ad passive tracer
thaitlhp
Location: Ha Noi University Sience and Technology, Vietnam
ad passive tracer
#1 Unread post by thaitlhp »
i'm trying ad passive tracer for upwelling test case step by step following:
viewtopic.php?f=14&t=2611
i added dye_01 in rst.nc and set ININAME= rst.nc then i set NPT = 1
but when i run uwelling.in i get this:
mpirun -np 3 ./romsM roms_upwelling.in
Thursday - May 23, 2019 - 1:16:02 PM
At line 2008 of file mod_ncparam.f90
Fortran runtime error: End of record
Error termination. Backtrace:
What is this error?
#0 0x7f54f7ed22da in ???
#1 0x7f54f7ed2ec5 in ???
#2 0x7f54f7ed368d in ???
#3 0x7f54f8049060 in ???
#4 0x7f54f80549e9 in ???
#5 0x7f54f804c2cc in ???
#6 0x7f54f804c46c in ???
#7 0x5643a8ed4552 in ???
#8 0x5643a8ce7c71 in ???
#9 0x5643a8c85a39 in ???
#10 0x5643a8c81fd4 in ???
#11 0x5643a8c818de in ???
#12 0x5643a8c8164e in ???
#13 0x7f54f7749b96 in ???
#14 0x5643a8c816a9 in ???
#15 0xffffffffffffffff in ???
Primary job terminated normally, but 1 process returned
a non-zero exit code.. Per user-direction, the job has been aborted.
#0 0x7f6c4b0a02da in ???
#1 0x7f6c4b0a0ec5 in ???
#2 0x7f6c4b0a168d in ???
#3 0x7f6c4b217060 in ???
#4 0x7f6c4b2229e9 in ???
#5 0x7f6c4b21a2cc in ???
#6 0x7f6c4b21a46c in ???
#7 0x5583bb66b552 in ???
#8 0x5583bb47ec71 in ???
#9 0x5583bb41ca39 in ???
#10 0x5583bb418fd4 in ???
#11 0x5583bb4188de in ???
#12 0x5583bb41864e in ???
#13 0x7f6c4a917b96 in ???
#14 0x5583bb4186a9 in ???
#0 0x7ff523fea2da in ???
#1 0x7ff523feaec5 in ???
#2 0x7ff523feb68d in ???
#3 0x7ff524161060 in ???
#4 0x7ff52416c9e9 in ???
#5 0x7ff5241642cc in ???
#6 0x7ff52416446c in ???
#7 0x55dd42f1d552 in ???
#8 0x55dd42d30c71 in ???
#9 0x55dd42ccea39 in ???
#10 0x55dd42ccafd4 in ???
#11 0x55dd42cca8de in ???
#12 0x55dd42cca64e in ???
#13 0x7ff523861b96 in ???
#14 0x55dd42cca6a9 in ???
mpirun detected that one or more processes exited with non-zero status, thus causing
the job to be terminated. The first process to do so was:
Process name: [[64664,1],1]
Exit code: 2
what is
upwelling.h
(1.73 KiB) Downloaded 473 times
Re: ad passive tracer
You've got one clue here:
Can you tell us what is at line 2008 of your mod_ncparam.f90 file?
What is NRREC in your roms.in file? The restart file is not necessarily the same as a file needed for initialization, especially when you go changing settings.
thaitlhp
#3 Unread post by thaitlhp »
kate wrote:You've got one clue here:
thanks for your reply!
now, i don't use perfect_restart, i set NRREC == 0 run again and get:
At line 1860 of file mod_ncparam.f90
my mod_ncparam.f90 here
mod_ncparam.f90
(84.08 KiB) Downloaded 426 times
thaitlhp
#4 Unread post by thaitlhp »
my input file
roms_upwelling.in
(132.31 KiB) Downloaded 422 times
thaitlhp
#5 Unread post by thaitlhp »
my header file
Looking forward to your help! :D :D :D :D
upwelling.h
(1.09 KiB) Downloaded 442 times
#6 Unread post by wilkin »
Your roms_upwelling.in has 4 passive tracers, not one. You have set NPT=4.
Your roms_upwelling.in has also set "closed" as the options for open boundary conditions on passive tracers:
   LBC(isTvar) ==   Per     Clo     Per     Clo \       ! temperature
                    Per     Clo     Per     Clo \
Clo     Clo     Clo     Clo \
Clo     Clo     Clo     Clo \
Clo     Clo     Clo     Clo \        ! salinity
		    Clo     Clo     Clo     Clo
when that should be periodic to match the active tracers.
You have options I don't recognize like ANA_PTOBC. Who's code are you using? It's not the default myroms.org code.
For these test purposes I think you could perhaps set initial values with ANA_PASSIVE and avoid creating the netcdf file until you get started.
I see you have AGE_MEAN. So you need to think carefully about initializing and forcing. Set a pair of age at initialization only will simply give you a patch of uniformly aging water.
thaitlhp
#7 Unread post by thaitlhp »
wilkin wrote:Your roms_upwelling.in has 4 passive tracers, not one. You have set NPT=4.
                    Per     Clo     Per     Clo \
Clo     Clo     Clo     Clo \
Clo     Clo     Clo     Clo \
		    Clo     Clo     Clo     Clo
Thank you very much for your suggestion! first i ran with NPT=1, after i tried with NPT=4,from
  Per     Clo     Per     Clo
to
   Clo     Clo     Clo     Clo
, all case get problem with mod_ncparam.F
about ANA_PTOBC Define for analytic passive tracer boundary conditions i read it in roms_manual.
where can i get ad passive tracer suggestion more clearly? forgive me, my English skill is still bad!I have been learning about ROMS for 1 year but My knowledge of ROMS is still small! thank all!
#8 Unread post by kate »
Which mod_ncparam.f90 error are you getting and what is on the line number in question? We want you to look at the file. Maybe you should also explain exactly what it is you want to do with your passive tracer.
thaitlhp
#9 Unread post by thaitlhp »
kate wrote:Which mod_ncparam.f90 error are you getting and what is on the line number in question? We want you to look at the file. Maybe you should also explain exactly what it is you want to do with your passive tracer.
Thank Kate!
      SELECT CASE (Vinfo(1))
              CASE ('tracer2')
                varid=varid-1
                DO i=1,MT
                  varid=varid+1
                  idTTav(i)=varid
                  DO ng=1,Ngrids
                    Fscale(varid,ng)=scale
                    Iinfo(1,varid,ng)=gtype
                  WRITE (Vname(1,varid),'(a,a)')                        &
     &                  TRIM(ADJUSTL(Vname(1,idTvar(i)))), '_2'
                  WRITE (Vname(2,varid),'(a,1x,a)')                     &
     &                  'time-averaged squared',                        &
     &                  TRIM(ADJUSTL(Vname(2,idTvar(i))))
                  IF (TRIM(ADJUSTL(Vname(3,idTvar(i)))).eq.             &
     &                'nondimensional') THEN
                    WRITE (Vname(3,varid),'(a)')                        &
     &                    TRIM(ADJUSTL(Vname(3,idTvar(i))))
                  ELSE
                    WRITE (Vname(3,varid),'(a,a)')                      &
     &                    TRIM(ADJUSTL(Vname(3,idTvar(i)))), '2'
                  WRITE (Vname(4,varid),'(a,a)')                        &
     &                  TRIM(Vname(1,varid)), ', scalar, series'
                  WRITE (Vname(5,varid),'(a)')                          &
     &                  TRIM(ADJUSTL(Vinfo(5)))
I want ad Radioactive function of Cs-137 with passive tracer. But first, i need understand how passive tracer work so i set default in ana_passive.h and looking for dye in output file.
:D :D :D
ana_passive.h
(3.35 KiB) Downloaded 418 times
#10 Unread post by kate »
Are you by chance asking for Aout(idTTav)? I have never done so and can't guarantee that it would work.
heroh2o
#11 Unread post by heroh2o »
I'm trying to add a passive tracer in upwelling test case, and I have the same problem.
If I edit passive tracer part of “varinfo.dat” file, it shows:
At line 1904 of file mod_ncparam.f90
If I use the original “varinfo.dat” file, it shows:
Fortran runtime error: shape and target do not conform
Have you solved your problem?
I need some suggestion.Thanks!
