Is CFSR server is down
atul
#1 Unread post by atul »
Hi
I am trying to download CFSR data using make_CFSR
I was downloading the data successfully then I am getting error
reapdap failed after 100 attempts of retrying
for error have a look below
>> make_CFSR
mkdir: cannot create directory ‘/home/atul/ROMS/Roms_tools/Run/ROMS_FILES/’: File exists
Read in the grid /home/atul/ROMS/Roms_tools/Run/ROMS_FILES/roms_grd.nc
BEGIN DOWNLOAD STEP
Download CFSR data with OPENDAP
Get CFSR data from 1983 to 1983
From http://nomads.ncdc.noaa.gov/thredds/dod ... /cmd_flxf/
Minimum Longitude: 77.4575
Maximum Longitude: 89.5256
Minimum Latitude: 4.0522
Maximum Latitude: 18.4906
Making output data directory /home/atul/ROMS/Roms_tools/Run/DATA/CFSR_BOB_SDomeT_1/
mkdir: cannot create directory ‘/home/atul/ROMS/Roms_tools/Run/DATA/CFSR_BOB_SDomeT_1/’: File exists
VNAME IS Land_cover_1land_2sea
Get time units and time: Get_My_Data is OFF
READDAP: reading time
GET SUBGRID time only k=1
USE VARIABLE: Land_cover_1land_2sea
Get_My_Data =0
READDAP: reading lon
READDAP: reading lat
GET LAND MASK
READDAP: reading Land_cover_1land_2sea
Create /home/atul/ROMS/Roms_tools/Run/DATA/CFSR_BOB_SDomeT_1/Land_cover_1land_2sea.nc
VNAME IS Upward_Long-Wave_Rad_Flux
Processing year: 1983
Processing month: 1
Get Upward_Long-Wave_Rad_Flux for year 1983 - month 1
Downloading Upward_Long-Wave_Rad_Flux for 01-Jan-1983
READDAP: did not work at 1 try: lets try again.
READDAP: did not work at 2 try: lets try again.
READDAP: did not work at 3 try: lets try again.
READDAP: did not work at 4 try: lets try again.
READDAP: did not work at 5 try: lets try again.
READDAP: did not work at 6 try: lets try again.
READDAP: did not work at 7 try: lets try again.
READDAP: did not work at 8 try: lets try again.
READDAP: did not work at 9 try: lets try again.
READDAP: did not work at 10 try: lets try again.
READDAP: did not work at 11 try: lets try again.
READDAP: did not work at 12 try: lets try again.
READDAP: did not work at 13 try: lets try again.
READDAP: did not work at 14 try: lets try again.
READDAP: did not work at 15 try: lets try again.
READDAP: did not work at 16 try: lets try again.
READDAP: did not work at 17 try: lets try again.
READDAP: did not work at 18 try: lets try again.
READDAP: did not work at 19 try: lets try again.
READDAP: did not work at 20 try: lets try again.
READDAP: did not work at 21 try: lets try again.
READDAP: did not work at 22 try: lets try again.
READDAP: did not work at 23 try: lets try again.
READDAP: did not work at 24 try: lets try again.
READDAP: did not work at 25 try: lets try again.
READDAP: did not work at 26 try: lets try again.
READDAP: did not work at 27 try: lets try again.
READDAP: did not work at 28 try: lets try again.
READDAP: did not work at 29 try: lets try again.
READDAP: did not work at 30 try: lets try again.
READDAP: did not work at 31 try: lets try again.
READDAP: did not work at 32 try: lets try again.
READDAP: did not work at 33 try: lets try again.
READDAP: did not work at 34 try: lets try again.
READDAP: did not work at 35 try: lets try again.
READDAP: did not work at 36 try: lets try again.
READDAP: did not work at 37 try: lets try again.
READDAP: did not work at 38 try: lets try again.
READDAP: did not work at 39 try: lets try again.
READDAP: did not work at 40 try: lets try again.
READDAP: did not work at 41 try: lets try again.
READDAP: did not work at 42 try: lets try again.
READDAP: did not work at 43 try: lets try again.
READDAP: did not work at 44 try: lets try again.
READDAP: did not work at 45 try: lets try again.
READDAP: did not work at 46 try: lets try again.
READDAP: did not work at 47 try: lets try again.
READDAP: did not work at 48 try: lets try again.
READDAP: did not work at 49 try: lets try again.
READDAP: did not work at 50 try: lets try again.
READDAP: did not work at 51 try: lets try again.
READDAP: did not work at 52 try: lets try again.
READDAP: did not work at 53 try: lets try again.
READDAP: did not work at 54 try: lets try again.
READDAP: did not work at 55 try: lets try again.
READDAP: did not work at 56 try: lets try again.
READDAP: did not work at 57 try: lets try again.
READDAP: did not work at 58 try: lets try again.
READDAP: did not work at 59 try: lets try again.
READDAP: did not work at 60 try: lets try again.
READDAP: did not work at 61 try: lets try again.
READDAP: did not work at 62 try: lets try again.
READDAP: did not work at 63 try: lets try again.
READDAP: did not work at 64 try: lets try again.
READDAP: did not work at 65 try: lets try again.
READDAP: did not work at 66 try: lets try again.
READDAP: did not work at 67 try: lets try again.
READDAP: did not work at 68 try: lets try again.
READDAP: did not work at 69 try: lets try again.
READDAP: did not work at 70 try: lets try again.
READDAP: did not work at 71 try: lets try again.
READDAP: did not work at 72 try: lets try again.
READDAP: did not work at 73 try: lets try again.
READDAP: did not work at 74 try: lets try again.
READDAP: did not work at 75 try: lets try again.
READDAP: did not work at 76 try: lets try again.
READDAP: did not work at 77 try: lets try again.
READDAP: did not work at 78 try: lets try again.
READDAP: did not work at 79 try: lets try again.
READDAP: did not work at 80 try: lets try again.
READDAP: did not work at 81 try: lets try again.
READDAP: did not work at 82 try: lets try again.
READDAP: did not work at 83 try: lets try again.
READDAP: did not work at 84 try: lets try again.
READDAP: did not work at 85 try: lets try again.
READDAP: did not work at 86 try: lets try again.
READDAP: did not work at 87 try: lets try again.
READDAP: did not work at 88 try: lets try again.
READDAP: did not work at 89 try: lets try again.
READDAP: did not work at 90 try: lets try again.
READDAP: did not work at 91 try: lets try again.
READDAP: did not work at 92 try: lets try again.
READDAP: did not work at 93 try: lets try again.
READDAP: did not work at 94 try: lets try again.
READDAP: did not work at 95 try: lets try again.
READDAP: did not work at 96 try: lets try again.
READDAP: did not work at 97 try: lets try again.
READDAP: did not work at 98 try: lets try again.
READDAP: did not work at 99 try: lets try again.
READDAP: did not work at 100 try: lets try again.
READDAP: did not work at 101 try: lets try again.
Error using readdap (line 46)
READDAP: repeated failures after 100 queries
Error in getdap (line 48)
var=readdap(url,vname,[trange,krange,jrange,irange]);
Error in extract_CFSR (line 101)
var0=getdap(url,fname,vname,...
Error in download_CFSR (line 167)
extract_CFSR(NCEP_dir,ncep_url,char(catalog(k)),...
Error in make_CFSR (line 99)
download_CFSR(Ymin,Ymax,Mmin,Mmax,lonmin,lonmax,latmin,latmax,...
now I am getting this error again and again
My friend told me this happens sometime
does it mean that CFSR server is down ?
how i can check if CFSr server is down? can we check it?
sflin
Re: Is CFSR server is down
#2 Unread post by sflin »
Has your problem been solved? I came across the same issues. I am looking for your help. Have you figured out how to address this problem? Thank you very much for your help!
:D :D :D
sflin
camidemello
#3 Unread post by camidemello »
Hi, I am having the same problem, is the server still down?
Is it possible to mannually download cfsr data? If so could someone give me the url?
#4 Unread post by wilkin »
Over a year ago all US Federal web services were required to switch to secure http, so at the very least your script needs updating to access opendap using https://...
But you should double-check to URL to the CFSR data online at https://nomads.ncdc.noaa.gov/thredds/ca ... talog.html
to see if you need any other updates to that code.
