How do you access GRID variables that aren't called in tile?
aryansafaie
#1 Unread post by aryansafaie »
Dear ROMS Community,
I suppose this is more of a C-header file question, but:
I'm computing the total water depth at any horizontal location as
abs(z_w(i,j,N(ng))-z_w(i,j,0))
If, for example, I wanted to do this inside the body of ana_smflux.h,
how would I import the z_w variable?
I've trying locally declaring it (failed), I've tried using the extern keyword (failed).
Any guidance would be appreciated.
Thanks!
-aryan
Re: How do you access GRID variables that aren't called in t
ana_vmix.h has an example for z_r and z_w. Notice that z_w is slightly different as it has a range from 0:N, as compared to z_r that goes from 1:N.
