The problem is that you don't have enough memory to run the domain you specify in the ocean.in file. What did you set Lm, Mm and N to? How about the number of tracers? Any idea how much memory you have on your system?
Lm == 199 ! Number of I-direction INTERIOR RHO-points
Mm == 215 ! Number of J-direction INTERIOR RHO-points
N == 30 ! Number of vertical levels
Nbed = 0 ! Number of sediment bed layers
NAT = 2 ! Number of active tracers (usually, 2)
NPT = 0 ! Number of inactive passive tracers
NCS = 0 ! Number of cohesive (mud) sediment tracers
NNS = 0 ! Number of non-cohesive (sand) sediment tracers
This is not what I would consider to be a large domain, probably not your problem.
On the other hand, this is asking for 552 processes for a modest domain and probably is your problem. What if you ask for a total of 4-8 processes instead? How many cores are in your computer? Is this some small laptop or desktop system? Your output from the limit command only reports operating system-imposed limits, not what you actually have for memory or anything.
thanks for ur reply. i run it on a super computer. It should be fine to ask for 552 processes. In order to rule out the error, I changed NtileI as 12 and NtileJ as 4( Resolution, Grid 01: 0199x0215x030, Parallel Nodes: 48, Tiling: 012x004), the same problem still exist. In order to make sure the super computer is ok, I also run a bio_toy example sucessfully in this super computer. the input files (frc,ini,bry,runoff and so on) and study area are same. but cpp option is different. the two models can compile sucessfully. however, this one (adding some dynamical cpp options) can not run sucessfully and showed " insufficient virtual memory"
thanks so much for your time!
model name : Intel(R) Xeon(R) CPU E5-4640 0 @ 2.40GHz
physical id : 0
physical id : 0
physical id : 0
physical id : 0
physical id : 0
physical id : 0
physical id : 0
physical id : 0
physical id : 1
physical id : 1
physical id : 1
physical id : 1
physical id : 1
physical id : 1
physical id : 1
physical id : 1
physical id : 2
physical id : 2
physical id : 2
physical id : 2
physical id : 2
physical id : 2
physical id : 2
physical id : 2
physical id : 3
physical id : 3
physical id : 3
physical id : 3
physical id : 3
physical id : 3
physical id : 3
physical id : 3
physical id : 0
physical id : 0
physical id : 0
physical id : 0
physical id : 0
physical id : 0
physical id : 0
physical id : 0
physical id : 1
physical id : 1
physical id : 1
physical id : 1
physical id : 1
physical id : 1
physical id : 1
physical id : 1
physical id : 2
physical id : 2
physical id : 2
physical id : 2
physical id : 2
physical id : 2
physical id : 2
physical id : 2
physical id : 3
physical id : 3
physical id : 3
physical id : 3
physical id : 3
physical id : 3
physical id : 3
physical id : 3
