical switches (TRUE/FALSE) to specify the state variables for
! which Forcing Singular Vectors or Stochastic Optimals is required.
Fstate(isFsur) == F ! free-surface
! Stochastic Optimals time decorrelation scale (days) assumed for
! red noise processes.
SO_decay == 2.0d0 ! days
! Stochastic Optimals surface forcing standard deviation for
! dimensionalization.
SO_sdev(isFsur) == 1.0d0 ! free-surface
SO_sdev(isUstr) == 1.0d0 ! surface U-stress
SO_sdev(isVstr) == 1.0d0 ! surface V-stress
SO_sdev(isTsur) == 1.0d0 1.0d0 ! NT surface tracers flux
! HISTORY output file.
Hout(idUvel) == T ! u 3D U-velocity
Hout(idTvar) == F F ! temp, salt temperature and salinity
Hout(idTair) == F ! Tair surface air temperature
! tracers other than biological and sediment tracers into the HISTORY
! output file. An inert passive tracer is one that it is only advected and
! diffused. Other processes are ignored. These tracers include, for example,
! dyes, pollutants, oil spills, etc. NPT values are expected. However, these
! switches can be activated using compact parameter specification.
Hout(inert) == F ! dye_01, ... inert passive tracers
NUSER = 1
USER = 1.d0
! Input and Output files processing library to use:
! [2] Serial or Parallel I/O with Parallel-IO (PIO) library (MPI only)
INP_LIB = 1
OUT_LIB = 1
! PIO library methods for reading/writing NetCDF files:
! [0] parallel read and write of PnetCDF (CDF-5, not recommended)
! [1] parallel read and write of NetCDF3 (64-bit offset)
! [2] serial read and write of NetCDF3 (64-bit offset)
! [4] parallel read and write of NETCDF4/HDF5
PIO_METHOD = 2
! PIO library MPI processes set-up:
PIO_IOTASKS = 2 ! number of I/O tasks to define
PIO_STRIDE = 1 ! stride in the MPI-ran between I/O tasks
PIO_BASE = 0 ! offset for the first I/O task
! PIO library rearranger methods for moving data between computational and I/O
! processes:
! [1] Box rearrangement
! [2] Subset rearrangement
PIO_REARR = 1
! PIO library rearranger flag for MPI communications between computational
! and I/O processes:
! [0] Point-to-Point (low-level communications)
! [1] Collective (high-level grouped communications)
PIO_REARRCOM = 0
! PIO library rearranger flow control direction flag for MPI communications
! between computational and I/O processes:
! [2] Enable computational to I/O processes only
! [3] Enable I/O to computational processes only
! [4] Disable flow control
PIO_REARRDIR = 2
! PIO rearranger options for computational to I/O processes (C2I):
PIO_C2I_HS = T ! Enable C2I handshake (T/F)
PIO_C2I_Send = T ! Enable C2I Isends (T/F)
PIO_C2I_Preq = 64 ! Maximum pending C2I requests
! PIO rearranger options for I/O to computational processes (I2C):
PIO_I2C_HS = T ! Enable I2C handshake (T/F)
GRDNAME == tidebore_grd.nc
ININAME == tidebore_ini.nc
ITLNAME ==
IRPNAME ==
IADNAME ==
FWDNAME ==
ADSNAME ==
FOInameA ==
FOInameB ==
FCTnameA ==
FCTnameB ==
NGCNAME =
NBCFILES == 1 ! number of boundary files
BRYNAME == tidebore_bry.nc
CLMNAME ==
NUDNAME ==
SSFNAME ==
TIDENAME == tidebore_tideforcing.nc
NFFILES == 1 ! number of unique forcing files
FRCNAME == tidebore_frc.nc ! forcing file 1, grid 1
DAINAME == tidebore_dai.nc
GSTNAME == tidebore_gst.nc
RSTNAME ==
HISNAME == tidebore_his.nc
QCKNAME == hzec_qck.nc
TLMNAME == hzec_tlm.nc
TLFNAME == hzec_tlf.nc
ADJNAME == hzec_adj.nc
AVGNAME == hzec_avg.nc
HARNAME == hzec_har.nc
DIANAME == hzec_dia.nc
STANAME == hzec_sta.nc
FLTNAME == hzec_flt.nc
APARNAM = s4dvar.in
SPOSNAM = stations.in
FPOSNAM = floats.in
BPARNAM = bio_Fennel.in
SPARNAM = sediment.in
USRNAME = MyFile.dat
smchen
Re: Roms can not write down the .rst file
#2 Unread post by smchen »
Try giving RSTNAME a filename.
zhqianj
#3 Unread post by zhqianj »
Thanks, I named rst filen as tidebore_rst.nc . and it still does not work.
the results says:
DEF_RST_NF90 - creating restart file, Grid 01: tidebore_rst.nc
Found Error: ** Line: 164 Source: ROMS/Utility/def_var.F, def_var_nf90
DEF_VAR_NF90 - Grid 01, unable to define variable:
in NetCDF file: tidebore_rst.nc
Found Error: 03 Line: 1050 Source: ROMS/Utility/def_rst.F, def_rst_nf90
Node # 0 CPU: 1.469
Total: 5.984
Average: 1.496
Minimum: 1.469
Maximum: 1.562
smchen
#4 Unread post by smchen »
I have no idea why your rst file has problems. Or just switch off the rst by setting NRST=0 to see if the model runs well to make sure the problems are rst files.
-- Shi-Ming
