IO error in reading netcdf file
sankaras
#1 Unread post by sankaras »
I getting the following error, while running ROMS for an estuary application, with tides and river flow. Any clues about where the problem is?. I generated the grid using seagrid and edited the grid using editmask.
Sankar
OPENCDF - inconsistent size of dimension: xi_psi 59 61
ROMS/TOMS - IO error ................ exit_flag: 4
Elapsed CPU time (seconds):
Thread # 0 CPU: 0.078
Total: 0.078
Total: 0.000 0.0000
All percentages are with respect to total time = 0.078
ERROR: OPENCDF - Can not open NetCDF file.
REASON: No error
My cpp options were:
ESTUARY_TEST Suspended Sediment Test in an Estuary
AVERAGES Writing out time-averaged fields.
AVERAGES_AKS Writing out time-averaged vertical S-diffusion.
EASTERN_WALL Wall boundary at Eastern edge.
NONLINEAR Nonlinear Model.
NORTHERN_WALL Wall boundary at Northern edge.
PRSGRD31 Standard density Jacobian formulation (Song, 1998).
K_GSCHEME Third-order upstream bias advection of TKE fields.
RHO_SURF Include difference between rho0 and surface density.
SALINITY Using salinity.
SOUTH_FSCLAMPED Southern edge, free-surface, Clamped condition.
SOUTH_M2REDUCED Southern edge, 2D momentum, reduced-physics condition.
SOUTH_M3RADIATION Southern edge, 3D momentum, radiation condition.
SOUTH_TCLAMPED Southern edge, tracers, Clamped condition.
TS_U3HADVECTION Third-order upstream bias horizontal advection of tracers.
UV_ADV Advection of momentum.
UV_U3HADVECTION Third-order upstream bias advection of momentum.
WESTERN_WALL Wall boundary at Western edge.
the error is inconsistent size of dimensions.
So your grid has a set of dimensions, the input file has a set of dimensions, the forcing files have grid dimensions, etc etc.
They all need to be consistent.
One needs to be careful. In the x-direction, the grid dimensions for the number of rho points goes from 0 to L.
LP=L+1, so 0:L = LP.
The input file wants Lm , and Lm = L-1.
Similar in y.
There have been other posts in this for you to search.
This is the kind of info that needs to be added to the wiki, so that we only have to do this once. Kate or Hernan had a nice set of grid patterns that could be put on
https://www.myroms.org/wiki/index.php?t ... Generation
sankaras
#3 Unread post by sankaras »
John,
Yes, I had the wrong dimensions in the input file. I should have carefully read the glossary at the end of the input file.
Lm Number of INTERIOR grid RHO-points in the XI-direction for
! each nested grid, [1:Ngrids]. If using NetCDF files as
! input, Lm=xi_rho-2 where "xi_rho" is the NetCDF file
! dimension of RHO-points. Recall that all RHO-point
! variables have a computational I-range of [0:Lm+1].
! Mm Number of INTERIOR grid RHO-points in the ETA-direction for
! input, Mm=eta_rho-2 where "eta_rho" is the NetCDF file
! variables have a computational J-range of [0:Mm+1].
Thanks very much for your help.
Sankar
