Segmentation fault
- zzyfathead
Segmentation fault
I tried to run a easy case and met a segmentation fault. So I turned on the USER_DEBUG, the results show belows:
I tried to figured out the problem but still have no idea yet.
Hope anyone have met this problem. Thanks lol
- zzyfathead
Re: Segmentation fault
Friday - January 3, 2020 - 4:44:40 PM
test
test
Operating system : Linux
CPU/hardware : x86_64
Compiler system : gfortran
Compiler command : /usr/bin/mpif90
Compiler flags : -frepack-arrays -g -fbounds-check -I/usr/include -ffree-form -ffree-form
Input Script :
SVN Root URL : https:://myroms.org/svn/src
SVN Revision : 65M
Local Root : /home/ubuntu/app/COAWST_V3.2
Header Dir : /home/ubuntu/app/COAWST_V3.2/Projects/test
Header file : test.h
Analytical Dir: /home/ubuntu/app/COAWST_V3.2/Projects/test
Resolution, Grid 01: 0176x0279x025, Parallel Nodes: 1, Tiling: 001x001
24000 ntimes Number of timesteps for 3-D equations.
0.100 dt Timestep size (s) for 3-D equations.
10 ndtfast Number of timesteps for 2-D equations between
120 nRST Number of timesteps between the writing of data
into restart fields.
to standard output.
10 nHIS Number of timesteps between the writing fields
into history file.
time-averaged data.
360 nAVG Number of timesteps between the writing of
2.0000E-01 nl_tnu2(01) NLM Horizontal, harmonic mixing coefficient
(m2/s) for tracer 01: temp
2.0000E-01 nl_tnu2(02) NLM Horizontal, harmonic mixing coefficient
(m2/s) for tracer 02: salt
1.0000E-01 nl_visc2 NLM Horizontal, harmonic mixing coefficient
(m2/s) for momentum.
for tracer 02: salt
for turbulent energy.
0.000 wec_alpha WEC factor for roller/breaking energy distribution.
1.0000E-01 Dcrit Minimum depth for wetting and drying (m).
1 lmd_Jwt Jerlov water type.
6.0000E+00 theta_s S-coordinate surface control parameter.
4.0000E-01 theta_b S-coordinate bottom control parameter.
10.000 Tcline S-coordinate surface/bottom layer width (m) used
for tracer 02: salt
0.0000E+00 Tnudg_SSS Nudging/relaxation time scale (days)
for sea surface salinity.
for 3D momentum.
Output Restart File: test_rst.nc
Output History File: test_his.nc
Output Averages File: test_avg.nc
Input Grid File: /home/ubuntu/app/COAWST_V3.2/Projects/test/test_grid.nc
Input Nonlinear Initial File: /home/ubuntu/app/COAWST_V3.2/Projects/test/test_init.nc
Tile partition information for Grid 01: 0176x0279x0025 tiling: 001x001
tile Istr Iend Jstr Jend Npts
Number of tracers: 2
0 1 176 1 279 1227600
(interior points only)
tile Xmin Xmax Ymin Ymax grid
0 0.50 176.50 0.50 279.50 RHO-points
0 1.00 176.00 0.50 279.50 U-points
0 0.50 176.50 1.00 279.00 V-points
HaloSizeI(1) = 374
HaloSizeJ(1) = 578
TileSide(1) = 283
TileSize(1) = 51223
zeta 1 Closed Closed Closed Closed
ubar 1 Closed Closed Closed Closed
vbar 1 Closed Closed Closed Closed
u 1 Closed Closed Closed Closed
v 1 Closed Closed Closed Closed
temp 1 Closed Closed Closed Closed
salt 1 Closed Closed Closed Closed
tke 1 Closed Closed Closed Closed
TEST test
CHARNOK Charnok surface roughness from wind stress.
MASKING Land/Sea masking.
NONLINEAR Nonlinear Model.
SALINITY Using salinity.
UV_ADV Advection of momentum.
WET_DRY Wetting and drying activated.
Process Information:
Node # 0 (pid= 15904) is active.
25 0.0000000 0.0000000 0.000 0.000 0.000 0.000
24 -0.0400000 -0.0001749 -0.004 -0.201 -0.461 -0.538
23 -0.0800000 -0.0007098 -0.008 -0.404 -1.066 -1.368
22 -0.1200000 -0.0016353 -0.012 -0.608 -1.829 -2.516
21 -0.1600000 -0.0030046 -0.016 -0.815 -2.770 -4.025
20 -0.2000000 -0.0048963 -0.020 -1.024 -3.921 -5.960
19 -0.2400000 -0.0074189 -0.024 -1.237 -5.326 -8.407
18 -0.2800000 -0.0107165 -0.028 -1.454 -7.042 -11.485
17 -0.3200000 -0.0149770 -0.032 -1.675 -9.145 -15.347
16 -0.3600000 -0.0204424 -0.036 -1.902 -11.733 -20.189
15 -0.4000000 -0.0274214 -0.040 -2.137 -14.930 -26.262
14 -0.4400000 -0.0363057 -0.044 -2.382 -18.892 -33.886
13 -0.4800000 -0.0475899 -0.048 -2.638 -23.819 -43.462
12 -0.5200000 -0.0618955 -0.052 -2.909 -29.961 -55.497
11 -0.5600000 -0.0799996 -0.056 -3.200 -37.630 -70.622
10 -0.6000000 -0.1028685 -0.060 -3.514 -47.214 -89.623
9 -0.6400000 -0.1316956 -0.063 -3.858 -59.194 -113.473
8 -0.6800000 -0.1679410 -0.067 -4.240 -74.157 -143.358
7 -0.7200000 -0.2133714 -0.071 -4.667 -92.812 -180.716
6 -0.7600000 -0.2700910 -0.076 -5.150 -116.006 -227.259
5 -0.8000000 -0.3405555 -0.080 -5.703 -144.725 -284.985
4 -0.8400000 -0.4275481 -0.084 -6.338 -180.090 -356.158
3 -0.8800000 -0.5340940 -0.088 -7.070 -223.315 -443.241
2 -0.9200000 -0.6632759 -0.092 -7.916 -275.642 -548.740
1 -0.9600000 -0.8179050 -0.096 -8.890 -338.198 -674.944
0 -1.0000000 -1.0000000 -0.100 -10.000 -411.797 -823.494
Time Splitting Weights for Grid 01: ndtfast = 10 nfast = 15
1 0.0014850648765542 0.1000000000000000 0.0014850648765542 0.1000000000000000
2 0.0059386031399402 0.0998514935123446 0.0074236680164944 0.1998514935123445
3 0.0133457074936657 0.0992576331983506 0.0207693755101601 0.2991091267106951
4 0.0236484051180389 0.0979230624489840 0.0444177806281990 0.3970321891596791
5 0.0366959666818608 0.0955582219371801 0.0811137473100598 0.4925904110968592
6 0.0521753389587947 0.0918886252689940 0.1332890862688545 0.5844790363658532
7 0.0695217010484137 0.0866710913731145 0.2028107873172682 0.6711501277389678
8 0.0878091442019233 0.0797189212682732 0.2906199315191915 0.7508690490072409
9 0.1056214752525633 0.0709380068480808 0.3962414067717548 0.8218070558553218
10 0.1209031436506851 0.0603758593228245 0.5171445504224399 0.8821829151781463
11 0.1307902921035067 0.0482855449577560 0.6479348425259466 0.9304684601359023
12 0.1314219308195445 0.0352065157474053 0.7793567733454911 0.9656749758833076
13 0.1177312353577226 0.0220643226654509 0.8970880087032138 0.9877392985487585
14 0.0832169680811588 0.0102911991296786 0.9803049767843727 0.9980304976784371
15 0.0196950232156274 0.0019695023215627 1.0000000000000000 0.9999999999999999
ndtfast, nfast = 10 15 nfast/ndtfast = 1.50000
1.000000000000 1.083803072626 0.541901536313 1.000000000000 1.000000000000
Power filter parameters, Fgamma, gamma = 0.28400 0.00000
Minimum X-grid spacing, DXmin = 1.00256452E-01 km
Maximum X-grid spacing, DXmax = 1.00262565E-01 km
Minimum Y-grid spacing, DYmin = 9.95247380E-02 km
Maximum Y-grid spacing, DYmax = 9.95366015E-02 km
Minimum Z-grid spacing, DZmin = 3.96056923E-03 m
Maximum Z-grid spacing, DZmax = 1.48550344E+02 m
Minimum barotropic Courant Number = 3.66827761E-04
Maximum barotropic Courant Number = 1.27240519E-02
Maximum Coriolis Courant Number = 2.26677842E-07
(Grid 01, File: test_init.nc, Rec=0001, Index=1)
- free-surface
- u-momentum component
- v-momentum component
- potential temperature
(Min = 2.00000000E+01 Max = 2.00000000E+01)
- salinity
(Min = 3.50000000E+01 Max = 3.50000000E+01)
At line 101 of file get_data.f90
Fortran runtime error: Index '1' of dimension 2 of array 'frc' above upper bound of 0
Error termination. Backtrace:
[b]#0 0x7ff3e1bdf2da in ???
#1 0x7ff3e1bdfec5 in ???
#2 0x7ff3e1be0297 in ???
#3 0x555ef59c8e30 in get_data_
at /home/ubuntu/app/COAWST_V3.2/Build/get_data.f90:101
#4 0x555ef59c5c3e in initial_
at /home/ubuntu/app/COAWST_V3.2/Build/initial.f90:296
#5 0x555ef57bfbbd in __ocean_control_mod_MOD_roms_initialize
at /home/ubuntu/app/COAWST_V3.2/Build/ocean_control.f90:131
#6 0x555ef57bec15 in ocean
at /home/ubuntu/app/COAWST_V3.2/Build/master.f90:95
#7 0x555ef57bede1 in main
at /home/ubuntu/app/COAWST_V3.2/Build/master.f90:50[/b]
Primary job terminated normally, but 1 process returned
a non-zero exit code.. Per user-direction, the job has been aborted.
mpirun detected that one or more processes exited with non-zero status, thus causing
the job to be terminated. The first process to do so was:
Process name: [[1340,1],0]
Exit code: 2
What is on this line?
Oops, didn't see this:at /home/ubuntu/app/COAWST_V3.2/Build/get_data.f90:101
Did you tell it NFFILES before the list of forcing files?Fortran runtime error: Index '1' of dimension 2 of array 'frc' above upper bound of 0
- zzyfathead
Hi Kate,kate wrote: Fri Jan 03, 2020 5:32 pm What is on this line?Oops, didn't see this:at /home/ubuntu/app/COAWST_V3.2/Build/get_data.f90:101Did you tell it NFFILES before the list of forcing files?Fortran runtime error: Index '1' of dimension 2 of array 'frc' above upper bound of 0
Thanks for your reply.
I don't want to input any forcing file, so I use '!' to comment out the code, as shown in the figure below. And the problem happend.
Then I delete '!' and change this code to 'NFFILES=0' , but ROMS told me NFFILES must be greater than 1.
I wonder that if it's necessay to input forcing files.
Thanks!
- 20200104144825.png (9.69 KiB) Viewed 9913 times
- zzyfathead
zzyfathead wrote: Sat Jan 04, 2020 6:57 amHi Kate,kate wrote: Fri Jan 03, 2020 5:32 pm What is on this line?Oops, didn't see this:at /home/ubuntu/app/COAWST_V3.2/Build/get_data.f90:101Did you tell it NFFILES before the list of forcing files?Fortran runtime error: Index '1' of dimension 2 of array 'frc' above upper bound of 0
I don't want to input any forcing file, so I use '!' to comment out the code, as shown in the figure below. And the problem happened.
I wonder that if it's necessay to input forcing files (Because I don't want to do that).
Thanks!
Well, you could try submitting a bug report for this case of no forcing files, but most of us just set NFFILES to 1 and move on.
- zzyfathead
Katekate wrote: Sat Jan 04, 2020 7:34 am Well, you could try submitting a bug report for this case of no forcing files, but most of us just set NFFILES to 1 and move on.
Thanks for your reply, you really help me out! So people usually input at least one forcing file, my case is not common.
By the way, where can I submit a bug report?
If you log into: https://www.myroms.org/projects/src you can submit a bug report.
This is not a bug. It always has to be equal or greater than one by design. If no input forcing files are needed, ROMS will ignore those values on standard input. I don't understand what it is the Fuzz about it. There are a lot of parameters in ROMS standard input that will be only relevant for a specific configuration. If not, they will be IGNORED!
NFFILES is needed to allocate an internal ROMS structure and initialize several parameters even if it is not used.
- zzyfathead
Thanks, I set NFFILES = 1 and input forcing file(though values = 0), it works now.arango wrote: Sat Jan 04, 2020 7:35 pm This is not a bug. It always has to be equal or greater than one by design. If no input forcing files are needed, ROMS will ignore those values on standard input. I don't understand what it is the Fuzz about it. There are a lot of parameters in ROMS standard input that will be only relevant for a specific configuration. If not, they will be IGNORED!
