When I tried to run the upwelling application, I met this:
rm -f -r core *.ipo /home/kekejiayu/Projects/upwelling/Build /home/kekejiayu/make_macros.mk
makefile:238: INCLUDING FILE /home/kekejiayu/make_macros.mk WHICH CONTAINS APPLICATION-DEPENDENT MAKE DEFINITIONS
cp -f /usr/local/include/netcdf.mod /home/kekejiayu/Projects/upwelling/Build
cp: cannot stat ‘/usr/local/include/netcdf.mod’: No such file or directory
make: *** No rule to make target '/home/kekejiayu/Projects/upwelling/Build/netcdf.mod', needed by '/home/kekejiayu/Projects/upwelling/Build/MakeDepend'. Stop.
I have no idea about this.
about upwelling case
Re: about upwelling case
Do you have the Netcdf library and the Netcdf-fortran library? You need to have both. This should be added to the FAQ - I'll try to get to it later.cp -f /usr/local/include/netcdf.mod /home/kekejiayu/Projects/upwelling/Build
I had the same problem, Could you plese tell me how to address this in the end?
Mr.kekejiayu
I am a graduate student major in ocean Modeling,and I am doing research using LTRANS now.May I have you email for further discussion?My email is yhq123@mail.ustc.edu.cn.I am loooking forward your reply.
Yin Heqing
8/15/2018
Yin Heqing
8/15/2018
