how can i down the 'ROMS/TOMS Test Cases' in wikiroms web
zhuyuxin500
#1 Unread post by zhuyuxin500 »
hi,
i am a new user,i want to run some of idealized model about ROMS,but i can't find where can down .so could you tell me how and where to down the 'ROMS/TOMS Test Cases' .
All the test cases are included with the distribution.
#3 Unread post by kate »
Which ones in particular did you want to run? Some are built in, not needing any files outside the ROMS distribution. For instance, the lock exchange problem is set with the GRAV_ADJ symbol in the makefile (where UPWELLING is by default). Do a search on GRAV_ADJ to see how the code changes for that configuration. The file ROMS/Include/grav_adj.h will be used to set cpp flags and ROMS/External/ocean_grav_adj.in should be used as input.
