model blow-up due to abnormal velocity
rcxy
#1 Unread post by rcxy »
when i add tide, the modle blow up . I find, maybe because the velocity too large.
I check the tide forcing file, there is nothing wrong in it. Why the model blow up ?
huangminfen
Re: model blow-up due to abnormal velocity
#2 Unread post by huangminfen »
hi,i've got the same problem as you.Have you solved it? Can you tell me how to fix it ?
nmichelet
#3 Unread post by nmichelet »
I have the same problem, did you find how to fix it?
#4 Unread post by jcwarner »
very difficult to determine what is happening from that image.
Maybe you need to use a tide ramp:
#define RAMP_TIDES
and see if that helps.
susonic
#5 Unread post by susonic »
1. What if you run the model without tide? Does it still blow up?
2. What if you reduce the time step? Say, half from current time step.
-JH
Joonho Lee
nmichelet
#6 Unread post by nmichelet »
I already use the tide_ramp option, so I don't think this is the problem.
I also try do run it with a little time step, it takes a long time, but it still blow up at the same time. I think there is a problem with the Wet_Dry option, because I have some velocity which blows up near the coast
You can see on this picture that the velocity near the coast explode and is directed toward the coast.
hpftcb
#7 Unread post by hpftcb »
Hi, I have the same problem with high velocity near the coast (resulting in model blow up). Did you solve yours?
Regards,
Fernando
#8 Unread post by kate »
Are you using the WET_DRY option? How shallow is your coastal water?
hpftcb
#9 Unread post by hpftcb »
Hi Kate,
no, I'm not using WetDry and my shelf region has very shallow parts. I am gonna try that.
Thank you.
