Ocean Modeling position at Harbor Branch Oceanographic Inst.
FAU's Harbor Branch Oceanographic Institute is seeking a coastal ocean modeler. The main job is to implement and test coupled physical-biogeochemical models for various coastal and shelf regions. The duties also include preparation of scientific reports, presentations and/or publications, and occasionally assisting in field work. Experience with ocean modeling is a must. Knowledge in biogeochemistry is a plus. Minimum education requirement is BS degree plus 3 years modeling experience, or MS degree plus 1 year modeling experience. Salary ranges $38,000-$45,000. Initial appointment will be one year. More details see attached job description. Apply online: https://jobs.fau.edu. For job inquiry, contact jiangm@fau.edu.
- Jiang_tech_jobdesc.pdf
- job description
- (57.22 KiB) Downloaded 704 times
Re: Ocean Modeling position at Harbor Branch Oceanographic I
This job is reopened for search - The interview will begin immediately until the post is filled. Thank you for your attention.
- ResearchTech_jobdesc_1-14-16.pdf
- (58.97 KiB) Downloaded 659 times
