ROMS requires history file from the first run
d.kobashi
#1 Unread post by d.kobashi »
I am trying to run ROMS using the restart file; however, the model asked for a history file to run the model. I wonder if I can override the requirement.
               /scratch/user/d.kobashi/projects/hindcasts/projects/txla2/outputs/2010/ocean_his_parent_00011.nc
               call from:  ROMS/Utility/def_his.F
 Found Error: 03   Line: 4461     Source: ROMS/Utility/def_his.F
 DEF_HIS - unable to open history NetCDF file: /scratch/user/d.kobashi/projects/hindcasts/projects/txla2/outputs/2010/ocean_his_parent_00011.nc
 Found Error: 03   Line: 135      Source: ROMS/Nonlinear/output.F
 Found Error: 03   Line: 630      Source: ROMS/Nonlinear/main3d.F
 Found Error: 03   Line: 320      Source: ROMS/Drivers/nl_ocean.h
 Elapsed CPU time (seconds):
This is not a continuous run. I want to run a nesting model using the restart file I have already (for the parent grid only). I have a restart file for a period of 1 year with daily frequency. I extracted the data from my restart file for a specific date using NCO and used it as initial conditions. However, when I ran the model, the model asked for a history file. I guess the model tried to merge with the history file created in the past. But this is a new run so I don't want to merge the history file.
Is there any way to override the requirement of a history file? I use COAWST version 3.5 (the latest version I guess).
Thanks in advance,
-DJ
Re: ROMS requires history file from the first run
if it is a new run, then you should set nrrec = 0 (? right) so then it would not look for his11, instead it would create a new his1. ?
d.kobashi
#3 Unread post by d.kobashi »
John,
Thanks for your reply.
However, after the run with nrrec=0 as you suggested, I now have a new error as follows. It appears that ROMS cannot write time variable to the history file. The reason for the error is not a valid netcdf ID. Not sure why.
TIME-STEP YYYY-MM-DD hh:mm:ss.ss  KINETIC_ENRG   POTEN_ENRG    TOTAL_ENRG    NET_VOLUME  Grid
    163080 2010-06-01 00:00:00.00  1.063596E-02  7.785886E+03  7.785896E+03  1.202254E+14  01
                     (544,063,26)  2.304623E-02  3.820861E-02  0.000000E+00  8.926374E-01
 Found Error: **   Line: 6017     Source: ROMS/Modules/mod_netcdf.F, netcdf_put_fvar
 NETCDF_PUT_FVAR_1D - error while writing variable:  ocean_time
                      in input file:  /scratch/user/d.kobashi/projects/hindcasts/projects/txla2/outputs/2010/ocean_his_parent.nc
                      call from:  ROMS/Utility/wrt_his.F
 Found Error: 03   Line: 146      Source: ROMS/Utility/wrt_his.F
 Found Error: 03   Line: 170      Source: ROMS/Nonlinear/output.F
 REASON: NetCDF: Not a valid ID
#4 Unread post by jcwarner »
if it is a new run, why is time step 163080? what is dstart?
not sure.
d.kobashi
#5 Unread post by d.kobashi »
A good catch, John. There was a typo for dstart. Thanks for your help. -DJ
