Hello~
i want to know the method of restart
i just know that LcycleRST set T.
1) How can I do if i do restart. Please give some information in detail.
and also 2) when i run model. the start time is 56658 and then i run model during 1 day.
but, the ocean_time in restart file is 484890400. I think it is wrong. how can i do??
Please help me~
Hi~ i want to know restart(hot start) method
Re: Hi~ i want to know restart(hot start) method
On restart, I need to:kobl1201 wrote:Hello~
Please help me~
* increase NTIMES
* set NRREC=-1
* perhaps set LDEFOUT=F
* change ININAME to the name of the restart file
So DSTART is 56658? What is your time origin? ocean_time in the restart file is time in seconds while the DSTART is time in days. Your value divided by 86400 (seconds/day) is only 5612, so you are right, something is odd there.
when i set DSTART = 56109, the ocean_time in restart file is 4832179200.
But i set boundary file from 55927 to 56292.
if i devide 4832179200/86400, it is 55928.
you mean that i just change ININAME to the name of the restart file, even though the ocean_time in restart file is 4832179200. Is it right??
Yes, that's right.
Hi Kate~
i changed ININAME to restart file. however, i have some problems.
the model didn't run.
the model show like this.
SET_NGFLD - current model time exceeds ending value for variable: zeta_west
TDAYS = 55928.0000
Data Tmin = 55927.0000 Data Tmax = 56292.0000
Data Tstr = 56292.0000 Data Tend = 55927.0000
TINTRP1 = 55926.0000 TINTRP2 = 55927.0000
FAC1 = -1.0000 FAC2 = 2.0000
Elapsed CPU time (seconds):
Node # 0 CPU: 2.540 Node # 2 CPU: 2.540
Node # 3 CPU: 2.540
Node # 4 CPU: 2.540
Node # 8 CPU: 2.539
Node # 10 CPU: 2.539
Node # 1 CPU: 2.540
Node # 5 CPU: 2.540
Node # 6 CPU: 2.540
Node # 7 CPU: 2.540
Node # 9 CPU: 2.539
Node # 11 CPU: 2.539
Node # 13 CPU: 2.539
Node # 14 CPU: 2.539
Node # 15 CPU: 2.539
Analytical header files used:
ROMS/Functionals/ana_btflux.h
REASON: No error
Node # 12 CPU: 2.539
How can i do??
all time of boundary and other forcing data set for 1 year in the model.
I want to test restart method, so i just run 1 day.
TDAYS = 55928.0000
Node # 3 CPU: 2.540
Node # 4 CPU: 2.540
Node # 8 CPU: 2.539
Node # 1 CPU: 2.540
Node # 5 CPU: 2.540
Node # 6 CPU: 2.540
Node # 7 CPU: 2.540
Node # 9 CPU: 2.539
REASON: No error
How can i do??
- Location: Technical University of Cartagena,Murcia, Spain
I am not an expert but:
It seems that you want to run de model (NTIMES) longer that the data available in your boundary file. So, you have to use a lower value for NTIMES or produce a new boundary file with more data.
I hope I have been able to help you and let´s wait to know what think the more experienced people.
-Francisco
-Francisco
