After successfully compiling the upwelling test case i got an executable file "oceanS".
However i get an error everytime i try running it.
This is the command i used to run the oceanS executable
./oceanS <ocean_upwelling.in
And this is the error i keep on getting
MOD_NCPARAM- Unable to open variable information file:
${MY_ROOT_DIR}/trunk/ROMS/External/varinfo.dat
NB: I have changed the path in the input file to the exact location of the varinfo.dat file but the error still remains
Running ROMS error
Re: Running ROMS error
You are probably specifying the path incorrectly.
Just try copying varinfo.dat to the directory where you have oceanS and ocean_upwelling.in, and remove any path information to the file in ocean_upwelling.in, i.e. have:
VARNAME = varinfo.dat
Thank you very much. It worked. Im grateful
