Inconsistent values of variables in TL initial condition
Biswamoy_Paul
#1 Unread post by Biswamoy_Paul »
I have setup IS4DVAR for the Indian Ocean with 8~9 km resolution and 40 vertical levels. I am testing a one day run with 30 inner loops and 1 outer loop using MetOffice EN4 T and S observation data.
It is running fine till the adjoint run in the last inner loop. After the corresponding Descent Algorithm (in inner loop# 30) the values of free-surface, u and v-momentum component, potential temperature and salinity in the input tangent linear model initial conditions file (namely, *_itl.nc) increase abruptly as seen in the following log:
 TLM: GET_STATE - Read state initial conditions,             t =  9710 00:00:00
                   (Grid 01, File: io_1x12_itl.nc, Rec=0001, Index=1)
                - free-surface
                   (Min = -1.05473263E+03 Max =  8.77788746E+02)
                - free-surface, open boundaries
                   (Min = -6.16861539E-01 Max =  2.13182573E-01)
                - vertically integrated u-momentum component, open boundaries
                - vertically integrated v-momentum component, open boundaries
                - surface u-momentum stress, adjusted tl_ustr
                   (Min = -4.47085764E-01 Max =  8.82287023E-01)
                - surface v-momentum stress, adjusted tl_vstr
                   (Min = -2.79389044E-01 Max =  3.06903690E-01)
                - u-momentum component
                   (Min = -2.21421791E+06 Max =  1.21455456E+06)
                - u-momentum component, open boundaries
                   (Min = -1.00039186E-01 Max =  3.04749362E-02)
                - v-momentum component
                   (Min = -1.45533555E+06 Max =  1.45103002E+06)
                - v-momentum component, open boundaries
                   (Min = -1.13609944E-01 Max =  4.29629471E-02)
                - potential temperature
                   (Min = -4.40319194E+03 Max =  7.84010994E+04)
                - salinity
                   (Min = -3.24198687E+04 Max =  4.41747228E+04)
                - potential temperature, open boundaries
                   (Min = -6.09766327E-02 Max =  1.63820702E-01)
                - salinity, open boundaries
                   (Min = -2.45726672E-02 Max =  4.26380653E-03)
                - surface net heat flux, adjusted tl_tflux
                   (Min = -7.60638358E-07 Max =  1.92845377E-02)
                - surface net salt flux, (E-P)*SALT, adjusted tl_tflux
                   (Min = -8.47218473E-07 Max =  9.61237175E-03)
      WRT_INI   - wrote initial  fields (Iter=0032, Index=1,1, Rec=0001)
Hence the following forward nonlinear model run blows up at the first time step.
I have tried to locate the problem with increasing the friction, changing the decorrelation scales, increasing the # of the inner loop, enabling/disabling ADJUST_BOUNDARY, ADJUST_WSTRESS, ADJUST_STFLUX, and also with relaxing T and S. But the problem still persists.
I have attached the figures of tangent linear u and v-momentum component at the surface. I don't have any clue what causes this sudden increment of these values. Any kind of help or advice would be highly appreciated. Thanks in advance.
tangent linear v-momentum component at the surface
tangent linear u-momentum component at the surface
Re: Inconsistent values of variables in TL initial condition
I suppose you are focused on the big blobs of extreme values, but my eye is drawn to Y=380 and the weird line there.
Biswamoy_Paul
#3 Unread post by Biswamoy_Paul »
Thanks, Kate for your reply.
Yes, I was more focused on those extreme values in velocity and tracer fields. Those high anomalies are found even in the subsurface.
I assume that the line of sharp gradient in velocity field, which is exactly on the Equator (my model domain ranges from 30S to 30N), is the source of this trouble. This weird line is found throughout the depth as seen in the attached figure, a vertical slice of v-momentum at X=458. Although no such line is found in tracers and free-surface field.
I wonder what causes this sharp changes in velocity field at the Equator.
TL v-momentum component at X=458
wavewatch
#4 Unread post by wavewatch »
May I ask if your problem has been solved ?
I had the same problem :( :( :(
