typo in wrt_info.F
chuning
typo in wrt_info.F
#1 Unread post by chuning »
Found a typo in ROMS/Utility/wrt_info.F
line 3747
GRID_VARS : IF (FileH.eq.ABS(STA(ng)%pioFile&fh)) THEN
Should be
GRID_VARS : IF (FileH.eq.ABS(STA(ng)%pioFile%fh)) THEN
Re: typo in wrt_info.F
#2 Unread post by arango »
Those two lines are identical. The code compiles fine for me when STATIONS is activated or not.
chuning
#3 Unread post by chuning »
Hi Hernan,
arango wrote: Fri May 28, 2021 6:40 pm Those two lines are identical. The code compiles fine for me when STATIONS is activated or not.
Those two lines are not identical. The last & should be %. The whole code piece in wrt_info.F is
!  Write out grid tiled variables.
# ifdef NO_WRITE_GRID
      GRID_VARS : IF (FileH.eq.ABS(STA(ng)%pioFile&fh)) THEN <-- HERE
# else
      GRID_VARS : IF (FileH.ne.ABS(FLT(ng)%pioFile%fh)) THEN
Note that the IF statement in #else is FLT(ng)%pioFile%fh while the other IF statement is STA(ng)%pioFile&fh.
It will compile regardless of the STATION CPP option. The error occurs when I compiled with NO_WRITE_GRID and the new PIO_LIB, which I'm testing on a cluster.
By the way I pulled from the git repo, not svn, if that's going to make a difference.
Chuning
