ROMS&SWAN coupling, Segmentation Fault
donghua
#1 Unread post by donghua »
Hello, all
I've tried to run a ROMS&SWAN coupling case. But I got the segmentation fault error. So I turned on
USE_DEBUG=on
In the debug mode, I got the message below:
SWAN grid   1 is preparing computation
0: Subscript out of range for array globalsegmap_g (waves_coupler.f90: 331)
    subscript=1, lower bound=0, upper bound=-1, dimension=1
In waves_coupler.f90 file, the 331 line is:
          CALL Router_init (OCNid, GlobalSegMap_G(iw)%GSMapSWAN,        &
     &                      WAV_COMM_WORLD, Router_O(iw,ng)%SWANtoROMS)
I don't quite understand what is the problem here. Can anyone give me some clues? Thank you so much!
Donghua
Re: ROMS&SWAN coupling, Segmentation Fault
John Warner would say you should email him for permission to download his COAWST code, which includes SWAN, ROMS, WRF, etc.
donghua
#3 Unread post by donghua »
Hi, Kate
Thanks for your quick reply.
I've downloaded the latest COAWST code, and tried to rerun the case.
I updated some obsolete terms. The results of the rerun case is still the same:
0: Subscript out of range for array globalsegmap_g (waves_coupler.f90: 341)
Within waves_coupler.f90, line 341 is still:
Any suggestion?
Donghua
#4 Unread post by jcwarner »
can you post this on
https://coawstmodel-trac.sourcerepo.com ... del_COAWST
i think i will need to see your .h file.
did you compile with nesting and not have 2 swan grids?
donghua
#5 Unread post by donghua »
Hello, John
Thank you for your reply.
I will post this problem in COAWST Discussion.
Below is my .h file:
#define ROMS_MODEL
#define SWAN_MODEL
#define MCT_LIB
#define WEC_VF
#define WDISS_WAVEMOD
#define UV_U3HADVECTION
#define UV_C4VADVECTION
#define RADIATION_2D
#define UV_LOGDRAG
#define TS_U3HADVECTION
#define TS_C4VADVECTION
#define  MIX_GEO_TS
#define SPLINES_VVISC
#define SPLINES_VDIFF
#define RI_SPLINES
#undef ANA_GRID
#undef ANA_INITIAL
#undef ANA_SMFLUX
#undef ANA_STFLUX
#undef ANA_SSFLUX
#define BULK_FLUXES
#undef ATM_PRESS
#define LONGWAVE_OUT
#define EMINUSP
#define SOLAR_SOURCE
#define ADD_FSOBC
#define ADD_M2OBC
#define SSH_TIDES
#define UV_TIDES
#define RAMP_TIDES
#define GLS_MIXING
#else
# define ANA_VMIX
# define ANA_BIOLOGY
# undef ANA_SPFLUX
# define ANA_BPFLUX
# undef ANA_SRFLUX
Thanks again
Donghua
donghua
#6 Unread post by donghua »
Hi, John
The NESTING term is not turned on. There is only one grid in swan.
When I run SWAN-only or ROMS-only, both work.
But when SWAN and ROMS couple, the segmentation fault pops up.
donghua
#7 Unread post by donghua »
Hello, all
The problem is solved!
It is simply because it has not enough memory.
Thank you Kate and John.
Thank you all.
Donghua
