When trying to change the sediment bed to have a non-uniform thickness in the entire domain, I added the following code to ana_sediment:
> # if defined unised
> DO j=JstrT,JendT
> DO i=IstrT,IendT
> DO k=1,Nbed
> bed(i,j,k,iaged)=time(ng)
> bed(i,j,k,ithck)=0.10_r8
> bed(i,j,k,iporo)=0.90_r8
> bed_frac(i,j,k,1)=1.0_r8
> END DO
> ! Set exposed sediment layer properties.
> bottom(i,j,irlen)=0.10_r8
> bottom(i,j,irhgt)=0.01_r8
> bottom(i,j,izdef)=Zob(ng)
> # elif defined SHELFSED
> DO j=JstrT,JendT
> DO i=IstrT,IendT
> val4=REAL(Lm(ng)+1-i,r8)
> ! Set bed layer properties.
> IF(val4.le.20.0_r8) THEN
> DO k=1,Nbed
> END DO
> ELSE IF(val4.le.25.0_r8) THEN
> DO k=1,Nbed
> bed(i,j,k,ithck)=0.10_r8*cos((val4-21)*pi/8)
> END DO
> ELSE
> DO k=1,Nbed
> bed(i,j,k,ithck)=0.0_r8
> bed(i,j,k,iporo)=0.9_r8
> END DO
> bottom(i,j,irlen)=0.0_r8
> bottom(i,j,irhgt)=0.0_r8
> END IF
> END DO
> END DO
> # endif
Since making this change, I've been getting the LBC_GETATT error when trying to restart from a previous solution.
I have tried changing the ana_sediment.h file back, I've tried overwriting it with a different file that I know to work, but this does not solve the problem.
Does anyone have experience with this issue? I guess I could just activate the #define NO_LBC_ATT option, but it seems like this should not be necessary when running 3.7
