Hello every,
I try to couple swan and roms using COAWST model, to simulate how wave and tide dominate the sediment transport. I do this work folloeing the Inlet_Test. I made a 3 hour wind file to force the swan model, at the same time roms model only forced by tide. When I run them separately, both of them are successful. But when I coupled them, an error occured after runing several days.
I turned on DEBUG switch and the result as following. I have been confused 2 days, Can you tell me the reason? or give me some clues. Thank you very much!
+time 20160707.223000 , step 333; iteration 1; sweep 3 grid 1
2014 6 23:50:00 8.099446E-02 2.887666E+02 2.888476E+02 3.176563E+13
(166,231,20) 1.865871E-02 2.403729E-02 1.042405E+00 2.460445E+00
2015 6 23:55:00 8.120892E-02 2.887750E+02 2.888562E+02 3.176748E+13
(164,233,20) 1.729698E-02 2.088922E-02 1.168342E+00 2.442810E+00
2016 7 00:00:00 8.140875E-02 2.887843E+02 2.888657E+02 3.176956E+13
(164,233,20) 1.600080E-02 1.813718E-02 1.183052E+00 2.455510E+00
+time 20160707.223000 , step 333; iteration 1; sweep 4 grid 1
+time 20160707.230000 , step 334; iteration 1; sweep 1 grid 1
+time 20160707.230000 , step 334; iteration 1; sweep 2 grid 1
+time 20160707.230000 , step 334; iteration 1; sweep 3 grid 1
+time 20160707.230000 , step 334; iteration 1; sweep 4 grid 1
+time 20160707.233000 , step 335; iteration 1; sweep 1 grid 1
+time 20160707.233000 , step 335; iteration 1; sweep 2 grid 1
+time 20160707.233000 , step 335; iteration 1; sweep 3 grid 1
+time 20160707.233000 , step 335; iteration 1; sweep 4 grid 1
+time 20160708.000000 , step 336; iteration 1; sweep 1 grid 1
+time 20160708.000000 , step 336; iteration 1; sweep 2 grid 1
+time 20160708.000000 , step 336; iteration 1; sweep 3 grid 1
+time 20160708.000000 , step 336; iteration 1; sweep 4 grid 1
== SWAN grid 1 sent wave data to ROMS grid 1
forrtl: error (65): floating invalid
Image PC Routine Line Source
coawstG 0000000000EBF79C swoexa_ 4169 swanout1.f90
coawstG 0000000000E91137 swouto_ 828 swanout1.f90
coawstG 0000000000E3A3FF swan_cpl_ 731 swanmain.f90
coawstG 0000000000E047CC waves_control_mod 178 waves_control.f90
coawstG 00000000004385D2 MAIN__ 197 master.f90
coawstG 0000000000435ACC Unknown Unknown Unknown
libc.so.6 000000358481ED1D Unknown Unknown Unknown
coawstG 00000000004359C9 Unknown Unknown Unknown
** ROMS grid 1 recv data from SWAN grid 1
forrtl: error (78): process killed (SIGTERM)
mca_btl_sm.so 00007FB692012BAB Unknown Unknown Unknown
libmpi.so.1 00007FB69A8C7E39 Unknown Unknown Unknown
libmpi.so.1 00007FB69A7FA472 Unknown Unknown Unknown
mca_coll_tuned.so 00007FB6911458EE Unknown Unknown Unknown
mca_coll_tuned.so 00007FB69114C918 Unknown Unknown Unknown
libmpi.so.1 00007FB69A8079DA Unknown Unknown Unknown
libmpi_f77.so.1 00007FB69ABB7958 Unknown Unknown Unknown
coawstG 00000000009D006D distribute_mod_mp 3695 distribute.f90
coawstG 000000000044E7E1 ocean_coupler_mod 988 ocean_coupler.f90
coawstG 0000000000449B7F ocean_coupler_mod 777 ocean_coupler.f90
coawstG 0000000000455F1C ocean_coupler_mod 1358 ocean_coupler.f90
coawstG 0000000000489B10 main3d_ 181 main3d.f90
coawstG 0000000000439E4B ocean_control_mod 185 ocean_control.f90
coawstG 00000000004387E8 MAIN__ 211 master.f90
an error about coupled SWAN and ROMS model
Re: an error about coupled SWAN and ROMS model
Ideally, you might want to have winds in both ROMS and SWAN for the coupled runs. If you provide SWAN with wind forcing, ROMS will not know unless you create a ROMS wind forcing file too. That, or you can set a surface stress in ROMS using ANA_SMFLUX.
Regarding the SWAN error, SWAN outputs PRINT and ERRFILES. What do these say? This could give you a clue of what's missing.
Also, make sure that you have this in your header file
#define ROMS_MODEL
#define SWAN_MODEL
#define MCT_LIB
#define ROMS_MODEL
#define SWAN_MODEL
#define MCT_LIB
