ocean_benchmark3.in run error
bsas
#1 Unread post by bsas »
Hello everyone.
I have configured ROMS with Upwelling. I'm running ocean_benchmark3.in and it gives me an error.
 Analytical header files used:
     ROMS/Functionals/ana_btflux.h
     ROMS/Functionals/ana_grid.h
     ROMS/Functionals/ana_smflux.h
     ROMS/Functionals/ana_stflux.h
     ROMS/Functionals/ana_vmix.h
 Found Error: 01   Line: 350      Source: ROMS/Utility/close_io.F
 ROMS/TOMS - Blows up ................ exit_flag:   1
I have looked for solutions to similar errors, but I can not find the fault. Attached the complete log of the execution in case someone can guide me.
Thank you very much for your time.
out.log
(30.54 KiB) Downloaded 467 times
Re: ocean_benchmark3.in run error
I managed to run BENCHMARK3 for the requested 200 steps. One difference I see - mine:
 Header file   : benchmark.h
yours:
 Header file   : upwelling.h\
You need to recompile with the BENCHMARK options turned on.
bsas
#3 Unread post by bsas »
Thank you very much Kate.
Indeed, I ran ocean_benchmark3.in compiling first with benchmark.h instead of upwelling.h, and the following result came out:
ROMS/TOMS: DONE... Monday - July 9, 2018 - 11:24:59 AM
I'm learning and I'm a little lost yet. If I compile with the Header file upwelling.h, what Input Script can I use?
Thank you so much for everything.
You can use ocean_upwelling.in.
#5 Unread post by kate »
Back to the benchmark3 case, I got it to run with gfortran. However, with ifort, I get:
Image              PC                Routine            Line        Source
oceanG             0000000001E8B685  Unknown               Unknown  Unknown
oceanG             0000000001E892A7  Unknown               Unknown  Unknown
oceanG             0000000001E373F4  Unknown               Unknown  Unknown
oceanG             0000000001E37206  Unknown               Unknown  Unknown
oceanG             0000000001DE54A6  Unknown               Unknown  Unknown
oceanG             0000000001DE90A0  Unknown               Unknown  Unknown
libpthread.so.0    00007FE027B177E0  Unknown               Unknown  Unknown
oceanG             0000000001BD7A74  mp_exchange_mod_m        1544  mp_exchange.f90
oceanG             0000000000C33109  ini_fields_mod_mp         252  ini_fields.f90
oceanG             0000000000C19938  ini_fields_mod_mp          65  ini_fields.f90
oceanG             00000000006AE853  main3d_                   154  main3d.f90
oceanG             000000000040D70E  ocean_control_mod         181  ocean_control.f90
oceanG             000000000040BFF7  MAIN__                    108  master.f90
oceanG             000000000040B88E  Unknown               Unknown  Unknown
libc.so.6          00007FE0266D5D1D  Unknown               Unknown  Unknown
oceanG             000000000040B769  Unknown               Unknown  Unknown
The line in question is:
1543       CALL wclock_on (ng, model, 61, 1473,                              &
1544      &                "ROMS/Utility/mp_exchange.F"//":mp_exchange3d")
Does anyone else get the same result?
By the way, I had to comment out this line in Compilers/Linux-ifort.mk:
FFLAGS += -Wl,-no_compact_unwind
bsas
#6 Unread post by bsas »
Hello Kate.
I ran benchmark3 case with Ifort and I did not get any errors. Do you want some configuration file to happen to you?
#7 Unread post by kate »
If we're both using the same ROMS trunk code, then maybe it's something in the version of ifort I'm using:
chinook04 186% which mpif90
/opt/scyld/openmpi/1.10.7/intel/bin/mpif90
chinook04 187% which ifort
/usr/local/pkg/compiler/ifort/2016.3.210-GCC-5.4.0-2.26/compilers_and_libraries_2016.3.210/linux/bin/intel64/ifort
bsas
#8 Unread post by bsas »
That is my version:
$ which mpif90
/opt/cesga/intel/2017/impi/2017.4.239/bin64/mpif90
$ which ifort
/opt/cesga/intel/2017/compilers_and_libraries_2017.5.239/linux/bin/intel64/ifort
