Dear All,,
i am doing spinup of my model using 3hourly data,,after sime time its blowup,,please any body help me, here i mentioned my specifications..
Sunday - August 7, 2016 - 11:53:40 AM
Indian Ocean ROMS #4, 0.75 Resolution
Operating system : Linux
CPU/hardware : x86_64
Compiler system : ifort
Compiler command : /apps/mvapich2-gcc/bin/mpif90
Compiler flags : -heap-arrays -fp-model precise -ip -O2 -msse4.2 -free -free -free -free -free
Input Script :
SVN Revision : exported
Local Root : /home/sreeja/ROMS/models/roms_new_12may2016
Header Dir : /home/sreeja/ROMS/models/roms_new_12may2016/ROMS/Include
Header file : indian_bio_kpp.h
Analytical Dir: /home/sreeja/ROMS/models/roms_new_12may2016/ROMS/Functionals
Resolution, Grid 01: 0359x0251x040, Parallel Nodes: 288, Tiling: 018x016
4891429 ntimes Number of timesteps for 3-D equations.
200.000 dt Timestep size (s) for 3-D equations.
54 ndtfast Number of timesteps for 2-D equations between
10519200 nRST Number of timesteps between the writing of data
into restart fields.
to standard output.
13149 nHIS Number of timesteps between the writing fields
into history file.
13149 ndefHIS Number of timesteps between creation of new
time-averaged data.
13149 nAVG Number of timesteps between the writing of
13149 ndefAVG Number of timesteps between creation of new
time-averaged file.
3.0000E+01 nl_tnu2(01) NLM Horizontal, harmonic mixing coefficient
(m2/s) for tracer 01: temp
3.0000E+01 nl_tnu2(02) NLM Horizontal, harmonic mixing coefficient
(m2/s) for tracer 02: salt
1.5000E+03 nl_visc2 NLM Horizontal, harmonic mixing coefficient
(m2/s) for momentum.
for tracer 02: salt
1.0000E+01 blk_ZQ Height (m) of surface air humidity measurement.
1.0000E+01 blk_ZT Height (m) of surface air temperature measurement.
1.0000E+01 blk_ZW Height (m) of surface winds measurement.
1 lmd_Jwt Jerlov water type.
7.0000E+00 theta_s S-coordinate surface control parameter.
2.0000E-01 theta_b S-coordinate bottom control parameter.
50.000 Tcline S-coordinate surface/bottom layer width (m) used
19910101.00 time_ref Reference time for units attribute (yyyymmdd.dd)
7.0000E+00 Tnudg(01) Nudging/relaxation time scale (days)
7.0000E+00 Tnudg(02) Nudging/relaxation time scale (days)
86,1 0%
146591 339 07:56:40 2.289597E-01 2.025764E+04 2.025787E+04 1.377060E+17
(070,026,14) 1.744474E-03 8.501117E-03 8.246943E-01 1.378543E+01
146592 339 08:00:00 2.289640E-01 2.025764E+04 2.025787E+04 1.377060E+17
(070,026,14) 1.772011E-03 8.507054E-03 8.243036E-01 1.378671E+01
146593 339 08:03:20 2.289688E-01 2.025764E+04 2.025787E+04 1.377060E+17
(070,026,14) 1.805437E-03 8.518298E-03 8.239647E-01 1.378790E+01
146594 339 08:06:40 2.289744E-01 2.025764E+04 2.025786E+04 1.377060E+17
(070,026,14) 1.838203E-03 8.540065E-03 8.236464E-01 1.378899E+01
146595 339 08:10:00 2.289809E-01 2.025764E+04 2.025786E+04 1.377060E+17
(070,026,14) 1.867016E-03 8.565792E-03 8.232082E-01 1.378945E+01
146596 339 08:13:20 2.289884E-01 2.025763E+04 2.025786E+04 1.377060E+17
(070,026,14) 1.893750E-03 8.588623E-03 8.226556E-01 1.378988E+01
146597 339 08:16:40 2.289974E-01 2.025763E+04 2.025786E+04 1.377060E+17
(070,026,14) 1.918078E-03 8.610913E-03 8.221626E-01 1.379024E+01
146598 339 08:20:00 2.290091E-01 2.025763E+04 2.025786E+04 1.377060E+17
(071,028,14) 1.216343E-02 5.734914E-02 8.066521E-01 1.464840E+01
146599 339 08:23:20 2.290240E-01 2.025763E+04 2.025786E+04 1.377060E+17
(071,028,13) 1.132072E-02 6.766856E-02 7.941535E-01 1.803783E+01
146600 339 08:26:40 2.290422E-01 2.025763E+04 2.025786E+04 1.377060E+17
(071,028,13) 1.024490E-02 6.119128E-02 8.640672E-01 2.063136E+01
Elapsed CPU time (seconds):
Node # 0 CPU: 446.057
Node # 2 CPU: 450.393
Node # 4 CPU: 450.991
Node # 1 CPU: 451.185
Node #156 CPU: 451.318
Node #180 CPU: 451.324
Node #266 CPU: 451.236
Node #216 CPU: 451.314
Nod
Allocation and array initialization .............. 6.424 ( 0.0049 %)
Ocean state initialization ....................... 4.395 ( 0.0034 %)
Reading of input data ............................ 724.387 ( 0.5574 %)
Processing of input data ......................... 8273.476 ( 6.3668 %)
Processing of output time averaged data .......... 959.304 ( 0.7382 %)
Computation of vertical boundary conditions ...... 23.033 ( 0.0177 %)
Computation of global information integrals ...... 509.136 ( 0.3918 %)
Writing of output data ........................... 3931.005 ( 3.0251 %)
Model 2D kernel .................................. 28404.559 (21.8586 %)
2D/3D coupling, vertical metrics ................. 1522.520 ( 1.1717 %)
Omega vertical velocity .......................... 672.822 ( 0.5178 %)
Equation of state for seawater ................... 1711.541 ( 1.3171 %)
Biological module, source/sink terms ............. 3992.792 ( 3.0726 %)
Atmosphere-Ocean bulk flux parameterization ...... 376.487 ( 0.2897 %)
KPP vertical mixing parameterization ............. 4466.511 ( 3.4372 %)
3D equations right-side terms .................... 544.740 ( 0.4192 %)
3D equations predictor step ...................... 6905.577 ( 5.3142 %)
Pressure gradient ................................ 692.987 ( 0.5333 %)
Harmonic mixing of tracers, geopotentials ........ 4951.128 ( 3.8101 %)
Biharmonic mixing of tracers, geopotentials ...... 276.834 ( 0.2130 %)
Harmonic stress tensor, S-surfaces ............... 551.194 ( 0.4242 %)
Corrector time-step for 3D momentum .............. 1832.092 ( 1.4099 %)
Corrector time-step for tracers .................. 56930.702 (43.8108 %)
Total: 128263.646 98.7049
Message Passage: 2D halo exchanges ............... 17895.924 (13.7717 %)
Message Passage: 3D halo exchanges ............... 4150.566 ( 3.1941 %)
Message Passage: 4D halo exchanges ............... 19935.049 (15.3409 %)
Message Passage: data broadcast .................. 4794.952 ( 3.6899 %)
Message Passage: data reduction .................. 11738.791 ( 9.0335 %)
Message Passage: data gathering .................. 188.869 ( 0.1453 %)
Message Passage: data scattering.................. 559.740 ( 0.4307 %)
Total: 59263.893 45.6063
All percentages are with respect to total time = 129946.643
Analytical header files used:
ROMS/Functionals/ana_btflux.h
ROMS/Functionals/ana_stflux.h
Biology model header files used:
ROMS/Nonlinear/Biology/fennel.h
7590,2 Bot
please anybody help.. before that i trying with timestep 900sce, 600sec,,its also initially blowup,, if i using 200sec,, after some time steps it blow up,,,
