my bry.nc have NaN in the varibales of zeta_east,zeta_north,zeta_south,and zeta_west.
So in my in file,I closed the free-surface.
LBC(isFsur) == Clo Clo Clo Clo ! free-surface
LBC(isUbar) == Clo Fla Fla Fla ! 2D U-momentum
LBC(isVbar) == Clo Fla Fla Fla ! 2D V-momentum
LBC(isUvel) == Clo Cla Cla Cla ! 3D U-momentum
LBC(isVvel) == Clo Cla Cla Cla ! 3D V-momentum
LBC(isMtke) == Gra Gra Gra Gra ! mixing TKE
LBC(isTvar) == Cla Cla Cla Cla \ ! temperature
Cla Cla Cla Cla ! salinity
! conditions keywords.
ad_LBC(isFsur) == Clo Clo Clo Clo ! free-surface
ad_LBC(isUbar) == Clo Fla Fla Fla ! 2D U-momentum
ad_LBC(isVbar) == Clo Fla Fla Fla ! 2D U-momentum
ad_LBC(isUvel) == Clo Cla Cla Cla ! 3D U-momentum
ad_LBC(isVvel) == Clo Cla Cla Cla ! 3D V-momentum
ad_LBC(isMtke) == Gra Gra Gra Gra ! mixing TKE
ad_LBC(isTvar) == Cla Cla Cla Cla \ ! temperature
But I still get Blowing-up.
0 0001-01-01 00:00:00.00 2.485765E-04 1.401961E+04 1.401961E+04 5.563019E+15
(59,16,04) 1.085449E-01 0.000000E+00 0.000000E+00 2.072265E+00
WRT_HIS - wrote history fields (Index=1,1) in record = 0000001
DEF_AVG - creating average file, Grid 01: ocean_avg.nc
DEF_DIAGS - creating diagnostics file, Grid 01: ocean_dia.nc
1 0001-01-01 00:45:00.00 NaN NaN NaN NaN
(00,00,00) 0.000000E+00 0.000000E+00 0.000000E+00 NaN
Found Error: 01 Line: 298 Source: ROMS/Nonlinear/main3d.F
Found Error: 01 Line: 298 Source: ROMS/Drivers/nl_ocean.h
WRT_RST - wrote re-start fields (Index=1,2) in record = 0000001
Elapsed CPU time (seconds):
Node # 0 CPU: 0.351
Node # 1 CPU: 0.352
Total: 0.703
and I checked my log file and find this:
GET_NGFLD - free-surface eastern boundary condition, 0001-12-12 00:00:00.00
(Grid= 01, Rec=0000012, Index=2, File: croco_bry.nc)
(Tmin= 15.0000 Tmax= 345.0000) t = 345.0000
(Min = NaN Max = NaN)
GET_NGFLD - free-surface southern boundary condition, 0001-12-12 00:00:00.00
GET_NGFLD - free-surface northern boundary condition, 0001-12-12 00:00:00.00
GET_NGFLD - free-surface eastern boundary condition, 0001-01-16 00:00:00.00
(Grid= 01, Rec=0000001, Index=1, File: croco_bry.nc)
(Tmin= 15.0000 Tmax= 345.0000) t = 15.0000
GET_NGFLD - free-surface southern boundary condition, 0001-01-16 00:00:00.00
GET_NGFLD - free-surface northern boundary condition, 0001-01-16 00:00:00.00
Why I closed the free surface,I still get this. Should I fill out the NaN values in the boundary file? Those NaN values are not alone, the whole matrix of zeta_east,zeta_north,zeta_south,zeta_west are NaN.
Some confusion about the boundary file
Re: Some confusion about the boundary file
The Flather condition uses zeta in the ubar term. Either fix your zeta or set it to zero.
Thank you very much,kate
Hello,kate.I set my zeta into zeros.And it running normally untill 9525 steps after it blowing up.
9513 0001-10-25 06:45:00.00 1.541050E-02 1.402140E+04 1.402142E+04 5.562436E+15
(59,17,20) 1.184031E-01 8.302710E-02 1.927002E+00 3.729171E+00
9514 0001-10-25 07:30:00.00 1.540656E-02 1.402140E+04 1.402142E+04 5.562437E+15
(59,17,19) 1.154813E-01 8.222846E-02 1.928615E+00 3.629425E+00
9515 0001-10-25 08:15:00.00 1.540227E-02 1.402140E+04 1.402142E+04 5.562437E+15
(59,17,19) 1.148758E-01 8.070675E-02 1.965517E+00 3.670237E+00
9516 0001-10-25 09:00:00.00 1.540064E-02 1.402140E+04 1.402142E+04 5.562437E+15
(59,17,19) 1.168241E-01 7.946633E-02 2.015523E+00 3.673641E+00
9517 0001-10-25 09:45:00.00 1.539963E-02 1.402140E+04 1.402142E+04 5.562437E+15
(59,17,19) 1.159784E-01 7.627296E-02 2.009265E+00 3.491694E+00
9518 0001-10-25 10:30:00.00 1.539638E-02 1.402140E+04 1.402142E+04 5.562437E+15
(59,17,20) 1.151301E-01 7.967622E-02 2.029614E+00 3.629846E+00
9519 0001-10-25 11:15:00.00 1.539088E-02 1.402140E+04 1.402142E+04 5.562437E+15
(59,17,20) 1.182182E-01 7.575985E-02 2.083018E+00 3.656241E+00
9520 0001-10-25 12:00:00.00 1.538693E-02 1.402140E+04 1.402142E+04 5.562438E+15
(59,17,20) 1.162398E-01 7.412836E-02 2.117487E+00 3.470595E+00
9521 0001-10-25 12:45:00.00 1.538487E-02 1.402140E+04 1.402142E+04 5.562438E+15
(59,17,20) 1.166021E-01 7.383122E-02 2.080710E+00 3.363347E+00
9522 0001-10-25 13:30:00.00 1.538302E-02 1.402140E+04 1.402142E+04 5.562438E+15
(59,17,20) 1.183279E-01 7.371244E-02 2.107115E+00 3.546257E+00
9523 0001-10-25 14:15:00.00 1.537885E-02 1.402140E+04 1.402142E+04 5.562438E+15
(59,17,20) 1.172144E-01 7.334491E-02 2.092832E+00 3.460003E+00
9524 0001-10-25 15:00:00.00 1.537479E-02 1.402140E+04 1.402142E+04 5.562438E+15
(59,17,20) 1.130312E-01 7.129245E-02 2.035680E+00 3.370243E+00
9525 0001-10-25 15:45:00.00 1.537169E-02 1.402140E+04 1.402142E+04 5.562438E+15
(59,17,20) 1.149655E-01 7.355530E-02 2.005018E+00 3.375108E+00
WRT_RST - wrote re-start fields (Index=1,2) in record = 0000003
I checked the restart file, and I find out that there is a value in temp that is very low,-67.8517. However the value in my input boundary seems normal. when I close the esat boudary,the model will run a longer time,then blow up. I am a little confused about it.
This is where you have to do more detective work. I wrote up what I know here.
