problems with the addition of tide forcing
Hello everyone
I'm using lake_signel as a test of starting.
I created a file of tidal forcing.
on my PC works perfectly but does not work on the cluster.
this is the problem and .h files
31 106.50 212.50 195.50 208.00 V-points
HaloSizeI(1) = 357
HaloSizeJ(1) = 81
TileSide(1) = 113
TileSize(1) = 2373
CREUS Cape Creus Test Case
MASKING Land/Sea masking.
NONLINEAR Nonlinear Model.
NORTHERN_WALL Wall boundary at Northern edge.
SALINITY Using salinity.
SOUTHERN_WALL Wall boundary at Southern edge.
TCLIMATOLOGY Processing tracer climatology data.
TCLM_NUDGING Nudging toward tracer climatology.
THREE_GHOST Using three Ghost Points in halo regions.
UV_ADV Advection of momentum.
UV_COR Coriolis term.
CHECKDEFS - no bottom stress formulation is selected.
Node # 25 (pid= 19121) is active.
Elapsed CPU time (seconds):
Node # 0 CPU: 0.036
Node # 2 CPU: 0.100
Node # 1 CPU: 0.096
Node # 4 CPU: 0.100
Node # 10 CPU: 0.100
Node # 3 CPU: 0.072
Node # 6 CPU: 0.076
Node # 16 CPU: 0.096
Node # 18 CPU: 0.096
Node # 8 CPU: 0.100
Node # 17 CPU: 0.096
Node # 7 CPU: 0.100
Node # 21 CPU: 0.016
Node # 9 CPU: 0.100
Node # 20 CPU: 0.068
Node # 22 CPU: 0.096
Node # 12 CPU: 0.100
Node # 26 CPU: 0.092
Node # 5 CPU: 0.096
Node # 11 CPU: 0.100
Node # 23 CPU: 0.096
Node # 24 CPU: 0.096
Node # 14 CPU: 0.108
Node # 29 CPU: 0.096
Node # 27 CPU: 0.096
Node # 13 CPU: 0.056
Node # 28 CPU: 0.096
Node # 15 CPU: 0.100
Node # 31 CPU: 0.096
Node # 19 CPU: 0.076
Node # 30 CPU: 0.088
Node # 25 CPU: 0.072
Total: 2.812
Total: 0.000 0.0000
Message Passage: data broadcast .................. 0.104 ( 3.6986 %)
Total: 0.104 3.6986
All percentages are with respect to total time = 2.812
#define TS_MPDATA
#define SPLINES
#if defined AVERAGES && defined BEDLOAD
# define AVERAGES_BEDLOAD
#undef FLOATS
#define NORTHERN_WALL
#define SOUTHERN_WALL
#define WESTERN_WALL
#define RADIATION_2D
#define EAST_M3RADIATION
#define EAST_TRADIATION
#define EAST_FSCHAPMAN
#define ANA_FSOBC
#define EAST_M2FLATHER
#define ANA_M2OBC
#define FSBOC REDUCED
#define UV_TIDES
#define SSH_TIDES
#undef MB_BBL
#undef SG_BBL
#undef SSW_BBL
#ifdef SG_BBL
#ifdef SG_BBL
# define SG_CALC_ZNOT
# undef SG_LOGINT
#ifdef MB_BBL
# define MB_CALC_ZNOT
# undef MB_Z0BIO
# undef MB_Z0BL
# undef MB_Z0RIP
#ifdef SSW_BBL
# define SSW_CALC_ZNOT
# undef SSW_LOGINT
#if defined MB_BBL || defined SG_BBL || defined SSW_BBL
# define ANA_WWAVE
#undef SEDIMENT
#ifdef SEDIMENT
# define SUSPLOAD
# define BEDLOAD_SOULSBY
# undef SED_MORPH
#if defined SEDIMENT || defined SG_BBL || defined MB_BBL || defined SSW_BBL
# define ANA_SEDIMENT
#ifdef MASKING
# undef ANA_MASK
#undef ANA_GRID
#undef ANA_INITIAL
#undef ANA_TCLIMA
#define TCLIMATOLOGY
#undef M3CLIMATOLOGY
#define TCLM_NUDGING
#define ANA_SMFLUX
#define ANA_STFLUX
#define ANA_SSFLUX
#define ANA_BPFLUX
#define ANA_SPFLUX
#define ANA_SRFLUX
/* define one vertical mixing scheme here*/
#undef ANA_VMIX
#undef MY25_MIXING
#define GLS_MIXING
# undef CRAIG_BANNER
# undef CHARNOK
you have any ideas???
best regards
HaloSizeI(1) = 357
HaloSizeJ(1) = 81
TileSide(1) = 113
TileSize(1) = 2373
Node # 0 CPU: 0.036
Node # 2 CPU: 0.100
Node # 1 CPU: 0.096
Node # 4 CPU: 0.100
Node # 3 CPU: 0.072
Node # 6 CPU: 0.076
Node # 8 CPU: 0.100
Node # 7 CPU: 0.100
Node # 9 CPU: 0.100
Node # 5 CPU: 0.096
Total: 2.812
Total: 0.000 0.0000
Total: 0.104 3.6986
#define TS_MPDATA
#define SPLINES
#undef FLOATS
#define ANA_FSOBC
#define ANA_M2OBC
#define UV_TIDES
#define SSH_TIDES
#undef MB_BBL
#undef SG_BBL
#undef SSW_BBL
#ifdef SG_BBL
#ifdef SG_BBL
# undef SG_LOGINT
#ifdef MB_BBL
# undef MB_Z0BIO
# undef MB_Z0BL
# undef MB_Z0RIP
#ifdef SSW_BBL
# undef SSW_LOGINT
# define ANA_WWAVE
#undef SEDIMENT
#ifdef SEDIMENT
# define SUSPLOAD
# undef SED_MORPH
#ifdef MASKING
# undef ANA_MASK
#undef ANA_GRID
#undef ANA_INITIAL
#undef ANA_TCLIMA
#define ANA_SMFLUX
#define ANA_STFLUX
#define ANA_SSFLUX
#define ANA_BPFLUX
#define ANA_SPFLUX
#define ANA_SRFLUX
#undef ANA_VMIX
#undef MY25_MIXING
#define GLS_MIXING
# undef CHARNOK
best regards
Re: problems with the addition of tide forcing
See above error message. You need to give the formulation which caculates the bottom stress.CHECKDEFS - no bottom stress formulation is selected.
In ROMS, we have logarithmic, Linear and Quadratic bottom friction formulation.
Those are UV_LOGDRAG, UV_LDRAG and UV_QDAG respectively in cppdefs.h.
You can choose any of them but only one need to be specified.
-Peter
Joonho Lee
Sorry but may I ask where to specify.susonic wrote: ↑Mon Apr 26, 2010 1:20 amSee above error message. You need to give the formulation which caculates the bottom stress.CHECKDEFS - no bottom stress formulation is selected.
-Peter
Which case are you trying to run? I suggest starting with a proven case like UPWELLING. There is an upwelling.h file containing the cppdefs for that case.
inlet_test.h has SSW_BBL defined, which should satisfy that bottom drag condition.
** svn $Id: inlet_test.h 939 2019-01-28 07:02:47Z arango $
** Copyright (c) 2002-2019 The ROMS/TOMS Group **
** See License_ROMS.txt **
** Options for Inlet Test Case, waves-ocean (SWAN/ROMS) two-way coupling.
** Application flag: INLET_TEST
** Input script: roms_inlet_test.in
** coupling_inlet_test.in
** sediment_inlet_test.in
#define SPLINES_VDIFF
#define SPLINES_VVISC
#define TS_MPDATA
#define ANA_INITIAL
#define ANA_SMFLUX
#define ANA_FSOBC
#define ANA_M2OBC
#ifdef SSW_BBL
#ifdef SOLVE3D
# define GLS_MIXING
# ifdef GLS_MIXING
# define RI_SPLINES
# define SEDIMENT
# ifdef SEDIMENT
# define SUSPLOAD
# define SED_MORPH
# if defined SEDIMENT || defined SG_BBL || defined MB_BBL || defined SSW_BBL
here is my inlet_test.h, I have tried to add #define SSW_BBL but seems nothing is being improved.
You're missing parts of that file - where did you get it from? How did that even compile, since it is missing an ending #endif or two?
For the problem you are seeing, before the #ifdef SSW_BBL bit, there should be:
/* define only one of the following 5 */
#undef UV_LOGDRAG
#undef UV_QDRAG
#undef MB_BBL
#undef SG_BBL
#define SSW_BBL
I have updated my ROMS version but now another error come out.kate wrote: ↑Tue Oct 29, 2019 5:48 pm You're missing parts of that file - where did you get it from? How did that even compile, since it is missing an ending #endif or two?
For the problem you are seeing, before the #ifdef SSW_BBL bit, there should be:/* define only one of the following 5 */
#undef UV_LOGDRAG
#undef UV_QDRAG
#undef MB_BBL
#undef SG_BBL
#define SSW_BBL
- log.txt
- (268.56 KiB) Downloaded 272 times
There are errors and warnings coming from SWAN. Is this from COAWST or not?
