BLOWING UP during nesting
haili
#1 Unread post by haili »
I run a coarse resolution case successfully, I would like to choose a small area of the case area to study the phenomenon of multi-layer nesting in the area.
But now only 2 layers nesting failed.
I do not know the reason.
I created the refine grid file with the Matlab code coarse2fine.
I extracted the refine initial file with the Matlab code d_roms2roms.
My refine tidal forcing files was interpolated from the coarse tidal forcing file.
The ngbay_ngc_2g_ab.nc was generated using the script contact.m.
Other forcing files are the same with the coarse case.
However at the first step the nesting case blow_up :cry: .
What I have already done:
1. check nan of the initial file and the tidal forcing file.
2. decrease the time steps 'dt' from 15 to 1
3. turn off the tidal forcing
Thank you for your help!
Best
Haili
7200 ntimes Number of timesteps for 3-D equations.
15.000 dt Timestep size (s) for 3-D equations.
15 ndtfast Number of timesteps for 2-D equations between
480 nRST Number of timesteps between the writing of data
into restart fields.
to standard output.
360 nSTA Number of timesteps between the writing of data
the stations file.
0 nHIS Number of timesteps between the writing fields
into history file.
into quicksave file.
time-averaged data.
480 nAVG Number of timesteps between the writing of
5760 ndefAVG Number of timesteps between creation of new
time-averaged file.
(m2/s) for tracer 01: temp
(m2/s) for tracer 02: salt
2.0000E+00 nl_visc2 NLM Horizontal, harmonic mixing coefficient
(m2/s) for momentum.
5.0000E-06 Akt_bak(02) Background vertical mixing coefficient (m2/s)
for tracer 02: salt
for turbulent energy.
1.0000E+01 blk_ZQ Height (m) of surface air humidity measurement.
1.0000E+01 blk_ZT Height (m) of surface air temperature measurement.
1.0000E+01 blk_ZW Height (m) of surface winds measurement.
1.0000E+00 theta_s S-coordinate surface control parameter.
1.0000E+00 theta_b S-coordinate bottom control parameter.
3.000 Tcline S-coordinate surface/bottom layer width (m) used
20060101.00 time_ref Reference time for units attribute (yyyymmdd.dd)
for tracer 02: salt
for 3D momentum.
1.5000E+01 obcfac Factor between passive and active
T Aout(idDano) Write out averaged density anomaly.
Output Restart File: /users/hwang121/scratch/ngbayhlnestingfile/output/ocean_rst.nc
Prefix for Averages Files: /users/hwang121/scratch/ngbayhlnestingfile/output/ocean_avg
Output Stations File: /users/hwang121/scratch/ngbayhlnestingfile/output/ocean_sta.nc
Input Grid File: /users/hwang121/roms/ngbay/Projects/ngbayfiles/coarseinput/ngbay_grd.nc
Nesting grid connectivity File: /users/hwang121/scratch/smallinput/ngbay_ngc_2g_ab.nc
Input Nonlinear Initial File: /users/hwang121/roms/ngbay/Projects/ngbayfiles/coarseinput/osom_grid4_mindep_smlp_mod7_ini_hydro.nc
Tidal Forcing File: /users/hwang121/roms/ngbay/Projects/ngbayfiles/coarseinput/osom_grid4_mindep_smlp_mod6_tidalforcing_2006.nc
Input Forcing File 01: /users/hwang121/roms/ngbay/Projects/ngbayfiles/coarseinput/frc_wind_field_OSOM_2006_new.nc
Input Forcing File 02: /users/hwang121/roms/ngbay/Projects/ngbayfiles/coarseinput/frc_bulk8_point_osom_2006.nc
Station positions File: /users/hwang121/data/hwang121/stations_osom_nesting.in
Resolution, Grid 02: 0900x1212x015, Parallel Nodes: 64, Tiling: 008x008
Physical Parameters, Grid: 02
108000 ntimes Number of timesteps for 3-D equations.
1.000 dt Timestep size (s) for 3-D equations.
to standard output.
the stations file.
into history file.
time-averaged data.
time-averaged file.
for tracer 02: salt
for tracer 02: salt
for 3D momentum.
Output Restart File: /users/hwang121/scratch/ngbayhlnestingfile/output/oceanhl_rst.nc
Prefix for Averages Files: /users/hwang121/scratch/ngbayhlnestingfile/output/oceanhl_avg
Input Grid File: /users/hwang121/scratch/smallinput/ngbay_grd_fine1.nc
Input Nonlinear Initial File: /users/hwang121/scratch/smallinput/ngbay_grd_ini.nc
GET_GRID - angle between XI-axis and EAST: angler
(Grid = 01, File: /users/hwang121/roms/ngbay/Projects/ngbayfiles/coarseinput/ngbay_grd.nc)
(Min = -5.73923922E-01 Max = 9.08638297E-01)
GET_GRID - reciprocal XI-grid spacing: pm
(Min = 2.29508154E-03 Max = 2.46946401E-02)
GET_GRID - reciprocal ETA-grid spacing: pn
(Min = 2.57345733E-03 Max = 3.66368034E-02)
GET_GRID - XI-derivative of inverse metric factor pn: dndx
(Min = -6.22353037E+00 Max = 1.29465657E+01)
GET_GRID - ETA-derivative of inverse metric factor pm: dmde
(Min = -1.37933839E+00 Max = 2.00305560E+01)
GET_GRID - Coriolis parameter at RHO-points: f
(Min = 9.47308397E-05 Max = 9.79166886E-05)
GET_GRID - bathymetry at RHO-points: h
(Min = 2.00000000E+00 Max = 1.12145151E+02)
GET_GRID - x-location of RHO-points: x-rho
(Min = -8.08048205E+06 Max = -7.78230926E+06)
GET_GRID - y-location of RHO-points: y_rho
(Min = 4.93464274E+06 Max = 5.18168211E+06)
GET_GRID - x-location of PSI-points: x_psi
(Min = -8.08034114E+06 Max = -7.78241485E+06)
GET_GRID - y-location of PSI-points: y-psi
(Min = 4.93490009E+06 Max = 5.18150523E+06)
GET_GRID - x-location of U-points: x_u
(Min = -8.08038301E+06 Max = -7.78236657E+06)
GET_GRID - y-location of U-points: y_u
(Min = 4.93464257E+06 Max = 5.18157942E+06)
GET_GRID - x-location of V-points: x_v
(Min = -8.08044156E+06 Max = -7.78235475E+06)
GET_GRID - y-location of V-points: y_v
(Min = 4.93490036E+06 Max = 5.18160159E+06)
GET_GRID - longitude of RHO-points: lon_rho
GET_GRID - latitude of RHO-points lat_rho
GET_GRID - longitude of PSI-points: lon_psi
(Min = -7.26635975E+01 Max = -6.99866847E+01)
GET_GRID - latitude of PSI-points lat_psi
(Min = 4.05088007E+01 Max = 4.21724345E+01)
GET_GRID - longitude of U-points: lon_u
(Min = -7.26639628E+01 Max = -6.99862328E+01)
GET_GRID - latitude of U-points: lat_u
(Min = 4.05071487E+01 Max = 4.21728490E+01)
GET_GRID - longitude of V-points: lon_v
(Min = -7.26650402E+01 Max = -6.99855448E+01)
GET_GRID - latitude of V-points: lat_v
(Min = 4.05088013E+01 Max = 4.21737681E+01)
GET_GRID - mask on RHO-points: mask_rho
(Min = 0.00000000E+00 Max = 1.00000000E+00)
GET_GRID - mask on PSI-points: mask_psi
GET_GRID - mask on U-points: mask_u
GET_GRID - mask on V-points: mask_v
(Grid = 02, File: /users/hwang121/scratch/smallinput/ngbay_grd_fine1.nc)
(Min = 9.39339461E-02 Max = 4.88527516E-01)
(Min = 2.04210158E-02 Max = 5.53111842E-02)
(Min = 2.34795268E-02 Max = 4.06173068E-02)
(Min = -1.49524133E-03 Max = 1.36560555E-02)
(Min = -1.72030760E-02 Max = -1.14129901E-02)
(Min = 9.65207017E-05 Max = 9.73545733E-05)
(Min = -1.65801391E+00 Max = 5.26751124E+01)
(Min = -7.95159584E+06 Max = -7.89327807E+06)
(Min = 5.08543749E+06 Max = 5.14402907E+06)
(Min = -7.95157715E+06 Max = -7.89331918E+06)
(Min = 5.08546640E+06 Max = 5.14400415E+06)
(Min = -7.95157754E+06 Max = -7.89330716E+06)
(Min = 5.08544056E+06 Max = 5.14401638E+06)
(Min = -7.95159545E+06 Max = -7.89329009E+06)
(Min = 5.08546333E+06 Max = 5.14401684E+06)
(Min = -7.14921368E+01 Max = -7.10528888E+01)
(Min = 4.14386890E+01 Max = 4.18767854E+01)
(Min = -7.14921482E+01 Max = -7.10527933E+01)
(Min = 4.14384986E+01 Max = 4.18768933E+01)
(Min = -7.14922510E+01 Max = -7.10526126E+01)
(Min = 4.14386717E+01 Max = 4.18768473E+01)
(Min = 0.00000000E+00 Max = 2.00000000E+00)
15 0.0000000 0.0000000 0.000 0.000 0.000 0.000
14 -0.0666667 -0.0064624 -0.085 -0.110 -0.540 -0.901
13 -0.1333333 -0.0257201 -0.181 -0.239 -1.775 -3.199
12 -0.2000000 -0.0573871 -0.286 -0.386 -3.682 -6.852
11 -0.2666667 -0.1008307 -0.401 -0.551 -6.227 -11.792
10 -0.3333333 -0.1551864 -0.524 -0.733 -9.365 -17.924
9 -0.4000000 -0.2193793 -0.656 -0.929 -13.035 -25.130
8 -0.4666667 -0.2921503 -0.794 -1.138 -17.171 -33.273
7 -0.5333333 -0.3720885 -0.938 -1.358 -21.696 -42.199
6 -0.6000000 -0.4576670 -1.086 -1.587 -26.526 -51.741
5 -0.6666667 -0.5472830 -1.238 -1.821 -31.575 -61.724
4 -0.7333333 -0.6393009 -1.391 -2.059 -36.755 -71.969
3 -0.8000000 -0.7320964 -1.546 -2.298 -41.976 -82.299
2 -0.8666667 -0.8241010 -1.699 -2.536 -47.155 -92.543
1 -0.9333333 -0.9138456 -1.851 -2.771 -52.211 -102.540
0 -1.0000000 -1.0000000 -2.000 -3.000 -57.073 -112.145
Vertical S-coordinate System, Grid 02:
14 -0.0666667 -0.0064624 0.234 -0.110 -0.326 -0.511
13 -0.1333333 -0.0257201 0.442 -0.239 -0.945 -1.660
12 -0.2000000 -0.0573871 0.624 -0.386 -1.847 -3.428
11 -0.2666667 -0.1008307 0.782 -0.551 -3.017 -5.782
10 -0.3333333 -0.1551864 0.918 -0.733 -4.437 -8.680
9 -0.4000000 -0.2193793 1.033 -0.929 -6.081 -12.068
8 -0.4666667 -0.2921503 1.131 -1.138 -7.921 -15.884
7 -0.5333333 -0.3720885 1.215 -1.358 -9.924 -20.057
6 -0.6000000 -0.4576670 1.286 -1.587 -12.056 -24.512
5 -0.6666667 -0.5472830 1.350 -1.821 -14.281 -29.167
4 -0.7333333 -0.6393009 1.408 -2.059 -16.560 -33.942
3 -0.8000000 -0.7320964 1.466 -2.298 -18.857 -38.756
2 -0.8666667 -0.8241010 1.524 -2.536 -21.136 -43.530
1 -0.9333333 -0.9138456 1.587 -2.771 -23.363 -48.192
0 -1.0000000 -1.0000000 1.658 -3.000 -25.509 -52.675
Time Splitting Weights for Grid 01: ndtfast = 15 nfast = 22
1-0.0006740978872509 0.0666666666666667-0.0006740978872509 0.0666666666666667
2-0.0001913161153518 0.0667116065258167-0.0008654140026027 0.1333782731924834
3 0.0014472038369421 0.0667243609335069 0.0005817898343395 0.2001026341259903
4 0.0042370228855824 0.0666278806777107 0.0048188127199218 0.2667305148037010
5 0.0081665994120431 0.0663454124853385 0.0129854121319649 0.3330759272890396
6 0.0132119623624627 0.0658009725245357 0.0261973744944276 0.3988768998135752
7 0.0193298623751124 0.0649201750337048 0.0455272368695400 0.4637970748472801
8 0.0264494009361902 0.0636315175420307 0.0719766378057303 0.5274285923893107
9 0.0344621375639418 0.0618682241462847 0.1064387753696720 0.5892968165355954
10 0.0432106750211074 0.0595707483086885 0.1496494503907794 0.6488675648442840
11 0.0524757225556949 0.0566900366406147 0.2021251729464743 0.7055576014848987
12 0.0619616371700794 0.0531916551369017 0.2640868101165537 0.7587492566218004
13 0.0712804429184289 0.0490608793255631 0.3353672530349826 0.8078101359473635
14 0.0799343282324558 0.0443088497976678 0.4153015812674384 0.8521189857450313
15 0.0872966212754959 0.0389798945821708 0.5025982025429343 0.8910988803272021
16 0.0925912433249121 0.0331601198304711 0.5951894458678464 0.9242590001576731
17 0.0948706401828253 0.0269873702754769 0.6900600860506717 0.9512463704331501
18 0.0929921916151718 0.0206626609299552 0.7830522776658435 0.9719090313631054
19 0.0855930988190858 0.0144631814889438 0.8686453764849293 0.9863722128520491
20 0.0710637499186094 0.0087569749010047 0.9397091264035388 0.9951291877530538
21 0.0475195634887281 0.0040193915730974 0.9872286898922669 0.9991485793261512
22 0.0127713101077333 0.0008514206738489 1.0000000000000002 1.0000000000000000
ndtfast, nfast = 15 22 nfast/ndtfast = 1.46667
1.000000000000 1.070450639131 0.535225319565 1.000000000000 1.000000000000
Power filter parameters, Fgamma, gamma = 0.28400 0.09467
Time Splitting Weights for Grid 02: ndtfast = 15 nfast = 22
Minimum X-grid spacing, DXmin = 4.04946174E-02 km
Maximum X-grid spacing, DXmax = 3.56382138E-01 km
Minimum Y-grid spacing, DYmin = 2.72949578E-02 km
Maximum Y-grid spacing, DYmax = 3.88582312E-01 km
Minimum Z-grid spacing, DZmin = 8.51699402E-02 m
Maximum Z-grid spacing, DZmax = 1.03302185E+01 m
Minimum barotropic Courant Number = 4.20343636E-02
Maximum barotropic Courant Number = 2.97002616E-01
Maximum Coriolis Courant Number = 1.46019263E-03
Horizontal mixing scaled by grid size, GRDMAX = 3.23731774E-01 km
Metrics information for Grid 02:
Minimum X-grid spacing, DXmin = 1.80523345E-02 km
Maximum X-grid spacing, DXmax = 4.91059154E-02 km
Minimum Y-grid spacing, DYmin = 2.45584637E-02 km
Maximum Y-grid spacing, DYmax = 4.26169539E-02 km
Minimum Z-grid spacing, DZmin = -2.33860479E-01 m
Maximum Z-grid spacing, DZmax = 4.81384947E+00 m
Minimum barotropic Courant Number = 8.72759390E-03
Maximum barotropic Courant Number = 5.95826250E-02
Maximum Coriolis Courant Number = 9.72995226E-05
Horizontal mixing scaled by grid size, GRDMAX = 4.55502426E-02 km
Refined Nested Grid(s) Information:
Refined Donor Refined Timestep Refined
Grid Grid Scale Ratio Timesteps
02 01 03 15.00000 15
WARNING: Usually the number of Refined Timesteps must be the same
as the Refined Scale for numerical stability.
NLM: GET_STATE - Reading state initial conditions, 2006-01-01 00:00:00.00
(Grid 01, t = 0.0000, File: osom_grid4_mindep_smlp_mod7_ini_hydro.nc, Rec=0001, Index=1)
- free-surface
- u-momentum component
- v-momentum component
- potential temperature
(Min = 4.56679989E+00 Max = 1.23957848E+01)
- salinity
(Min = 3.09659979E-09 Max = 3.36493083E+01)
(Grid 02, t = 0.0000, File: ngbay_grd_ini.nc, Rec=0001, Index=1)
- free-surface
(Min = 5.98502991E+00 Max = 8.41852708E+00)
- salinity
(Min = 0.00000000E+00 Max = 3.17598902E+01)
GET_NGFLD - tidal period
(Grid = 01, Min = 1.49047214E+04 Max = 9.67260838E+04)
(Grid = 01, Min = 0.00000000E+00 Max = 7.54251636E-01)
(Grid = 01, Min = 6.26773407E-06 Max = 6.28318498E+00)
(Grid = 01, Min = 0.00000000E+00 Max = 3.14159244E+00)
(Grid = 01, Min = 0.00000000E+00 Max = 6.28318364E+00)
(Grid = 01, Min = 0.00000000E+00 Max = 1.49311554E+00)
(Grid = 01, Min = -3.37066252E-01 Max = 2.52296461E-01)
GET_2DFLD - surface u-wind component, 2005-12-31 23:00:00.00
(Grid=01, Rec=0000001, Index=1, File: frc_wind_field_OSOM_2006_new.nc)
(Tmin= -0.0417 Tmax= 365.0000) t = -0.0417
(Min = -4.81854172E+00 Max = -1.58071958E+00) regrid = T
GET_2DFLD - surface v-wind component, 2005-12-31 23:00:00.00
(Min = -2.42937271E+00 Max = 1.13576238E+00) regrid = T
GET_2DFLD - surface air pressure, 2006-01-01 00:00:00.00
(Grid=01, Rec=0000001, Index=1, File: frc_bulk8_point_osom_2006.nc)
(Tmin= 0.0000 Tmax= 365.0000) t = 0.0000
(Min = 1.00983752E+03 Max = 1.00983752E+03) regrid = F
GET_2DFLD - solar shortwave radiation flux, 2006-01-01 00:00:00.00
(Min = 8.57305843E-13 Max = 8.57305843E-13) regrid = F
GET_2DFLD - downwelling longwave radiation flux, 2006-01-01 00:00:00.00
(Min = 7.64574591E-05 Max = 7.64574591E-05) regrid = F
GET_2DFLD - surface air temperature, 2006-01-01 00:00:00.00
(Min = 3.75000000E-01 Max = 3.75000000E-01) regrid = F
GET_2DFLD - surface air relative humidity, 2006-01-01 00:00:00.00
(Min = 9.24499969E-01 Max = 9.24499969E-01) regrid = F
GET_2DFLD - rain fall rate, 2006-01-01 00:00:00.00
(Min = 1.17592590E-05 Max = 1.17592590E-05) regrid = F
(Grid=02, Rec=0000001, Index=1, File: frc_wind_field_OSOM_2006_new.nc)
(Min = -3.84400734E+00 Max = -2.83434620E+00) regrid = T
(Min = -2.09210197E+00 Max = -4.23612321E-01) regrid = T
(Grid=02, Rec=0000001, Index=1, File: frc_bulk8_point_osom_2006.nc)
Maximum grid stiffness ratios: rx0 = 6.848054E-01 (Beckmann and Haidvogel)
rx1 = 1.568418E+01 (Haney)
Initial domain volumes: TotVolume = 6.2370483442E+11 m3
MinCellVol = 3.4037041132E+02 m3
MaxCellVol = 6.8561716618E+05 m3
Max/Min = 2.0143265789E+03
Basin information for Grid 02:
Maximum grid stiffness ratios: rx0 = 2.592861E-01 (Beckmann and Haidvogel)
rx1 = 6.109278E+00 (Haney)
Initial domain volumes: TotVolume = 3.4468096079E+09 m3
MinCellVol = 4.2938854899E+01 m3
MaxCellVol = 6.6263574929E+03 m3
Max/Min = 1.5432077796E+02
NL ROMS/TOMS: started time-stepping: (Grid: 01 TimeSteps: 000000000001 - 000000007200)
NL ROMS/TOMS: started time-stepping: (Grid: 02 TimeSteps: 000000000001 - 000000108000)
GET_2DFLD - surface u-wind component, 2006-01-01 00:00:00.00
(Grid=01, Rec=0000002, Index=2, File: frc_wind_field_OSOM_2006_new.nc)
(Tmin= -0.0417 Tmax= 365.0000) t = 0.0000
GET_2DFLD - surface v-wind component, 2006-01-01 00:00:00.00
GET_2DFLD - surface air pressure, 2006-01-01 03:00:00.00
(Grid=01, Rec=0000002, Index=2, File: frc_bulk8_point_osom_2006.nc)
(Tmin= 0.0000 Tmax= 365.0000) t = 0.1250
(Min = 1.00822778E+03 Max = 1.00822778E+03) regrid = F
GET_2DFLD - solar shortwave radiation flux, 2006-01-01 03:00:00.00
GET_2DFLD - downwelling longwave radiation flux, 2006-01-01 03:00:00.00
(Min = 7.66043529E-05 Max = 7.66043529E-05) regrid = F
GET_2DFLD - surface air temperature, 2006-01-01 03:00:00.00
(Min = 8.00000012E-01 Max = 8.00000012E-01) regrid = F
GET_2DFLD - surface air relative humidity, 2006-01-01 03:00:00.00
(Min = 9.20000000E-01 Max = 9.20000000E-01) regrid = F
GET_2DFLD - rain fall rate, 2006-01-01 03:00:00.00
TIME-STEP YYYY-MM-DD hh:mm:ss.ss KINETIC_ENRG POTEN_ENRG TOTAL_ENRG NET_VOLUME Grid
0 2006-01-01 00:00:00.00 0.000000E+00 2.254681E+02 2.254681E+02 6.480027E+11 01
(000,0000,00) 0.000000E+00 0.000000E+00 0.000000E+00 0.000000E+00
DEF_AVG - creating average file, Grid 01: /users/hwang121/scratch/ngbayhlnestingfile/output/ocean_avg_0001.nc
DEF_STATION - creating stations file, Grid 01: /users/hwang121/scratch/ngbayhlnestingfile/output/ocean_sta.nc
(Grid=02, Rec=0000002, Index=2, File: frc_wind_field_OSOM_2006_new.nc)
(Grid=02, Rec=0000002, Index=2, File: frc_bulk8_point_osom_2006.nc)
0 2006-01-01 00:00:00.00 0.000000E+00 5.118196E+01 5.118196E+01 4.990846E+09 02
DEF_AVG - creating average file, Grid 02: /users/hwang121/scratch/ngbayhlnestingfile/output/oceanhl_avg_0001.nc
DEF_STATION - creating stations file, Grid 02: /users/hwang121/scratch/ngbayhlnestingfile/output/ocean_sta.nc
GET_2DFLD - surface u-wind component, 2006-01-01 01:00:00.00
(Grid=02, Rec=0000003, Index=1, File: frc_wind_field_OSOM_2006_new.nc)
(Tmin= -0.0417 Tmax= 365.0000) t = 0.0417
(Min = -6.39545228E+00 Max = -4.19266902E+00) regrid = T
GET_2DFLD - surface v-wind component, 2006-01-01 01:00:00.00
(Min = -1.92643796E+00 Max = -9.67419191E-01) regrid = T
1 2006-01-01 00:00:01.00 NaN NaN NaN NaN 02
(402,1077,01) 4.900151E-05 1.821114E-05 0.000000E+00 1.578565E-03
Found Error: 01 Line: 302 Source: ROMS/Nonlinear/main3d.F
Found Error: 01 Line: 274 Source: ROMS/Drivers/nl_ocean.h
WRT_RST - wrote re-start fields (Index=1,1) in record = 0000001 01
Kosa
Re: BLOWING UP during nesting
#2 Unread post by Kosa »
1. Is that your full output file? Where are the lateral boundary conditions and C-preprocessing options etc.?
2. What is your grid refinement factor? This should dictate your DT. E.g. if it is 3x refined, it's typical to use a 1/3 smaller DT for the refined grid (so 3 s instead of 15 s). I don't know whether this would help with your NaNs on the first timestep though.
3. I would start with the simplest possible scenario and add complexity one piece at a time. Analytical initial conditions, no atmospheric forcing, no rivers, no tides, etc.
haili
#3 Unread post by haili »
Kosa wrote:1. Is that your full output file? Where are the lateral boundary conditions and C-preprocessing options etc.?
Thank you for your reply.
1. This is not my full output file, because the limit number of the characters.
2. my grid refinement factor is 3, but I have changed the time step to 1/3 smaller than the coarse one. the result did not change.
3. Yeah, we should start from the simplest one , but the boundary and the forcing files have already succeed for the coarse one. I only added the initial condition, the tidal forcing and the contact files for the refined grid.
the following part is the output file:
## SLURM PROLOG ###############################################################
## Job ID : 2931264
## Job Name : laketest
## Nodelist : node[445-447,453]
## CPUs : 64
## Mem/Node : 30720 MB
## Directory : /gpfs/scratch/hwang121/ngbaynestingngc
## Started : Sun Mar 3 22:49:24 EST 2019
Laketest case started in parallel
Sunday - March 3, 2019 - 10:49:26 PM
NGBAY nesting grids
Operating system : Linux
CPU/hardware : x86_64
Compiler system : ifort
Compiler command : /gpfs/runtime/opt/mpi/mvapich2-2.3a_intel/bin/mpif90
Compiler flags : -heap-arrays -fp-model precise -ip -O3 -free -free
Input Script : ngbay_case56hl.in
SVN Revision :
Local Root : /gpfs/data/bfoxkemp/hwang121/trunk
Header Dir : /users/hwang121/scratch/ngbaynestingngc
Header file : ngbay.h
Analytical Dir: /users/hwang121/scratch/ngbaynestingngc
Resolution, Grid 01: 0998x1098x015, Parallel Nodes: 64, Tiling: 008x008
to standard output.
the stations file.
into history file.
time-averaged data.
time-averaged file.
for tracer 02: salt
for tracer 02: salt
for 3D momentum.
to standard output.
the stations file.
into history file.
time-averaged data.
time-averaged file.
for tracer 02: salt
for tracer 02: salt
for 3D momentum.
Output Stations File: /users/hwang121/scratch/ngbayhlnestingfile/output/oceanhl_sta.nc
Input Nonlinear Initial File: /users/hwang121/scratch/smallinput/ngbay_ini.nc
Tile partition information for Grid 01: 0998x1098x0015 tiling: 008x008
tile Istr Iend Jstr Jend Npts
0 1 124 1 135 251100
1 125 249 1 135 253125
2 250 374 1 135 253125
3 375 499 1 135 253125
4 500 624 1 135 253125
5 625 749 1 135 253125
6 750 874 1 135 253125
7 875 998 1 135 251100
8 1 124 136 273 256680
9 125 249 136 273 258750
10 250 374 136 273 258750
11 375 499 136 273 258750
12 500 624 136 273 258750
13 625 749 136 273 258750
14 750 874 136 273 258750
15 875 998 136 273 256680
16 1 124 274 411 256680
17 125 249 274 411 258750
18 250 374 274 411 258750
19 375 499 274 411 258750
20 500 624 274 411 258750
21 625 749 274 411 258750
22 750 874 274 411 258750
23 875 998 274 411 256680
24 1 124 412 549 256680
25 125 249 412 549 258750
26 250 374 412 549 258750
27 375 499 412 549 258750
28 500 624 412 549 258750
29 625 749 412 549 258750
30 750 874 412 549 258750
31 875 998 412 549 256680
32 1 124 550 687 256680
33 125 249 550 687 258750
34 250 374 550 687 258750
35 375 499 550 687 258750
36 500 624 550 687 258750
37 625 749 550 687 258750
38 750 874 550 687 258750
39 875 998 550 687 256680
40 1 124 688 825 256680
41 125 249 688 825 258750
42 250 374 688 825 258750
43 375 499 688 825 258750
44 500 624 688 825 258750
45 625 749 688 825 258750
46 750 874 688 825 258750
47 875 998 688 825 256680
48 1 124 826 963 256680
49 125 249 826 963 258750
50 250 374 826 963 258750
51 375 499 826 963 258750
52 500 624 826 963 258750
53 625 749 826 963 258750
54 750 874 826 963 258750
55 875 998 826 963 256680
56 1 124 964 1098 251100
57 125 249 964 1098 253125
58 250 374 964 1098 253125
59 375 499 964 1098 253125
60 500 624 964 1098 253125
61 625 749 964 1098 253125
62 750 874 964 1098 253125
63 875 998 964 1098 251100
Tile partition information for Grid 02: 0900x1212x0015 tiling: 008x008
0 1 111 1 150 249750
1 112 224 1 150 254250
2 225 337 1 150 254250
3 338 450 1 150 254250
4 451 563 1 150 254250
5 564 676 1 150 254250
6 677 789 1 150 254250
7 790 900 1 150 249750
8 1 111 151 302 253080
9 112 224 151 302 257640
10 225 337 151 302 257640
11 338 450 151 302 257640
12 451 563 151 302 257640
13 564 676 151 302 257640
14 677 789 151 302 257640
15 790 900 151 302 253080
16 1 111 303 454 253080
17 112 224 303 454 257640
18 225 337 303 454 257640
19 338 450 303 454 257640
20 451 563 303 454 257640
21 564 676 303 454 257640
22 677 789 303 454 257640
23 790 900 303 454 253080
24 1 111 455 606 253080
25 112 224 455 606 257640
26 225 337 455 606 257640
27 338 450 455 606 257640
28 451 563 455 606 257640
29 564 676 455 606 257640
30 677 789 455 606 257640
31 790 900 455 606 253080
32 1 111 607 758 253080
33 112 224 607 758 257640
34 225 337 607 758 257640
35 338 450 607 758 257640
36 451 563 607 758 257640
37 564 676 607 758 257640
38 677 789 607 758 257640
39 790 900 607 758 253080
40 1 111 759 910 253080
41 112 224 759 910 257640
42 225 337 759 910 257640
43 338 450 759 910 257640
44 451 563 759 910 257640
45 564 676 759 910 257640
46 677 789 759 910 257640
47 790 900 759 910 253080
48 1 111 911 1062 253080
49 112 224 911 1062 257640
50 225 337 911 1062 257640
51 338 450 911 1062 257640
52 451 563 911 1062 257640
53 564 676 911 1062 257640
54 677 789 911 1062 257640
55 790 900 911 1062 253080
56 1 111 1063 1212 249750
57 112 224 1063 1212 254250
58 225 337 1063 1212 254250
59 338 450 1063 1212 254250
60 451 563 1063 1212 254250
61 564 676 1063 1212 254250
62 677 789 1063 1212 254250
63 790 900 1063 1212 249750
(interior points only)
tile Xmin Xmax Ymin Ymax grid
0 0.50 124.50 0.50 135.50 RHO-points
1 124.50 249.50 0.50 135.50 RHO-points
2 249.50 374.50 0.50 135.50 RHO-points
3 374.50 499.50 0.50 135.50 RHO-points
4 499.50 624.50 0.50 135.50 RHO-points
5 624.50 749.50 0.50 135.50 RHO-points
6 749.50 874.50 0.50 135.50 RHO-points
7 874.50 998.50 0.50 135.50 RHO-points
8 0.50 124.50 135.50 273.50 RHO-points
9 124.50 249.50 135.50 273.50 RHO-points
10 249.50 374.50 135.50 273.50 RHO-points
11 374.50 499.50 135.50 273.50 RHO-points
12 499.50 624.50 135.50 273.50 RHO-points
13 624.50 749.50 135.50 273.50 RHO-points
14 749.50 874.50 135.50 273.50 RHO-points
15 874.50 998.50 135.50 273.50 RHO-points
16 0.50 124.50 273.50 411.50 RHO-points
17 124.50 249.50 273.50 411.50 RHO-points
18 249.50 374.50 273.50 411.50 RHO-points
19 374.50 499.50 273.50 411.50 RHO-points
20 499.50 624.50 273.50 411.50 RHO-points
21 624.50 749.50 273.50 411.50 RHO-points
22 749.50 874.50 273.50 411.50 RHO-points
23 874.50 998.50 273.50 411.50 RHO-points
24 0.50 124.50 411.50 549.50 RHO-points
25 124.50 249.50 411.50 549.50 RHO-points
26 249.50 374.50 411.50 549.50 RHO-points
27 374.50 499.50 411.50 549.50 RHO-points
28 499.50 624.50 411.50 549.50 RHO-points
29 624.50 749.50 411.50 549.50 RHO-points
30 749.50 874.50 411.50 549.50 RHO-points
31 874.50 998.50 411.50 549.50 RHO-points
32 0.50 124.50 549.50 687.50 RHO-points
33 124.50 249.50 549.50 687.50 RHO-points
34 249.50 374.50 549.50 687.50 RHO-points
35 374.50 499.50 549.50 687.50 RHO-points
36 499.50 624.50 549.50 687.50 RHO-points
37 624.50 749.50 549.50 687.50 RHO-points
38 749.50 874.50 549.50 687.50 RHO-points
39 874.50 998.50 549.50 687.50 RHO-points
40 0.50 124.50 687.50 825.50 RHO-points
41 124.50 249.50 687.50 825.50 RHO-points
42 249.50 374.50 687.50 825.50 RHO-points
43 374.50 499.50 687.50 825.50 RHO-points
44 499.50 624.50 687.50 825.50 RHO-points
45 624.50 749.50 687.50 825.50 RHO-points
46 749.50 874.50 687.50 825.50 RHO-points
47 874.50 998.50 687.50 825.50 RHO-points
48 0.50 124.50 825.50 963.50 RHO-points
49 124.50 249.50 825.50 963.50 RHO-points
50 249.50 374.50 825.50 963.50 RHO-points
51 374.50 499.50 825.50 963.50 RHO-points
52 499.50 624.50 825.50 963.50 RHO-points
53 624.50 749.50 825.50 963.50 RHO-points
54 749.50 874.50 825.50 963.50 RHO-points
55 874.50 998.50 825.50 963.50 RHO-points
56 0.50 124.50 963.50 1098.50 RHO-points
57 124.50 249.50 963.50 1098.50 RHO-points
58 249.50 374.50 963.50 1098.50 RHO-points
59 374.50 499.50 963.50 1098.50 RHO-points
60 499.50 624.50 963.50 1098.50 RHO-points
61 624.50 749.50 963.50 1098.50 RHO-points
62 749.50 874.50 963.50 1098.50 RHO-points
63 874.50 998.50 963.50 1098.50 RHO-points
0 1.00 124.50 0.50 135.50 U-points
1 124.50 249.50 0.50 135.50 U-points
2 249.50 374.50 0.50 135.50 U-points
3 374.50 499.50 0.50 135.50 U-points
4 499.50 624.50 0.50 135.50 U-points
5 624.50 749.50 0.50 135.50 U-points
6 749.50 874.50 0.50 135.50 U-points
7 874.50 998.00 0.50 135.50 U-points
8 1.00 124.50 135.50 273.50 U-points
9 124.50 249.50 135.50 273.50 U-points
10 249.50 374.50 135.50 273.50 U-points
11 374.50 499.50 135.50 273.50 U-points
12 499.50 624.50 135.50 273.50 U-points
13 624.50 749.50 135.50 273.50 U-points
14 749.50 874.50 135.50 273.50 U-points
15 874.50 998.00 135.50 273.50 U-points
16 1.00 124.50 273.50 411.50 U-points
17 124.50 249.50 273.50 411.50 U-points
18 249.50 374.50 273.50 411.50 U-points
19 374.50 499.50 273.50 411.50 U-points
20 499.50 624.50 273.50 411.50 U-points
21 624.50 749.50 273.50 411.50 U-points
22 749.50 874.50 273.50 411.50 U-points
23 874.50 998.00 273.50 411.50 U-points
24 1.00 124.50 411.50 549.50 U-points
25 124.50 249.50 411.50 549.50 U-points
26 249.50 374.50 411.50 549.50 U-points
27 374.50 499.50 411.50 549.50 U-points
28 499.50 624.50 411.50 549.50 U-points
29 624.50 749.50 411.50 549.50 U-points
30 749.50 874.50 411.50 549.50 U-points
31 874.50 998.00 411.50 549.50 U-points
32 1.00 124.50 549.50 687.50 U-points
33 124.50 249.50 549.50 687.50 U-points
34 249.50 374.50 549.50 687.50 U-points
35 374.50 499.50 549.50 687.50 U-points
36 499.50 624.50 549.50 687.50 U-points
37 624.50 749.50 549.50 687.50 U-points
38 749.50 874.50 549.50 687.50 U-points
39 874.50 998.00 549.50 687.50 U-points
40 1.00 124.50 687.50 825.50 U-points
41 124.50 249.50 687.50 825.50 U-points
42 249.50 374.50 687.50 825.50 U-points
43 374.50 499.50 687.50 825.50 U-points
44 499.50 624.50 687.50 825.50 U-points
45 624.50 749.50 687.50 825.50 U-points
46 749.50 874.50 687.50 825.50 U-points
47 874.50 998.00 687.50 825.50 U-points
48 1.00 124.50 825.50 963.50 U-points
49 124.50 249.50 825.50 963.50 U-points
50 249.50 374.50 825.50 963.50 U-points
51 374.50 499.50 825.50 963.50 U-points
52 499.50 624.50 825.50 963.50 U-points
53 624.50 749.50 825.50 963.50 U-points
54 749.50 874.50 825.50 963.50 U-points
55 874.50 998.00 825.50 963.50 U-points
56 1.00 124.50 963.50 1098.50 U-points
57 124.50 249.50 963.50 1098.50 U-points
58 249.50 374.50 963.50 1098.50 U-points
59 374.50 499.50 963.50 1098.50 U-points
60 499.50 624.50 963.50 1098.50 U-points
61 624.50 749.50 963.50 1098.50 U-points
62 749.50 874.50 963.50 1098.50 U-points
63 874.50 998.00 963.50 1098.50 U-points
0 0.50 124.50 1.00 135.50 V-points
1 124.50 249.50 1.00 135.50 V-points
2 249.50 374.50 1.00 135.50 V-points
3 374.50 499.50 1.00 135.50 V-points
4 499.50 624.50 1.00 135.50 V-points
5 624.50 749.50 1.00 135.50 V-points
6 749.50 874.50 1.00 135.50 V-points
7 874.50 998.50 1.00 135.50 V-points
8 0.50 124.50 135.50 273.50 V-points
9 124.50 249.50 135.50 273.50 V-points
10 249.50 374.50 135.50 273.50 V-points
11 374.50 499.50 135.50 273.50 V-points
12 499.50 624.50 135.50 273.50 V-points
13 624.50 749.50 135.50 273.50 V-points
14 749.50 874.50 135.50 273.50 V-points
15 874.50 998.50 135.50 273.50 V-points
16 0.50 124.50 273.50 411.50 V-points
17 124.50 249.50 273.50 411.50 V-points
18 249.50 374.50 273.50 411.50 V-points
19 374.50 499.50 273.50 411.50 V-points
20 499.50 624.50 273.50 411.50 V-points
21 624.50 749.50 273.50 411.50 V-points
22 749.50 874.50 273.50 411.50 V-points
23 874.50 998.50 273.50 411.50 V-points
24 0.50 124.50 411.50 549.50 V-points
25 124.50 249.50 411.50 549.50 V-points
26 249.50 374.50 411.50 549.50 V-points
27 374.50 499.50 411.50 549.50 V-points
28 499.50 624.50 411.50 549.50 V-points
29 624.50 749.50 411.50 549.50 V-points
30 749.50 874.50 411.50 549.50 V-points
31 874.50 998.50 411.50 549.50 V-points
32 0.50 124.50 549.50 687.50 V-points
33 124.50 249.50 549.50 687.50 V-points
34 249.50 374.50 549.50 687.50 V-points
35 374.50 499.50 549.50 687.50 V-points
36 499.50 624.50 549.50 687.50 V-points
37 624.50 749.50 549.50 687.50 V-points
38 749.50 874.50 549.50 687.50 V-points
39 874.50 998.50 549.50 687.50 V-points
40 0.50 124.50 687.50 825.50 V-points
41 124.50 249.50 687.50 825.50 V-points
42 249.50 374.50 687.50 825.50 V-points
43 374.50 499.50 687.50 825.50 V-points
44 499.50 624.50 687.50 825.50 V-points
45 624.50 749.50 687.50 825.50 V-points
46 749.50 874.50 687.50 825.50 V-points
47 874.50 998.50 687.50 825.50 V-points
48 0.50 124.50 825.50 963.50 V-points
49 124.50 249.50 825.50 963.50 V-points
50 249.50 374.50 825.50 963.50 V-points
51 374.50 499.50 825.50 963.50 V-points
52 499.50 624.50 825.50 963.50 V-points
53 624.50 749.50 825.50 963.50 V-points
54 749.50 874.50 825.50 963.50 V-points
55 874.50 998.50 825.50 963.50 V-points
56 0.50 124.50 963.50 1098.00 V-points
57 124.50 249.50 963.50 1098.00 V-points
58 249.50 374.50 963.50 1098.00 V-points
59 374.50 499.50 963.50 1098.00 V-points
60 499.50 624.50 963.50 1098.00 V-points
61 624.50 749.50 963.50 1098.00 V-points
62 749.50 874.50 963.50 1098.00 V-points
63 874.50 998.50 963.50 1098.00 V-points
Tile minimum and maximum fractional coordinates for Grid 02:
0 0.50 111.50 0.50 150.50 RHO-points
1 111.50 224.50 0.50 150.50 RHO-points
2 224.50 337.50 0.50 150.50 RHO-points
3 337.50 450.50 0.50 150.50 RHO-points
4 450.50 563.50 0.50 150.50 RHO-points
5 563.50 676.50 0.50 150.50 RHO-points
6 676.50 789.50 0.50 150.50 RHO-points
7 789.50 900.50 0.50 150.50 RHO-points
8 0.50 111.50 150.50 302.50 RHO-points
9 111.50 224.50 150.50 302.50 RHO-points
10 224.50 337.50 150.50 302.50 RHO-points
11 337.50 450.50 150.50 302.50 RHO-points
12 450.50 563.50 150.50 302.50 RHO-points
13 563.50 676.50 150.50 302.50 RHO-points
14 676.50 789.50 150.50 302.50 RHO-points
15 789.50 900.50 150.50 302.50 RHO-points
16 0.50 111.50 302.50 454.50 RHO-points
17 111.50 224.50 302.50 454.50 RHO-points
18 224.50 337.50 302.50 454.50 RHO-points
19 337.50 450.50 302.50 454.50 RHO-points
20 450.50 563.50 302.50 454.50 RHO-points
21 563.50 676.50 302.50 454.50 RHO-points
22 676.50 789.50 302.50 454.50 RHO-points
23 789.50 900.50 302.50 454.50 RHO-points
24 0.50 111.50 454.50 606.50 RHO-points
25 111.50 224.50 454.50 606.50 RHO-points
26 224.50 337.50 454.50 606.50 RHO-points
27 337.50 450.50 454.50 606.50 RHO-points
28 450.50 563.50 454.50 606.50 RHO-points
29 563.50 676.50 454.50 606.50 RHO-points
30 676.50 789.50 454.50 606.50 RHO-points
31 789.50 900.50 454.50 606.50 RHO-points
32 0.50 111.50 606.50 758.50 RHO-points
33 111.50 224.50 606.50 758.50 RHO-points
34 224.50 337.50 606.50 758.50 RHO-points
35 337.50 450.50 606.50 758.50 RHO-points
36 450.50 563.50 606.50 758.50 RHO-points
37 563.50 676.50 606.50 758.50 RHO-points
38 676.50 789.50 606.50 758.50 RHO-points
39 789.50 900.50 606.50 758.50 RHO-points
40 0.50 111.50 758.50 910.50 RHO-points
41 111.50 224.50 758.50 910.50 RHO-points
42 224.50 337.50 758.50 910.50 RHO-points
43 337.50 450.50 758.50 910.50 RHO-points
44 450.50 563.50 758.50 910.50 RHO-points
45 563.50 676.50 758.50 910.50 RHO-points
46 676.50 789.50 758.50 910.50 RHO-points
47 789.50 900.50 758.50 910.50 RHO-points
48 0.50 111.50 910.50 1062.50 RHO-points
49 111.50 224.50 910.50 1062.50 RHO-points
50 224.50 337.50 910.50 1062.50 RHO-points
51 337.50 450.50 910.50 1062.50 RHO-points
52 450.50 563.50 910.50 1062.50 RHO-points
53 563.50 676.50 910.50 1062.50 RHO-points
54 676.50 789.50 910.50 1062.50 RHO-points
55 789.50 900.50 910.50 1062.50 RHO-points
56 0.50 111.50 1062.50 1212.50 RHO-points
57 111.50 224.50 1062.50 1212.50 RHO-points
58 224.50 337.50 1062.50 1212.50 RHO-points
59 337.50 450.50 1062.50 1212.50 RHO-points
60 450.50 563.50 1062.50 1212.50 RHO-points
61 563.50 676.50 1062.50 1212.50 RHO-points
62 676.50 789.50 1062.50 1212.50 RHO-points
63 789.50 900.50 1062.50 1212.50 RHO-points
0 1.00 111.50 0.50 150.50 U-points
1 111.50 224.50 0.50 150.50 U-points
2 224.50 337.50 0.50 150.50 U-points
3 337.50 450.50 0.50 150.50 U-points
4 450.50 563.50 0.50 150.50 U-points
5 563.50 676.50 0.50 150.50 U-points
6 676.50 789.50 0.50 150.50 U-points
7 789.50 900.00 0.50 150.50 U-points
8 1.00 111.50 150.50 302.50 U-points
9 111.50 224.50 150.50 302.50 U-points
10 224.50 337.50 150.50 302.50 U-points
11 337.50 450.50 150.50 302.50 U-points
12 450.50 563.50 150.50 302.50 U-points
13 563.50 676.50 150.50 302.50 U-points
14 676.50 789.50 150.50 302.50 U-points
15 789.50 900.00 150.50 302.50 U-points
16 1.00 111.50 302.50 454.50 U-points
17 111.50 224.50 302.50 454.50 U-points
18 224.50 337.50 302.50 454.50 U-points
19 337.50 450.50 302.50 454.50 U-points
20 450.50 563.50 302.50 454.50 U-points
21 563.50 676.50 302.50 454.50 U-points
22 676.50 789.50 302.50 454.50 U-points
23 789.50 900.00 302.50 454.50 U-points
24 1.00 111.50 454.50 606.50 U-points
25 111.50 224.50 454.50 606.50 U-points
26 224.50 337.50 454.50 606.50 U-points
27 337.50 450.50 454.50 606.50 U-points
28 450.50 563.50 454.50 606.50 U-points
29 563.50 676.50 454.50 606.50 U-points
30 676.50 789.50 454.50 606.50 U-points
31 789.50 900.00 454.50 606.50 U-points
32 1.00 111.50 606.50 758.50 U-points
33 111.50 224.50 606.50 758.50 U-points
34 224.50 337.50 606.50 758.50 U-points
35 337.50 450.50 606.50 758.50 U-points
36 450.50 563.50 606.50 758.50 U-points
37 563.50 676.50 606.50 758.50 U-points
38 676.50 789.50 606.50 758.50 U-points
39 789.50 900.00 606.50 758.50 U-points
40 1.00 111.50 758.50 910.50 U-points
41 111.50 224.50 758.50 910.50 U-points
42 224.50 337.50 758.50 910.50 U-points
43 337.50 450.50 758.50 910.50 U-points
44 450.50 563.50 758.50 910.50 U-points
45 563.50 676.50 758.50 910.50 U-points
46 676.50 789.50 758.50 910.50 U-points
47 789.50 900.00 758.50 910.50 U-points
48 1.00 111.50 910.50 1062.50 U-points
49 111.50 224.50 910.50 1062.50 U-points
50 224.50 337.50 910.50 1062.50 U-points
51 337.50 450.50 910.50 1062.50 U-points
52 450.50 563.50 910.50 1062.50 U-points
53 563.50 676.50 910.50 1062.50 U-points
54 676.50 789.50 910.50 1062.50 U-points
55 789.50 900.00 910.50 1062.50 U-points
56 1.00 111.50 1062.50 1212.50 U-points
57 111.50 224.50 1062.50 1212.50 U-points
58 224.50 337.50 1062.50 1212.50 U-points
59 337.50 450.50 1062.50 1212.50 U-points
60 450.50 563.50 1062.50 1212.50 U-points
61 563.50 676.50 1062.50 1212.50 U-points
62 676.50 789.50 1062.50 1212.50 U-points
63 789.50 900.00 1062.50 1212.50 U-points
0 0.50 111.50 1.00 150.50 V-points
1 111.50 224.50 1.00 150.50 V-points
2 224.50 337.50 1.00 150.50 V-points
3 337.50 450.50 1.00 150.50 V-points
4 450.50 563.50 1.00 150.50 V-points
5 563.50 676.50 1.00 150.50 V-points
6 676.50 789.50 1.00 150.50 V-points
7 789.50 900.50 1.00 150.50 V-points
8 0.50 111.50 150.50 302.50 V-points
9 111.50 224.50 150.50 302.50 V-points
10 224.50 337.50 150.50 302.50 V-points
11 337.50 450.50 150.50 302.50 V-points
12 450.50 563.50 150.50 302.50 V-points
13 563.50 676.50 150.50 302.50 V-points
14 676.50 789.50 150.50 302.50 V-points
15 789.50 900.50 150.50 302.50 V-points
16 0.50 111.50 302.50 454.50 V-points
17 111.50 224.50 302.50 454.50 V-points
18 224.50 337.50 302.50 454.50 V-points
19 337.50 450.50 302.50 454.50 V-points
20 450.50 563.50 302.50 454.50 V-points
21 563.50 676.50 302.50 454.50 V-points
22 676.50 789.50 302.50 454.50 V-points
23 789.50 900.50 302.50 454.50 V-points
24 0.50 111.50 454.50 606.50 V-points
25 111.50 224.50 454.50 606.50 V-points
26 224.50 337.50 454.50 606.50 V-points
27 337.50 450.50 454.50 606.50 V-points
28 450.50 563.50 454.50 606.50 V-points
29 563.50 676.50 454.50 606.50 V-points
30 676.50 789.50 454.50 606.50 V-points
31 789.50 900.50 454.50 606.50 V-points
32 0.50 111.50 606.50 758.50 V-points
33 111.50 224.50 606.50 758.50 V-points
34 224.50 337.50 606.50 758.50 V-points
35 337.50 450.50 606.50 758.50 V-points
36 450.50 563.50 606.50 758.50 V-points
37 563.50 676.50 606.50 758.50 V-points
38 676.50 789.50 606.50 758.50 V-points
39 789.50 900.50 606.50 758.50 V-points
40 0.50 111.50 758.50 910.50 V-points
41 111.50 224.50 758.50 910.50 V-points
42 224.50 337.50 758.50 910.50 V-points
43 337.50 450.50 758.50 910.50 V-points
44 450.50 563.50 758.50 910.50 V-points
45 563.50 676.50 758.50 910.50 V-points
46 676.50 789.50 758.50 910.50 V-points
47 789.50 900.50 758.50 910.50 V-points
48 0.50 111.50 910.50 1062.50 V-points
49 111.50 224.50 910.50 1062.50 V-points
50 224.50 337.50 910.50 1062.50 V-points
51 337.50 450.50 910.50 1062.50 V-points
52 450.50 563.50 910.50 1062.50 V-points
53 563.50 676.50 910.50 1062.50 V-points
54 676.50 789.50 910.50 1062.50 V-points
55 789.50 900.50 910.50 1062.50 V-points
56 0.50 111.50 1062.50 1212.00 V-points
57 111.50 224.50 1062.50 1212.00 V-points
58 224.50 337.50 1062.50 1212.00 V-points
59 337.50 450.50 1062.50 1212.00 V-points
60 450.50 563.50 1062.50 1212.00 V-points
61 563.50 676.50 1062.50 1212.00 V-points
62 676.50 789.50 1062.50 1212.00 V-points
63 789.50 900.50 1062.50 1212.00 V-points
HaloSizeI(1) = 556
HaloSizeJ(1) = 608
TileSide(1) = 146
TileSize(1) = 19418
HaloSizeI(2) = 508
HaloSizeJ(2) = 664
TileSide(2) = 160
TileSize(2) = 19360
haili
#4 Unread post by haili »
The rest part:
zeta 1 Periodic Closed Periodic Closed
2 Nested Nested Nested Nested
ubar 1 Periodic Closed Periodic Closed
vbar 1 Periodic Closed Periodic Closed
u 1 Periodic Closed Periodic Closed
v 1 Periodic Closed Periodic Closed
temp 1 Periodic Closed Periodic Closed
salt 1 Periodic Closed Periodic Closed
tke 1 Periodic Closed Periodic Closed
NGBAY NGBAY nesting grids
ADD_FSOBC Adding tidal elevation to processed OBC data.
ADD_M2OBC Adding tidal currents to processed OBC data.
!ASSEMBLE_ALL... Using mpi_isend/mpi_recv in mp_assemble routine.
!BOUNDARY_ALLGATHER Using mpi_allreduce in mp_boundary routine.
BULK_FLUXES Surface bulk fluxes parameterization.
!COLLECT_ALL... Using mpi_isend/mpi_recv in mp_collect routine.
DIFF_GRID Horizontal diffusion coefficient scaled by grid size.
EMINUSP Compute Salt Flux using E-P.
LONGWAVE_OUT Compute outgoing longwave radiation internally.
MASKING Land/Sea masking.
NESTING Nesting grids: Composite and Refinement.
NONLINEAR Nonlinear Model.
NO_WRITE_GRID Not Writing grid arrays into NetCDF ouput files.
ONE_WAY One-way nesting in refinement grids.
PERFECT_RESTART Processing perfect restart variables.
REDUCE_ALLGATHER Using mpi_allgather in mp_reduce routine.
SALINITY Using salinity.
STATIONS Writing out station data.
UV_ADV Advection of momentum.
UV_COR Coriolis term.
UV_SADVECTION Parabolic splines vertical advection of momentum.
UV_TIDES Add tidal currents to 2D momentum climatologies.
VISC_GRID Horizontal viscosity coefficient scaled by grid size.
Process Information:
Node # 0 (pid= 30031) is active.
Node # 3 (pid= 30034) is active.
Node # 7 (pid= 30038) is active.
Node # 9 (pid= 30040) is active.
Node # 14 (pid= 30045) is active.
Node # 1 (pid= 30032) is active.
Node # 2 (pid= 30033) is active.
Node # 5 (pid= 30036) is active.
Node # 6 (pid= 30037) is active.
Node # 8 (pid= 30039) is active.
Node # 10 (pid= 30041) is active.
Node # 11 (pid= 30042) is active.
Node # 12 (pid= 30043) is active.
Node # 13 (pid= 30044) is active.
Node # 15 (pid= 30046) is active.
Node # 4 (pid= 30035) is active.
Node # 20 (pid= 20243) is active.
Node # 33 (pid= 31531) is active.
Node # 57 (pid= 12425) is active.
Node # 47 (pid= 31545) is active.
Node # 22 (pid= 20245) is active.
Node # 46 (pid= 31544) is active.
Node # 29 (pid= 20252) is active.
Node # 34 (pid= 31532) is active.
Node # 26 (pid= 20249) is active.
Node # 35 (pid= 31533) is active.
Node # 30 (pid= 20253) is active.
Node # 37 (pid= 31535) is active.
Node # 21 (pid= 20244) is active.
Node # 40 (pid= 31538) is active.
Node # 23 (pid= 20246) is active.
Node # 42 (pid= 31540) is active.
Node # 18 (pid= 20241) is active.
Node # 38 (pid= 31536) is active.
Node # 31 (pid= 20254) is active.
Node # 43 (pid= 31541) is active.
Node # 28 (pid= 20251) is active.
Node # 45 (pid= 31543) is active.
Node # 24 (pid= 20247) is active.
Node # 44 (pid= 31542) is active.
Node # 17 (pid= 20240) is active.
Node # 41 (pid= 31539) is active.
Node # 25 (pid= 20248) is active.
Node # 36 (pid= 31534) is active.
Node # 16 (pid= 20239) is active.
Node # 32 (pid= 31530) is active.
Node # 27 (pid= 20250) is active.
Node # 39 (pid= 31537) is active.
Node # 19 (pid= 20242) is active.
Node # 62 (pid= 12430) is active.
Node # 51 (pid= 12419) is active.
Node # 52 (pid= 12420) is active.
Node # 56 (pid= 12424) is active.
Node # 49 (pid= 12417) is active.
Node # 58 (pid= 12426) is active.
Node # 54 (pid= 12422) is active.
Node # 55 (pid= 12423) is active.
Node # 60 (pid= 12428) is active.
Node # 61 (pid= 12429) is active.
Node # 59 (pid= 12427) is active.
Node # 53 (pid= 12421) is active.
Node # 50 (pid= 12418) is active.
Node # 48 (pid= 12416) is active.
Node # 63 (pid= 12431) is active.
Minimum X-grid spacing, DXmin = 1.00000000E-40 km
Maximum X-grid spacing, DXmax = 4.89691606E-02 km
Minimum Y-grid spacing, DYmin = 1.00000000E-40 km
Maximum Z-grid spacing, DZmax = 9.27954758E+35 m
Maximum barotropic Courant Number = 9.33809402E+54
Maximum Coriolis Courant Number = 1.00000000E+37
Horizontal mixing scaled by grid size, GRDMAX = 4.54778126E-02 km
- free-surface
- salinity
(Grid 02, t = 0.0000, File: ngbay_ini.nc, Rec=0001, Index=1)
- free-surface
(Min = 4.55619148E+00 Max = 1.23957848E+01)
- salinity
(Min = 1.04572727E-21 Max = 3.36493083E+01)
0 2006-01-01 00:00:00.00 0.000000E+00 5.120693E+01 5.120693E+01 4.990846E+09 02
DEF_STATION - creating stations file, Grid 02: /users/hwang121/scratch/ngbayhlnestingfile/output/oceanhl_sta.nc
(310,0595,01) 2.617588E-03 1.370244E-03 0.000000E+00 NaN
Node # 48 CPU: 54.900
Node # 32 CPU: 55.032
Node # 16 CPU: 55.014
Node # 49 CPU: 54.874
Node # 33 CPU: 55.116
Node # 17 CPU: 55.050
WRT_RST - wrote re-start fields (Index=1,2) in record = 0000001 02
Elapsed CPU time (seconds):
Node # 0 CPU: 43.720
Total: 3509.985
Node # 50 CPU: 55.066
Node # 34 CPU: 55.123
Node # 18 CPU: 55.050
Node # 1 CPU: 55.114
Node # 51 CPU: 55.057
Node # 35 CPU: 55.108
Node # 19 CPU: 54.905
Node # 2 CPU: 54.913
Node # 52 CPU: 55.081
Node # 36 CPU: 55.115
Node # 20 CPU: 55.107
Node # 3 CPU: 55.006
Node # 53 CPU: 55.057
Node # 37 CPU: 55.030
Node # 21 CPU: 54.779
Node # 4 CPU: 55.121
Node # 54 CPU: 54.888
Node # 38 CPU: 55.100
Node # 22 CPU: 54.683
Node # 5 CPU: 55.003
Node # 55 CPU: 54.844
Node # 39 CPU: 55.112
Node # 23 CPU: 55.113
Node # 6 CPU: 55.110
Node # 56 CPU: 55.019
Node # 40 CPU: 55.091
Node # 24 CPU: 54.822
Node # 7 CPU: 54.974
Node # 57 CPU: 55.085
Node # 41 CPU: 55.046
Node # 25 CPU: 54.997
Node # 8 CPU: 54.970
Node # 58 CPU: 55.096
Node # 42 CPU: 55.060
Node # 26 CPU: 55.079
Node # 9 CPU: 55.052
Node # 59 CPU: 55.044
Node # 43 CPU: 55.114
Node # 27 CPU: 54.923
Node # 10 CPU: 55.166
Node # 60 CPU: 54.970
Node # 44 CPU: 55.081
Node # 28 CPU: 54.986
Node # 11 CPU: 55.125
Node # 61 CPU: 55.067
Node # 45 CPU: 55.002
Node # 29 CPU: 55.057
Node # 12 CPU: 55.069
Node # 62 CPU: 54.950
Node # 46 CPU: 55.084
Node # 30 CPU: 54.994
Node # 13 CPU: 54.928
Node # 63 CPU: 54.955
Node # 47 CPU: 55.108
Node # 31 CPU: 55.109
Node # 14 CPU: 54.848
Node # 15 CPU: 54.923
Allocation and array initialization .............. 32.764 ( 0.9334 %)
Ocean state initialization ....................... 553.223 (15.7614 %)
Reading of input data ............................ 611.396 (17.4188 %)
Processing of input data ......................... 3.559 ( 0.1014 %)
Processing of output time averaged data .......... 0.003 ( 0.0001 %)
Computation of vertical boundary conditions ...... 0.170 ( 0.0048 %)
Computation of global information integrals ...... 0.567 ( 0.0161 %)
Writing of output data ........................... 34.367 ( 0.9791 %)
Model 2D kernel .................................. 13.601 ( 0.3875 %)
Tidal forcing .................................... 0.813 ( 0.0232 %)
2D/3D coupling, vertical metrics ................. 5.117 ( 0.1458 %)
Omega vertical velocity .......................... 1.034 ( 0.0295 %)
Equation of state for seawater ................... 4.133 ( 0.1178 %)
Atmosphere-Ocean bulk flux parameterization ...... 3.019 ( 0.0860 %)
GLS vertical mixing parameterization ............. 12.478 ( 0.3555 %)
3D equations right-side terms .................... 2.062 ( 0.0587 %)
3D equations predictor step ...................... 1.942 ( 0.0553 %)
Pressure gradient ................................ 0.839 ( 0.0239 %)
Harmonic mixing of tracers, S-surfaces ........... 0.299 ( 0.0085 %)
Harmonic stress tensor, S-surfaces ............... 0.623 ( 0.0177 %)
Corrector time-step for 3D momentum .............. 2.789 ( 0.0795 %)
Corrector time-step for tracers .................. 16.648 ( 0.4743 %)
Nesting algorithm ................................ 43.169 ( 1.2299 %)
Reading model state vector ....................... 144.918 ( 4.1287 %)
Total: 1489.532 42.4370
Message Passage: 2D halo exchanges ............... 16.447 ( 0.4686 %)
Message Passage: 3D halo exchanges ............... 7.907 ( 0.2253 %)
Message Passage: 4D halo exchanges ............... 8.309 ( 0.2367 %)
Message Passage: data broadcast .................. 967.364 (27.5604 %)
Message Passage: data reduction .................. 4.707 ( 0.1341 %)
Message Passage: data gathering .................. 203.935 ( 5.8101 %)
Message Passage: data scattering.................. 145.144 ( 4.1352 %)
Message Passage: point data gathering ............ 7.135 ( 0.2033 %)
Message Passage: nesting point data gathering .... 462.264 (13.1700 %)
Message Passage: synchronization barrier ......... 0.795 ( 0.0227 %)
Total: 1824.007 51.9662
Nonlinear model elapsed CPU time profile, Grid: 02
Allocation and array initialization .............. 32.764 ( 0.9335 %)
Ocean state initialization ....................... 551.690 (15.7177 %)
Reading of input data ............................ 10.013 ( 0.2853 %)
Processing of input data ......................... 0.341 ( 0.0097 %)
Processing of output time averaged data .......... 0.001 ( 0.0000 %)
Computation of vertical boundary conditions ...... 0.116 ( 0.0033 %)
Computation of global information integrals ...... 0.871 ( 0.0248 %)
Writing of output data ........................... 14.395 ( 0.4101 %)
Model 2D kernel .................................. 13.747 ( 0.3917 %)
Tidal forcing .................................... 0.000 ( 0.0000 %)
2D/3D coupling, vertical metrics ................. 5.327 ( 0.1518 %)
Omega vertical velocity .......................... 1.228 ( 0.0350 %)
Equation of state for seawater ................... 5.938 ( 0.1692 %)
Atmosphere-Ocean bulk flux parameterization ...... 2.577 ( 0.0734 %)
GLS vertical mixing parameterization ............. 12.301 ( 0.3504 %)
3D equations right-side terms .................... 2.082 ( 0.0593 %)
3D equations predictor step ...................... 1.800 ( 0.0513 %)
Pressure gradient ................................ 0.858 ( 0.0244 %)
Harmonic mixing of tracers, S-surfaces ........... 0.305 ( 0.0087 %)
Harmonic stress tensor, S-surfaces ............... 0.646 ( 0.0184 %)
Corrector time-step for 3D momentum .............. 2.408 ( 0.0686 %)
Corrector time-step for tracers .................. 14.788 ( 0.4213 %)
Nesting algorithm ................................ 16.886 ( 0.4811 %)
Reading model state vector ....................... 110.424 ( 3.1460 %)
Total: 801.506 22.8350
Nonlinear model message Passage profile, Grid: 02
Message Passage: 2D halo exchanges ............... 11.532 ( 0.3285 %)
Message Passage: 3D halo exchanges ............... 7.760 ( 0.2211 %)
Message Passage: 4D halo exchanges ............... 6.648 ( 0.1894 %)
Message Passage: data broadcast .................. 358.380 (10.2103 %)
Message Passage: data reduction .................. 1.822 ( 0.0519 %)
Message Passage: data gathering .................. 209.274 ( 5.9623 %)
Message Passage: data scattering.................. 93.113 ( 2.6528 %)
Message Passage: point data gathering ............ 3.059 ( 0.0872 %)
Message Passage: nesting point data gathering .... 648.264 (18.4691 %)
Total: 1339.852 38.1726
Unique code regions profiled ..................... 2291.037 65.2720 %
Residual, non-profiled code ...................... 1218.947 34.7280 %
All percentages are with respect to total time = 3509.985
number of time records written in STATION file = 00000001
ROMS/TOMS - Output NetCDF summary for Grid 02:
Analytical header files used:
ROMS/Functionals/ana_btflux.h
ROMS/TOMS: DONE... Sunday - March 3, 2019 - 10:50:22 PM
Laketest case complete
Kosa
#5 Unread post by Kosa »
haili wrote:I only added the initial condition, the tidal forcing and the contact files for the refined grid.
Can you clarify this sentence? You don't have a tidal forcing file for the refined grid so are you saying that you haven't run the coarse grid standalone with its initial conditions file or its tidal forcing file yet? If so, I would recommend running the coarse grid on its own with all of your initial/forcing files first.
haili
#6 Unread post by haili »
I have already ran the coarse grid with its own initial/forcing files successfully, and then I add the initial condition, the tidal forcing and the contact files of the refined grid to do the nesting.
#7 Unread post by jcwarner »
are you using wet/dry for the nest? how shallow do the water depths get?
#8 Unread post by wilkin »
You have negative depths.
wavewatch
#9 Unread post by wavewatch »
I looked through your output file and found that ROMS did not read the boundary conditions. There was no such problem in the old version of ROMS. I would like to ask if anyone has encountered this problem. :?
#10 Unread post by wilkin »
When updating your source code remember you may need to update the roms.in (ocean.in). New options may have been introduced to manage file input/output that your old set-up does not have. It is not difficult to diff your input script with the trunk version it was based on to highlight possible missing new options. Also, generally speaking the release notes accompanying a major update will alert you to new options you may need to add. I recommend reading those.
wavewatch
#11 Unread post by wavewatch »
wilkin wrote: Mon Jun 15, 2020 1:09 pm
Dear Dr. Wilkin:
According to your suggestion, I modified the build script file and *.in file of the new version, and recompiled and ran the Two-way nesting examples.The result is the following error:
         0 2000-01-02 00:00:00.00  1.314949E-03  2.184196E+04  2.184196E+04  1.005743E+17  01
                     (214,052,04)  3.291530E-02  3.888322E-02  0.000000E+00  9.450913E-01
      DEF_HIS     - creating  history      file, Grid 01: ./output/SP_s1_his_0001.nc
      WRT_HIS     - wrote history     fields (Index=1,1) in record = 0000001               01
      DEF_AVG     - creating  average      file, Grid 01: ./output/SP_s1_avg_0001.nc
Program received signal SIGSEGV: Segmentation fault - invalid memory reference.
Backtrace for this error:
A process has executed an operation involving a call to the
"fork()" system call to create a child process.  Open MPI is currently
operating in a condition that could result in memory corruption or
other system errors; your job may hang, crash, or produce silent
data corruption.  The use of fork() (or system() or other calls that
create child processes) is strongly discouraged.
The process that invoked fork was:
  Local host:          [[64185,1],0] (PID 13572)
If you are *absolutely sure* that your application will successfully
and correctly survive a call to fork(), you may disable this warning
by setting the mpi_warn_on_fork MCA parameter to 0.
#0  0x2B687FAD66F7
#1  0x2B687FAD6D3E
#2  0x2B688078426F
#3  0x5255BB in __nesting_mod_MOD_nesting
#4  0x46D4ED in main3d_
#5  0x403C5D in __ocean_control_mod_MOD_roms_run
#6  0x403868 in MAIN__ at master.f90:?
mpirun noticed that process rank 0 with PID 0 on node comput43 exited on signal 11 (Segmentation fault).
But when I define ONE_WAY in the .h file, the mode worked, but blowing up quickly. In both cases, the boundary conditions can be found in Output/Input Files, however, no boundary values are read.
Sorry, There is no way to upload the attachment. I reposted a post with details on it.Looking forward to reply.Thank you
viewtopic.php?f=14&t=5529
johnluick
#12 Unread post by johnluick »
Just wondered if this was what John Wilkin meant to paste in about negative depths.
