Hi, everyone
I'm trying to use Roms_tools to create initial fields file, forcing fields file and climatology fields file as input files of ROMS3.0. As you known, some variables' name in Roms_tool are not the same in ROMS3.0. I have checked the codes in Preprocessing_tools of Roms_tools. I just found that the 'scrum_time' should be renamed as 'ocean_time' in 'create_inifile.m'. In the same file, the 'tstart' and 'tend' are not needed. And 'sc_w' and 'Cs_w' should be added. You could add following three line to calculate them :
sc_w = ((0:N)-N)/N;
Cs_w = (1.-theta_b)*cff1*sinh(theta_s*sc_w)...
+theta_b*(cff2*tanh(theta_s*(sc_w+0.5))-0.5);
If you found something more should be modified, please share with me.
By the way, some variables such as 'sustr' could be interpolated directly to the u (v,w) points instead of be interpolated to the rho points first.
