Hello Roms community,
I am using the tropflux daily climatology data forcings (Tair,swrad, lwrad, Qair, Pair from coreV2) and GPCP data for rainfall rate and Uwind & Vwind from quikscat data. The current setup is a trial to run a 10 years climatological run for the domain [35E to 90E & 25S to 20N] and resolution is 1/4. But model is blowing in the second time step itself. description of log file is under mentioned.
ndtfast, nfast = 50 69 nfast/ndtfast = 1.38000
1.000000000000 1.033396903681 0.516698451840 1.000000000000 1.000000000000
Power filter parameters, Fgamma, gamma = 0.28400 0.22720
Minimum X-grid spacing, DXmin = 2.51801363E+01 km
Maximum X-grid spacing, DXmax = 2.77831716E+01 km
Minimum Y-grid spacing, DYmin = 2.52032577E+01 km
Maximum Y-grid spacing, DYmax = 2.77831405E+01 km
Minimum Z-grid spacing, DZmin = 1.25073687E+00 m
Maximum Z-grid spacing, DZmax = 7.52012906E+02 m
Minimum barotropic Courant Number = 3.40694121E-02
Maximum barotropic Courant Number = 2.98301057E-01
Maximum Coriolis Courant Number = 7.37608015E-02
Horizontal mixing scaled by grid size, GRDMAX = 2.77831249E+01 km
Minimum horizontal diffusion coefficient = 2.09930786E+02 m2/s
Maximum horizontal diffusion coefficient = 2.31526041E+02 m2/s
Minimum horizontal viscosity coefficient = 2.09930786E+02 m2/s
Maximum horizontal viscosity coefficient = 2.31526041E+02 m2/s
(Grid 01, File: roms_ini.nc, Rec=0001, Index=1)
- free-surface
- u-momentum component
- v-momentum component
- potential temperature
(Min = 6.12046405E-01 Max = 2.96272088E+01)
- salinity
(Min = 3.07662600E+01 Max = 4.06677452E+01)
GET_2DFLD - surface u-wind component, t = 0 00:00:00
(Rec=0000001, Index=1, File: uwind.nc)
(Tmin= 0.0000 Tmax= 364.0000)
(Min = -8.86058779E+00 Max = 1.00000000E+20)
GET_2DFLD - surface v-wind component, t = 0 00:00:00
(Rec=0000001, Index=1, File: vwind.nc)
(Min = -8.67955616E+00 Max = 1.00000000E+20)
GET_2DFLD - surface air pressure, t = 0 00:00:00
(Rec=0000001, Index=1, File: surface_pres.nc)
(Min = 1.00951002E+03 Max = 1.02011134E+03)
GET_2DFLD - solar shortwave radiation flux, t = 345 00:00:00
(Rec=0000012, Index=1, File: roms_frc.nc)
(Min = 3.97214003E-05 Max = 7.47180066E-05)
GET_2DFLD - net longwave radiation flux, t = 0 00:00:00
(Rec=0000001, Index=1, File: longwave.nc)
(Min = -2.81343400E-05 Max = 2.44820516E+13)
GET_2DFLD - surface air temperature, t = 0 00:00:00
(Rec=0000001, Index=1, File: airtemp.nc)
(Min = 2.06291232E+01 Max = 1.00000000E+20)
GET_2DFLD - surface air specific humidity, t = 0 00:00:00
(Rec=0000001, Index=1, File: specific_hum.nc)
(Min = 9.47512199E+00 Max = 1.00000000E+20)
GET_2DFLD - rain fall rate, t = 0 00:00:00
(Rec=0000001, Index=1, File: precip.nc)
(Min = 0.00000000E+00 Max = 3.03253871E-04)
GET_2DFLD - sea surface salinity climatology, t = 345 00:00:00
(Min = 2.75694853E+01 Max = 3.96281540E+01)
(Rec=0000012, Index=2, File: roms_bry.nc)
(Min = -1.71301593E-01 Max = 1.30383335E-01)
(Min = -1.71301593E-01 Max = 8.02520623E+00)
GET_NGFLD - 3D u-momentum eastern boundary condition, t = 345 00:00:00
(Min = -2.30252428E-01 Max = 1.18584624E-01)
GET_NGFLD - 3D v-momentum eastern boundary condition, t = 345 00:00:00
(Min = -6.45121988E-02 Max = 1.28864014E-01)
GET_NGFLD - 3D u-momentum southern boundary condition, t = 345 00:00:00
(Min = -1.11475038E-02 Max = 7.97645937E-03)
GET_NGFLD - 3D v-momentum southern boundary condition, t = 345 00:00:00
(Min = -1.93501570E-01 Max = 7.76984871E-02)
GET_NGFLD - temperature eastern boundary condition, t = 345 00:00:00
(Min = 7.27592240E-01 Max = 2.86222639E+01)
GET_NGFLD - salinity eastern boundary condition, t = 345 00:00:00
(Min = 3.02278060E+01 Max = 3.58199364E+01)
GET_NGFLD - temperature southern boundary condition, t = 345 00:00:00
(Min = 6.13947362E-01 Max = 2.68585280E+01)
GET_NGFLD - salinity southern boundary condition, t = 345 00:00:00
(Min = 3.44397525E+01 Max = 3.58216616E+01)
Maximum grid stiffness ratios: rx0 = 2.154182E-01 (Beckmann and Haidvogel)
rx1 = 4.478907E+00 (Haney)
Initial basin volumes: TotVolume = 8.4646060247E+16 m3
MinVolume = 8.5321855646E+08 m3
MaxVolume = 5.8048028930E+11 m3
Max/Min = 6.8034184782E+02
NL ROMS/TOMS: started time-stepping: (Grid: 01 TimeSteps: 00000001 - 08064720)
GET_2DFLD - surface u-wind component, t = 1 00:00:00
(Rec=0000002, Index=2, File: uwind.nc)
(Min = -9.42937975E+00 Max = 1.00000000E+20)
GET_2DFLD - surface v-wind component, t = 1 00:00:00
(Rec=0000002, Index=2, File: vwind.nc)
(Min = -8.49320788E+00 Max = 1.00000000E+20)
GET_2DFLD - surface air pressure, t = 1 00:00:00
(Rec=0000002, Index=2, File: surface_pres.nc)
(Min = 1.00934552E+03 Max = 1.01951950E+03)
(Rec=0000001, Index=2, File: roms_frc.nc)
(Min = 4.14254984E-05 Max = 7.63300206E-05)
GET_2DFLD - net longwave radiation flux, t = 1 00:00:00
(Rec=0000002, Index=2, File: longwave.nc)
(Min = -2.80249039E-05 Max = 2.44820516E+13)
GET_2DFLD - surface air temperature, t = 1 00:00:00
(Rec=0000002, Index=2, File: airtemp.nc)
(Min = 2.04292793E+01 Max = 1.00000000E+20)
GET_2DFLD - surface air specific humidity, t = 1 00:00:00
(Rec=0000002, Index=2, File: specific_hum.nc)
(Min = 9.55675877E+00 Max = 1.00000000E+20)
GET_2DFLD - rain fall rate, t = 1 00:00:00
(Rec=0000002, Index=2, File: precip.nc)
(Min = 0.00000000E+00 Max = 2.52505480E-04)
(Min = 2.87745855E+01 Max = 3.86804531E+01)
(Rec=0000001, Index=1, File: roms_bry.nc)
(Min = -1.49242404E-01 Max = 1.21437297E-01)
(Min = -1.35165429E-01 Max = 8.02420879E+00)
(Min = -2.33005595E-01 Max = 1.00078927E-01)
(Min = -4.78489296E-02 Max = 1.75680212E-01)
(Min = -1.46073857E-02 Max = 7.39300480E-03)
(Min = -2.06468452E-01 Max = 6.61020167E-02)
(Min = 7.27592240E-01 Max = 2.88058121E+01)
(Min = 3.07662600E+01 Max = 3.58525282E+01)
(Min = 6.13947362E-01 Max = 2.75359423E+01)
(Min = 3.44510161E+01 Max = 3.58558299E+01)
0 0 00:00:00 0.000000E+00 1.993934E+04 1.993934E+04 8.519198E+16
(000,000,00) 0.000000E+00 0.000000E+00 0.000000E+00 0.000000E+00
DEF_HIS - creating history file, Grid 01: output/ocean_his_0001.nc
1 0 00:20:00 NaN NaN NaN NaN
(219,185,01) 0.000000E+00 0.000000E+00 0.000000E+00 0.000000E+00
WRT_RST - wrote re-start fields (Index=2,2) into time record = 0000001
Elapsed CPU time (seconds):
Node # 18 CPU: 3.657
Node # 22 CPU: 3.643
Node # 26 CPU: 3.648
Node # 30 CPU: 3.675
Node # 34 CPU: 3.645
Node # 0 CPU: 2.426
Node # 6 CPU: 3.672
Node # 24 CPU: 3.667
Node # 2 CPU: 3.656
Node # 4 CPU: 3.676
Node # 10 CPU: 3.670
Node # 14 CPU: 3.671
Node # 16 CPU: 3.668
Node # 20 CPU: 3.632
Node # 28 CPU: 3.637
Analytical header files used:
ROMS/Functionals/ana_btflux.h
ROMS/TOMS: DONE... Friday - July 24, 2015 - 9:04:10 PM
Node # 11 CPU: 3.665
Node # 15 CPU: 3.676
Node # 19 CPU: 3.644
Node # 23 CPU: 3.647
Node # 27 CPU: 3.606
Node # 31 CPU: 3.622
Node # 7 CPU: 3.651
Node # 17 CPU: 3.668
Node # 21 CPU: 3.656
Node # 25 CPU: 3.644
Node # 29 CPU: 3.678
Node # 33 CPU: 3.614
Node # 35 CPU: 3.623
Node # 1 CPU: 3.661
Node # 3 CPU: 3.664
Node # 5 CPU: 3.646
Node # 9 CPU: 3.669
Node # 13 CPU: 3.672
Node # 8 CPU: 3.652
Node # 12 CPU: 3.679
Node # 32 CPU: 3.637
please suggest some probable solution.
Best Regards-
Tara
issue to handle masked surface forcing files, model is blown
Re: issue to handle masked surface forcing files, model is b
There are many ways to get ROMS to blow up that quickly. I would check the forcing files first, though:
What is that 10E+20? A special land value?GET_2DFLD - surface u-wind component, t = 1 00:00:00
Hello Kate,
I am very grateful for your instant reply, yes you are correct, my tropflux data that I am using for Tair, Qair and quikscat(Uwind,Vwind) data both are masked over land , and my doubt was also on these masked values present in land points. But I am surprise that if model is not dealing with land points then how these values are creating problems and the question comes that ...
Q1> If I need to use this kind of masked land points data for forcing, how to process the data or provide to the model in a suitable manner, so that model will not blow?
Actually, I tried to solve this issue by providing some different domains so that these points will not come in the calculation (Avoiding NaN i.e. in the first time step). I tried this different domain setups & all of them was over Indian Ocean and less than the spatial range what my forcing files have.
Q2> can you kindly suggest me whether this issue can cause for blown up,if yes then how to make this data compatible with model?
With Best Regards--
Tara
With Best Regards--
Tara
I typically use MERRA, which has values everywhere. However, the land values are appropriate to say winds over land, not winds over water. My colleague Raphael has introduced us to a tool called sosie which we use to process the MERRA files, extrapolating water values into the land. This allows ROMS to do its interpolation to the ROMS ocean points using valid "wet" values even when the nearest wind point is actually a land point.
Another option would be to look into the ROMS interpolation code and perhaps replace it with something smarter about masked values. I've been hearing of groups switching over to ESMF now that it provides interpolation routines. I'd be interested in your mods if you take this route.![Wink ;)](./images/smilies/icon_wink.gif)
Dear Kate,
Thank you very much for your kind help.
We resolved this issue by adding attribute "_FillValue = 1.e+20;" to the uwind, vwind variables in forcings files. By default it was having missing_value attribute.
I just followed the same procedure for all my required forcings files.
Now model is working fine.
I got this _FillValue attribute information from here viewtopic.php?f=14&t=1078
Thanks & Regards,
Tara
Thanks & Regards,
Tara
