I wanna to make my model closer to the hycom in order to run some sensitive experiments.I use the hycom data as the boundary and initial condition.The only force is wind from CFRS.
The outcome is bad,and I suspect that I don't set the parameters well because most of them are difficult to undertand. I also upload the model output as a picture which compares to the hycom.You can see the Kuroshio intrusion is so strong even form an eddy in the western of Luzon strait.
Here are my parameters.I wonder that someone could give me advice and point out some obvious mistakes.
(m2/s) for momentum.
for tracer 02: salt
for turbulent energy.
-1.000 gls_p GLS stability exponent.
0.500 gls_m GLS turbulent kinetic energy exponent.
5.5500E-01 gls_c1 GLS shear production coefficient.
8.3300E-01 gls_c2 GLS dissipation coefficient.
-6.0000E-01 gls_c3m GLS stable buoyancy production coefficient.
2.0000E+00 gls_sigk GLS constant Schmidt number for TKE.
2.0000E+00 gls_sigp GLS constant Schmidt number for PSI.
3.0000E-03 Zob Bottom roughness (m).
1.0000E-03 Zos Surface roughness (m).
7.0000E+00 theta_s S-coordinate surface control parameter.
300.000 Tcline S-coordinate surface/bottom layer width (m) used
1028.000 rho0 Mean density (kg/m3) for Boussinesq approximation.
2.0000E+00 Tnudg(01) Nudging/relaxation time scale (days)
2.0000E+00 Tnudg(02) Nudging/relaxation time scale (days)
for tracer 02: salt
1.0000E-03 Znudg Nudging/relaxation time scale (days)
1.0000E-03 M2nudg Nudging/relaxation time scale (days)
1.0000E-03 M3nudg Nudging/relaxation time scale (days)
for 3D momentum.
5.0000E+00 obcfac Factor between passive and active
Here is my .h file.
#undef UV_LOGDRAG
#undef UV_SMAGORINSKY
#ifdef UV_VIS2
# define VISC_GRID
# define MIX_S_UV
#define TS_MPDATA
#undef TS_DIF2
#ifdef TS_DIF2
# define DIFF_GRID
# define MIX_S_TS
#define SPLINES
#define SPHERICAL
#define AVERAGES_AKV
#define AVERAGES_AKT
#define AVERAGES_AKS
#define AVERAGES_FLUXES
#undef DIAGNOSTICS_UV
#undef DIAGNOSTICS_TS
#undef FSOBC_REDUCED
#undef EAST_FS_REDUCED
#undef WEST_FS_REDUCED
#undef NORTH_FS_REDUCED
#define PERFECT_RESTART
#undef TCLIMATOLOGY
#undef TCLM_NUDGING
#define RADIATION_2D
#define GLS_MIXING
#undef MY25_MIXING
# undef CANUTO_A
#undef SEDIMENT
#ifdef SEDIMENT
# define SUSPLOAD
# undef SED_DENS
# undef wsed_power
# undef no_deposition
#undef ANA_PSOURCE
#undef ANA_GRID
#undef ANA_INITIAL
#undef ANA_SEDIMENT
#undef ANA_SMFLUX
#define ANA_STFLUX
#define ANA_SSFLUX
#define ANA_SPFLUX
#define ANA_BPFLUX
#undef ANA_FSOBC
#undef ANA_M2OBC
#undef ANA_M3OBC
#undef ANA_TOBC
#undef ANA_TCLIMA
#undef ANA_VMIX
Any suggestions are welcome!
