I have errors when running the upwelling case, the version is arango
The model can run successfully with oceanG and oceanO.
The following error occurs with the executable oceanS:
NL ROMS/TOMS: started time-stepping: (Grid: 01 TimeSteps: 00000001 - 00000288)
0 0 00:00:00 0.000000E+00 6.585677E+02 6.585677E+02 3.884376E+11
DEF_AVG - creating average file, Grid 01: ocean_avg.nc
DEF_DIAGS - creating diagnostics file, Grid 01: ocean_dia.nc
1 0 00:05:00 6.479416E-13 6.585677E+02 6.585677E+02 3.884376E+11
(01,01,01) 1.068554E-09 1.950202E-06 0.000000E+00 9.216771E-06
2 0 00:10:00 9.311375E-12 6.585677E+02 6.585677E+02 3.884376E+11
(01,02,08) 6.735275E-08 1.793582E-06 1.433645E-05 3.661905E-05
Image PC Routine Line Source
oceanM 00000000004B5F15 Unknown Unknown Unknown
oceanM 00000000004AAB23 Unknown Unknown Unknown
oceanM 000000000048BD57 Unknown Unknown Unknown
oceanM 0000000000404BEC Unknown Unknown Unknown
oceanM 0000000000404A0B Unknown Unknown Unknown
oceanM 000000000040485C Unknown Unknown Unknown
libc.so.6 0000003C2FC1D8B4 Unknown Unknown Unknown
oceanM 0000000000404769 Unknown Unknown Unknown
rank 2 in job 9 hksbs-s10.com_37297 caused collective abort of all ranks
exit status of rank 2: return code 174
rank 1 in job 9 hksbs-s10.com_37297 caused collective abort of all ranks
exit status of rank 1: return code 174
rank 0 in job 9 hksbs-s10.com_37297 caused collective abort of all ranks
exit status of rank 0: return code 174
The following error occurs with the executable oceanM:
2 0 00:10:00 9.311373E-12 6.585677E+02 6.585677E+02 3.884376E+11
(01,02,08) 6.735275E-08 1.793580E-06 1.433645E-05 3.661904E-05
oceanS 000000000049E275 Unknown Unknown Unknown
oceanS 0000000000492D23 Unknown Unknown Unknown
oceanS 0000000000474667 Unknown Unknown Unknown
oceanS 0000000000403B3C Unknown Unknown Unknown
oceanS 000000000040395D Unknown Unknown Unknown
oceanS 000000000040386C Unknown Unknown Unknown
oceanS 0000000000403779 Unknown Unknown Unknown
Re: forrtl: severe (174): SIGSEGV, segmentation fault occurr
it looks like it took 2 time steps
so save the history every time step and look at the output his file. Where is it having trouble?
grid location 01,02 looks like a boundary problem.
I would also recompile with bounds checking turned on (often the default with USE_DEBUG). One way to get a seg fault is through an array bounds violation.
Hi, I have the same issue, but I'm with oceanS and setting a grid netcdf file. When I run it:
log file:
and in the console:
I've used the option ulimit -c unlimited, but this go on. Is important the order of the parameters in the grid.nc? I made this grid file with easygrid.m (contains the bath and mask points)
Matias.
log file:
NL ROMS/TOMS: started time-stepping: (Grid: 01 TimeSteps: 00000001 - 00002016)
C => (i,j) Cu Cv C Max Max Speed
0 0 00:00:00 0.000000E+00 0.000000E+00 0.000000E+00 4.584548E+13
(00,000) 0.000000E+00 0.000000E+00 0.000000E+00 0.000000E+00
oceanS 000000000044BE3D Unknown Unknown Unknown
oceanS 00000000004423B2 Unknown Unknown Unknown
oceanS 000000000040375A Unknown Unknown Unknown
oceanS 00000000004035A2 Unknown Unknown Unknown
oceanS 000000000040342C Unknown Unknown Unknown
libc.so.6 00007FD8F0AA3D5D Unknown Unknown Unknown
oceanS 0000000000403329 Unknown Unknown Unknown
Matias.
This is what I know of seg faults. We really don't know what caused yours from what you posted. The model read the grid file, so it's probably not that (some grid file problems can cause another sort of blowing up).
As Kate said, you have to use USE_DEBUG and maybe edit the corresponding file in Compiler directory for changing the debug compiler flags. The "Unknown" will then be replaced by a precise statement of the nature of the error.
In truth, it is more likely that there is an error in your configuration and/or blow-up than a true error in the ROMS model. Unfortunately, it is hard if not impossible to make detailed error trackback when a problem happens.
I made the build.bahs with USE_DEBUG and I got this
So I have somethings specific. And Kate your advice helped me to figere out some mistakes in my grid file.
oceanG 00000000004BDC68 set_vbc_mod_mp_se 180 set_vbc.f90
oceanG 00000000004B9C8C set_vbc_mod_mp_se 63 set_vbc.f90
oceanG 0000000000497F48 main2d_ 122 main2d.f90
oceanG 0000000000403FA1 ocean_control_mod 151 ocean_control.f90
oceanG 0000000000403645 MAIN__ 86 master.f90
oceanG 000000000040344C Unknown Unknown Unknown
libc.so.6 00007FEE7A6C6D5D Unknown Unknown Unknown
oceanG 0000000000403349 Unknown Unknown Unknown
I solved my issue, it was a mix of grid setting and the forcing.
Thanks!!
Thanks!!
I have the same kind of problem, could you explain me how you solve it.
I am currently trying to make a two-way nest simulation, so I followed the example of the Lake Jersey AB example. The program don't even start and it gives me the log file I attached.
Do I miss something in the example?
Thanks for your time
roms.in
- (118.16 KiB) Downloaded 1126 times
iroise.log
- (7.35 KiB) Downloaded 1159 times
Did you read the posts higher in the thread? Try USE_DEBUG and see if it gives you useful line numbers at least. Then you can look at those files to see what is at the line number.
Deer Kate,
I read the entire post but it is not exactly the same problem.
I tried the USE_DEBUG and here the information it gives me
I checked what's in line 2508 of inp_par.f90
S(ng)%name=TRIM(S(ng)%files(1)) ! load first file
If you have some advice to solve it it would be great
Model Input Parameters: ROMS/TOMS version 3.5
Wednesday - December 2, 2015 - 3:32:04 PM
forrtl: severe (408): fort: (2): Subscript #1 of the array FILES has value 1 which is greater than the upper bound of 0
oceanG 0000000000F8DD4D Unknown Unknown Unknown
oceanG 0000000000F8C855 Unknown Unknown Unknown
oceanG 0000000000F33A80 Unknown Unknown Unknown
oceanG 0000000000EF1FBF Unknown Unknown Unknown
oceanG 0000000000EF23C2 Unknown Unknown Unknown
oceanG 0000000000B204F2 load_s1d_ 2508 inp_par.f90
oceanG 0000000000AFC9A0 read_phypar_ 1390 inp_par.f90
oceanG 0000000000AA521A inp_par_ 87 inp_par.f90
oceanG 000000000040492C ocean_control_mod 84 ocean_control.f90
oceanG 00000000004045E9 MAIN__ 95 master.f90
oceanG 00000000004044CC Unknown Unknown Unknown
libc.so.6 00002B914712DBC6 Unknown Unknown Unknown
oceanG 00000000004043C9 Unknown Unknown Unknown
How about what is here?
Inp_par is reading the ocean.in file, presumably the names of the forcing files. What do you have in that section of the ocean.in file? Show us all of:
NFFILES == 1 ! number of forcing files
FRCNAME == ocean_frc.nc ! forcing file 1, grid 1
I have got similar errors a few weeks ago and it was due to stackspace exhaustion. I added -heap-arrays to the fortran compiler and it solved the issue. I'm not sure if this is your case, but if you don't see anything wrong with the code, it may be something worth trying. There is a post online explaining this error and I found it quite helpful: https://software.intel.com/en-us/articl ... us-errors/
Good luck! I know how much pain it is to see this error.
I have checked and the -heap-array option is already activated
I have looked at the lines 1390 and 87 in the inp_par.f90, but I don't really understand what it means
line 1390 : Npts=load_s1d(Nval, Cval, line, label, igrid, Nfiles, ITL)
line 87 : CALL read_PhyPar (model, inp, out, Lwrite)
Finally in the ocean.in I have
NCFILES == 2 ! number of unique forcing files
FRCNAMES == ./frc_parent.nc \ ! forcing file 1, grid 1
./frc_child.nc ! forcing file 1, grid 2
Hmm, it's not the forcing file:
Do you have:
in your ocean.in?
As for the forcing file, try removing the comments after the "\" and after the filenames. ROMS will ignore any line starting with "!" but an ending "!" with comment is more problematic.
CASE ('ITLNAME')
label='ITL - tangent linear model initial conditions'
Npts=load_s1d(Nval, Cval, Cdim, line, label, igrid, &
& Nfiles, ITL)
ITLNAME == ocean_itl.nc
I have this line in my ocean.in but no file named ocean_itl.nc, what kind of file is this?
I also have tried to remove the comment line but same thing, no change
Maybe show us that whole chunk of your ocean.in file. Did you ask it to read an initial conditions file? Do you have a comment on the ININAME line? It's reading that just before the ITLNAME.
Hello Katekate wrote:Maybe show us that whole chunk of your ocean.in file. Did you ask it to read an initial conditions file? Do you have a comment on the ININAME line? It's reading that just before the ITLNAME.
I may have a problem when the model read the focring/bulk file. But I can't find the point,could you help? Thanks very much.I will run the model one year form 2009.01.01.00:00:00 to 2009.12.31.00:00:00
the output used oceanG as follows:
Wednesday - June 29, 2016 - 4:57:58 PM
Internal tidal System, 1/12 degree resolution
Operating system : Linux
CPU/hardware : x86_64
Compiler system : ifort
Compiler command : /usr/local/mpi/bin/mpif90
Compiler flags : -heap-arrays -fp-model precise -I/usr/local/mpi/include -g -check bounds -traceback -check uninit -warn interfaces,nouncalled -gen-interfaces -free -free -free
Input Script :
SVN Revision : 783M
Local Root : /vol/home/student/lshw/roms/trunk
Header Dir : /vol/home/student/lshw/roms/MYPROJECT/rSSC12
Header file : ssc12.h
Analytical Dir: /vol/home/student/lshw/roms/MYPROJECT/Functionals
Resolution, Grid 01: 0275x0275x032, Parallel Nodes: 16, Tiling: 004x004
87600 ntimes Number of timesteps for 3-D equations.
360.000 dt Timestep size (s) for 3-D equations.
72 ndtfast Number of timesteps for 2-D equations between
90 nRST Number of timesteps between the writing of data
into restart fields.
to standard output.
1200 nHIS Number of timesteps between the writing fields
into history file.
14400 ndefHIS Number of timesteps between creation of new
history files.
864000 ntsAVG Starting timestep for the accumulation of output
time-averaged data.
864000 nAVG Number of timesteps between the writing of
864000 ndefAVG Number of timesteps between creation of new
time-averaged file.
864000 ntsDIA Starting timestep for the accumulation of output
864000 nDIA Number of timesteps between the writing of
864000 ndefDIA Number of timesteps between creation of new
diagnostic file.
2.5000E+01 nl_tnu2(01) NLM Horizontal, harmonic mixing coefficient
(m2/s) for tracer 01: temp
2.5000E+01 nl_tnu2(02) NLM Horizontal, harmonic mixing coefficient
(m2/s) for tracer 02: salt
2.5000E+01 nl_visc2 NLM Horizontal, harmonic mixing coefficient
(m2/s) for momentum.
T LuvSponge Turning ON sponge on horizontal momentum.
T LtracerSponge(01) Turning ON sponge on tracer 01: temp
T LtracerSponge(02) Turning ON sponge on tracer 02: salt
for tracer 02: salt
for turbulent energy.
2.5000E-03 rdrg2 Quadratic bottom drag coefficient.
1.0000E+01 blk_ZQ Height (m) of surface air humidity measurement.
1.0000E+01 blk_ZT Height (m) of surface air temperature measurement.
1.0000E+01 blk_ZW Height (m) of surface winds measurement.
1 lmd_Jwt Jerlov water type.
6.0000E+00 theta_s S-coordinate surface control parameter.
5.0000E-01 theta_b S-coordinate bottom control parameter.
15.000 Tcline S-coordinate surface/bottom layer width (m) used
20090101.00 time_ref Reference time for units attribute (yyyymmdd.dd)
1.2000E+02 Tnudg(01) Nudging/relaxation time scale (days)
1.2000E+02 Tnudg(02) Nudging/relaxation time scale (days)
for tracer 02: salt
1.2000E+02 Znudg Nudging/relaxation time scale (days)
1.2000E+02 M2nudg Nudging/relaxation time scale (days)
1.2000E+02 M3nudg Nudging/relaxation time scale (days)
for 3D momentum.
1.2000E+02 obcfac Factor between passive and active
5.000 T0 Background potential temperature (C) constant.
T Hout(idTsur) Write out surface net heat flux.
T Hout(idTsur) Write out surface net salt flux.
T Hout(idSrad) Write out shortwave radiation flux.
T Hout(idLrad) Write out longwave radiation flux.
T Hout(idLhea) Write out latent heat flux.
T Hout(idShea) Write out sensible heat flux.
T Hout(idEmPf) Write out E-P flux.
T Hout(idevap) Write out evaporation rate.
T Hout(idrain) Write out rain rate.
T Hout(idVvis) Write out vertical viscosity: AKv.
T Hout(idTdif) Write out vertical diffusion: AKt(itemp).
T Hout(idSdif) Write out vertical diffusion: AKt(isalt).
T Hout(idMtke) Write out turbulent kinetic energy.
T Hout(idMtls) Write out turbulent generic length-scale.
Output Restart File: ssc12_rst.nc
Prefix for History Files: ssc12_his
Prefix for Averages Files: ssc12_avg
Prefix for Diagnostics Files: ssc12_dia
Input Grid File: ./Data/ssc12_grd.nc
Input Nonlinear Initial File: ./Data/ssc12_ini.nc
Input Forcing File 01: ./Data/ssc12_blkm1.nc
./Data/ssc12_blkm2.nc
./Data/ssc12_blkm3.nc
./Data/ssc12_blkm4.nc
./Data/ssc12_blkm5.nc
./Data/ssc12_blkm6.nc
./Data/ssc12_blkm7.nc
./Data/ssc12_blkm8.nc
./Data/ssc12_blkm9.nc
./Data/ssc12_blkm10.nc
./Data/ssc12_blkm11.nc
./Data/ssc12_blkm12.nc
Input Boundary File: ./Data/ssc12_brym1.nc
./Data/ssc12_brym2.nc
./Data/ssc12_brym3.nc
./Data/ssc12_brym4.nc
./Data/ssc12_brym5.nc
./Data/ssc12_brym6.nc
./Data/ssc12_brym7.nc
./Data/ssc12_brym8.nc
./Data/ssc12_brym9.nc
./Data/ssc12_brym10.nc
./Data/ssc12_brym11.nc
./Data/ssc12_brym12.nc
Input/Output USER File: MyFile.dat
Generic User Parameters:
2.0000E+01 user(01) User parameter 01.
Tile partition information for Grid 01: 0275x0275x0032 tiling: 004x004
tile Istr Iend Jstr Jend Npts
0 1 69 1 69 152352
1 70 138 1 69 152352
2 139 207 1 69 152352
3 208 275 1 69 150144
4 1 69 70 138 152352
5 70 138 70 138 152352
6 139 207 70 138 152352
7 208 275 70 138 150144
8 1 69 139 207 152352
9 70 138 139 207 152352
10 139 207 139 207 152352
11 208 275 139 207 150144
12 1 69 208 275 150144
13 70 138 208 275 150144
14 139 207 208 275 150144
15 208 275 208 275 147968
(interior points only)
tile Xmin Xmax Ymin Ymax grid
0 0.50 69.50 0.50 69.50 RHO-points
1 69.50 138.50 0.50 69.50 RHO-points
2 138.50 207.50 0.50 69.50 RHO-points
3 207.50 275.50 0.50 69.50 RHO-points
4 0.50 69.50 69.50 138.50 RHO-points
5 69.50 138.50 69.50 138.50 RHO-points
6 138.50 207.50 69.50 138.50 RHO-points
7 207.50 275.50 69.50 138.50 RHO-points
8 0.50 69.50 138.50 207.50 RHO-points
9 69.50 138.50 138.50 207.50 RHO-points
10 138.50 207.50 138.50 207.50 RHO-points
11 207.50 275.50 138.50 207.50 RHO-points
12 0.50 69.50 207.50 275.50 RHO-points
13 69.50 138.50 207.50 275.50 RHO-points
14 138.50 207.50 207.50 275.50 RHO-points
15 207.50 275.50 207.50 275.50 RHO-points
0 1.00 69.50 0.50 69.50 U-points
1 69.50 138.50 0.50 69.50 U-points
2 138.50 207.50 0.50 69.50 U-points
3 207.50 275.00 0.50 69.50 U-points
4 1.00 69.50 69.50 138.50 U-points
5 69.50 138.50 69.50 138.50 U-points
6 138.50 207.50 69.50 138.50 U-points
7 207.50 275.00 69.50 138.50 U-points
8 1.00 69.50 138.50 207.50 U-points
9 69.50 138.50 138.50 207.50 U-points
10 138.50 207.50 138.50 207.50 U-points
11 207.50 275.00 138.50 207.50 U-points
12 1.00 69.50 207.50 275.50 U-points
13 69.50 138.50 207.50 275.50 U-points
14 138.50 207.50 207.50 275.50 U-points
15 207.50 275.00 207.50 275.50 U-points
0 0.50 69.50 1.00 69.50 V-points
1 69.50 138.50 1.00 69.50 V-points
2 138.50 207.50 1.00 69.50 V-points
3 207.50 275.50 1.00 69.50 V-points
4 0.50 69.50 69.50 138.50 V-points
5 69.50 138.50 69.50 138.50 V-points
6 138.50 207.50 69.50 138.50 V-points
7 207.50 275.50 69.50 138.50 V-points
8 0.50 69.50 138.50 207.50 V-points
9 69.50 138.50 138.50 207.50 V-points
10 138.50 207.50 138.50 207.50 V-points
11 207.50 275.50 138.50 207.50 V-points
12 0.50 69.50 207.50 275.00 V-points
13 69.50 138.50 207.50 275.00 V-points
14 138.50 207.50 207.50 275.00 V-points
15 207.50 275.50 207.50 275.00 V-points
HaloSizeI(1) = 162
HaloSizeJ(1) = 162
TileSide(1) = 75
TileSize(1) = 5625
ubar 1 Flather Flather Flather Flather
vbar 1 Flather Flather Flather Flather
u 1 Rad + Nud Rad + Nud Rad + Nud Rad + Nud
v 1 Rad + Nud Rad + Nud Rad + Nud Rad + Nud
temp 1 Rad + Nud Rad + Nud Rad + Nud Rad + Nud
salt 1 Rad + Nud Rad + Nud Rad + Nud Rad + Nud
tke 1 Rad + Nud Rad + Nud Rad + Nud Rad + Nud
SSC12 South Sea of China Internal tidal System, 1/12 degree resolution
ADD_FSOBC Adding tidal elevation to processed OBC data.
ADD_M2OBC Adding tidal currents to processed OBC data.
ANA_SPONGE Analytical enhanced viscosity/diffusion sponge.
BULK_FLUXES Surface bulk fluxes parameterization.
DIAGNOSTICS_TS Computing and writing tracer diagnostic terms.
DIAGNOSTICS_UV Computing and writing momentum diagnostic terms.
DIFF_GRID Horizontal diffusion coefficient scaled by grid size.
DIURNAL_SRFLUX Modulate shortwave radiation by the local diurnal cycle.
EMINUSP Compute Salt Flux using E-P.
MASKING Land/Sea masking.
MIX_GEO_UV Mixing of momentum along geopotential surfaces.
MY25_MIXING Mellor/Yamada Level-2.5 mixing closure.
NONLINEAR Nonlinear Model.
QCORRECTION Surface net heat flux correction.
RAMP_TIDES Ramping tidal forcing for one day.
SALINITY Using salinity.
SPLINES_VDIFF Parabolic Spline Reconstruction for Vertical Diffusion.
SPLINES_VVISC Parabolic Spline Reconstruction for Vertical Viscosity.
TS_C4HADVECTION Fourth-order centered horizontal advection of tracers.
TS_SVADVECTION Parabolic splines vertical advection of tracers.
UV_ADV Advection of momentum.
UV_COR Coriolis term.
UV_TIDES Add tidal currents to 2D momentum climatologies.
VISC_GRID Horizontal viscosity coefficient scaled by grid size.
Process Information:
Node # 0 (pid= 16064) is active.
Node # 14 (pid= 16078) is active.
Node # 1 (pid= 16065) is active.
Node # 5 (pid= 16069) is active.
Node # 8 (pid= 16072) is active.
Node # 10 (pid= 16074) is active.
Node # 2 (pid= 16066) is active.
Node # 4 (pid= 16068) is active.
Node # 15 (pid= 16079) is active.
Node # 6 (pid= 16070) is active.
Node # 7 (pid= 16071) is active.
Node # 13 (pid= 16077) is active.
Node # 9 (pid= 16073) is active.
Node # 11 (pid= 16075) is active.
Node # 12 (pid= 16076) is active.
Node # 3 (pid= 16067) is active.
32 0.0000000 0.0000000 0.000 0.000 0.000 0.000
31 -0.0312500 -0.0001116 -0.188 -0.235 -0.800 -1.136
30 -0.0625000 -0.0004504 -0.377 -0.472 -2.279 -3.630
29 -0.0937500 -0.0010281 -0.567 -0.711 -4.473 -7.555
28 -0.1250000 -0.0018650 -0.757 -0.951 -7.442 -13.031
27 -0.1562500 -0.0029903 -0.949 -1.194 -11.272 -20.233
26 -0.1875000 -0.0044433 -1.143 -1.440 -16.083 -29.396
25 -0.2187500 -0.0062746 -1.338 -1.688 -22.025 -40.823
24 -0.2500000 -0.0085478 -1.534 -1.939 -29.287 -54.895
23 -0.2812500 -0.0113419 -1.733 -2.194 -38.107 -72.083
22 -0.3125000 -0.0147533 -1.934 -2.454 -48.773 -92.966
21 -0.3437500 -0.0188997 -2.138 -2.720 -61.637 -118.248
20 -0.3750000 -0.0239231 -2.346 -2.992 -77.122 -148.778
19 -0.4062500 -0.0299948 -2.557 -3.272 -95.741 -185.581
18 -0.4375000 -0.0373204 -2.774 -3.561 -118.110 -229.889
17 -0.4687500 -0.0461459 -2.997 -3.862 -144.963 -283.172
16 -0.5000000 -0.0567646 -3.227 -4.176 -177.177 -347.187
15 -0.5312500 -0.0695249 -3.466 -4.506 -215.794 -424.018
14 -0.5625000 -0.0848395 -3.714 -4.855 -262.047 -516.135
13 -0.5937500 -0.1031943 -3.975 -5.227 -317.391 -626.446
12 -0.6250000 -0.1251587 -4.251 -5.626 -383.526 -758.359
11 -0.6562500 -0.1513952 -4.543 -6.057 -462.434 -915.837
10 -0.6875000 -0.1826680 -4.856 -6.526 -556.399 -1103.456
9 -0.7187500 -0.2198500 -5.192 -7.039 -668.032 -1326.437
8 -0.7500000 -0.2639239 -5.556 -7.604 -800.270 -1590.663
7 -0.7812500 -0.3159778 -5.951 -8.229 -956.366 -1902.645
6 -0.8125000 -0.3771881 -6.384 -8.923 -1139.838 -2269.423
5 -0.8437500 -0.4487876 -6.858 -9.694 -1354.372 -2698.375
4 -0.8750000 -0.5320097 -7.378 -10.553 -1603.654 -3196.882
3 -0.9062500 -0.6280041 -7.950 -11.507 -1891.123 -3771.824
2 -0.9375000 -0.7377147 -8.576 -12.564 -2219.601 -4428.850
1 -0.9687500 -0.8617150 -9.259 -13.728 -2590.801 -5171.391
0 -1.0000000 -1.0000000 -10.000 -15.000 -3004.710 -5999.420
Time Splitting Weights for Grid 01: ndtfast = 72 nfast = 98
1-0.0002697221589845 0.0138888888888889-0.0002697221589845 0.0138888888888889
2-0.0005179738466200 0.0138926350299859-0.0007876960056045 0.0277815239188748
3-0.0007447551074202 0.0138998291111890-0.0015324511130247 0.0416813530300638
4-0.0009500661144945 0.0139101729321254-0.0024825172275192 0.0555915259621891
5-0.0011339073179268 0.0139233682948267-0.0036164245454460 0.0695148942570158
6-0.0012962796525070 0.0139391170075756-0.0049127041979530 0.0834540112645914
7-0.0014371848048139 0.0139571208916382-0.0063498890027669 0.0974111321562297
8-0.0015566255396494 0.0139770817917051-0.0079065145424162 0.1113882139479348
9-0.0016546060858249 0.0139987015908669-0.0095611206282412 0.1253869155388017
10-0.0017311325812999 0.0140216822309478-0.0112922532095411 0.1394085977697495
11-0.0017862135776710 0.0140457257390214-0.0130784667872121 0.1534543235087709
12-0.0018198606040138 0.0140705342609335-0.0148983273912259 0.1675248577697044
13-0.0018320887900766 0.0140958101026559-0.0167304161813025 0.1816206678723603
14-0.0018229175488246 0.0141212557802959-0.0185533337301271 0.1957419236526562
15-0.0017923713183374 0.0141465740795851-0.0203457050484645 0.2098884977322413
16-0.0017404803630569 0.0141714681256731-0.0220861854115213 0.2240599658579144
17-0.0016672816343881 0.0141956414640489-0.0237534670459094 0.2382556073219634
18-0.0015728196906507 0.0142187981534154-0.0253262867365601 0.2524744054753787
19-0.0014571476763831 0.0142406428713411-0.0267834344129432 0.2667150483467199
20-0.0013203283609977 0.0142608810335131-0.0281037627739409 0.2809759293802330
21-0.0011624352367880 0.0142792189274159-0.0292661980107289 0.2952551483076488
22-0.0009835536762878 0.0142953638612601-0.0302497516870167 0.3095505121689089
23-0.0007837821489820 0.0143090243289864-0.0310335338359988 0.3238595364978953
24-0.0005632334973686 0.0143199101921667-0.0315967673333673 0.3381794466900619
25-0.0003220362723731 0.0143277328796301-0.0319188036057405 0.3525071795696921
26-0.0000603361281147 0.0143322056056353-0.0319791397338552 0.3668393851753274
27 0.0002217027239766 0.0143330436074147-0.0317574370098786 0.3811724287827420
28 0.0005238960016901 0.0143299644029150-0.0312335410081885 0.3955023931856571
29 0.0008460377792135 0.0143226880695582-0.0303875032289750 0.4098250812552152
30 0.0011878988549600 0.0143109375448469-0.0291996043740150 0.4241360188000621
31 0.0015492250600437 0.0142944389496391-0.0276503793139713 0.4384304577497012
32 0.0019297355074029 0.0142729219349163-0.0257206438065684 0.4527033796846174
33 0.0023291207815727 0.0142461200528690-0.0233915230249958 0.4669494997374865
34 0.0027470410691043 0.0142137711531249-0.0206444819558915 0.4811632708906114
35 0.0031831242296341 0.0141756178049429-0.0174613577262575 0.4953388886955543
36 0.0036369638075999 0.0141314077461980-0.0138243939186576 0.5094702964417523
37 0.0041081169846063 0.0140808943599814-0.0097162769340513 0.5235511908017337
38 0.0045961024724372 0.0140238371796396-0.0051201744616140 0.5375750279813734
39 0.0051003983467181 0.0139600024230780-0.0000197761148959 0.5515350304044513
40 0.0056204398212250 0.0138891635571513 0.0056006637063291 0.5654241939616026
41 0.0061556169628429 0.0138111018929677 0.0117562806691720 0.5792352958545702
42 0.0067052723471717 0.0137256072129282 0.0184615530163437 0.5929609030674984
43 0.0072686986547809 0.0136324784303286 0.0257302516711247 0.6065933814978269
44 0.0078451362081123 0.0135315242823455 0.0335753878792370 0.6201249057801724
45 0.0084337704490309 0.0134225640572328 0.0420091583282679 0.6335474698374053
46 0.0090337293570240 0.0133054283565518 0.0510428876852919 0.6468528981939571
47 0.0096440808080493 0.0131799598932598 0.0606869684933412 0.6600328580872169
48 0.0102638298740300 0.0130460143264814 0.0709507983673713 0.6730788724136982
49 0.0108919160629993 0.0129034611337865 0.0818427144303705 0.6859823335474847
50 0.0115272104998922 0.0127521845218004 0.0933699249302627 0.6987345180692851
51 0.0121685130479867 0.0125920843759686 0.1055384379782495 0.7113266024452537
52 0.0128145493709923 0.0124230772503021 0.1183529873492417 0.7237496796955558
53 0.0134639679357865 0.0122450973979272 0.1318169552850283 0.7359947770934830
54 0.0141153369558014 0.0120580978432635 0.1459322922408297 0.7480528749367465
55 0.0147671412750559 0.0118620514966551 0.1606994335158856 0.7599149264334017
56 0.0154177791928386 0.0116569523122794 0.1761172127087242 0.7715718787456811
57 0.0160655592290373 0.0114428164901566 0.1921827719377615 0.7830146952358378
58 0.0167086968301175 0.0112196837230866 0.2088914687678790 0.7942343789589245
59 0.0173453110157492 0.0109876184893350 0.2262367797836282 0.8052219974482595
60 0.0179734209660816 0.0107467113918941 0.2442102007497098 0.8159687088401536
61 0.0185909425496662 0.0104970805451429 0.2628011432993760 0.8264657893852965
62 0.0191956847920284 0.0102388730097309 0.2819968280914044 0.8367046623950274
63 0.0197853462848869 0.0099722662765083 0.3017821743762913 0.8466769286715357
64 0.0203575115360218 0.0096974698003293 0.3221396859123131 0.8563743984718649
65 0.0209096472597907 0.0094147265845512 0.3430493331721038 0.8657891250564161
66 0.0214390986082931 0.0091243148170541 0.3644884317803970 0.8749134398734703
67 0.0219430853431833 0.0088265495586056 0.3864315171235803 0.8837399894320759
68 0.0224186979481308 0.0085217844843947 0.4088502150717111 0.8922617739164705
69 0.0228628936819303 0.0082104136795596 0.4317131087536414 0.9004721875960301
70 0.0232724925722585 0.0078928734895328 0.4549856013258999 0.9083650610855628
71 0.0236441733500801 0.0075696444260292 0.4786297746759800 0.9159347055115920
72 0.0239744693247019 0.0072412531295003 0.5026042440006819 0.9231759586410923
73 0.0242597641994746 0.0069082743888794 0.5268640082001566 0.9300842330299717
74 0.0244962878281439 0.0065713332194423 0.5513602960283005 0.9366555662494139
75 0.0246801119118487 0.0062311069996069 0.5760404079401492 0.9428866732490209
76 0.0248071456367686 0.0058883276674979 0.6008475535769178 0.9487750009165188
77 0.0248731312524188 0.0055437839780984 0.6257206848293365 0.9543187848946172
78 0.0248736395905937 0.0051983238218148 0.6505943244199301 0.9595171087164319
79 0.0248040655249589 0.0048528566052787 0.6753983899448891 0.9643699653217107
80 0.0246596233712912 0.0045083556952099 0.7000580133161803 0.9688783210169206
81 0.0244353422283667 0.0041658609261642 0.7244933555445470 0.9730441819430847
82 0.0241260612594974 0.0038264811729924 0.7486194168040444 0.9768706631160772
83 0.0237264249147164 0.0034913969888327 0.7723458417187609 0.9803620601049099
84 0.0232308780936106 0.0031618633094617 0.7955767198123714 0.9835239234143716
85 0.0226336612488020 0.0028392122248282 0.8182103810611735 0.9863631356391998
86 0.0219288054300778 0.0025248558185948 0.8401391864912513 0.9888879914577946
87 0.0211101272691677 0.0022202890765104 0.8612493137604190 0.9911082805343050
88 0.0201712239051703 0.0019270928644386 0.8814205376655893 0.9930353733987436
89 0.0191054678506273 0.0016469369768668 0.9005260055162165 0.9946823103756104
90 0.0179060017982467 0.0013815832567192 0.9184320073144632 0.9960638936323296
91 0.0165657333682728 0.0011328887872991 0.9349977406827360 0.9971967824196287
92 0.0150773297965061 0.0009028091571842 0.9500750704792420 0.9980995915768129
93 0.0134332125629703 0.0006934017988994 0.9635082830422124 0.9987929933757124
94 0.0116255519612283 0.0005068294021915 0.9751338350034406 0.9992998227779039
95 0.0096462616083458 0.0003453634027300 0.9847800966117864 0.9996451861806338
96 0.0074869928955037 0.0002113875470585 0.9922670895072901 0.9998565737276923
97 0.0051391293792585 0.0001074015346210 0.9974062188865486 0.9999639752623133
98 0.0025937811134509 0.0000360247376868 0.9999999999999996 1.0000000000000000
ndtfast, nfast = 72 98 nfast/ndtfast = 1.36111
1.000000000000 1.025151749473 0.512575874736 1.000000000000 1.000000000000
Power filter parameters, Fgamma, gamma = 0.28400 0.24456
Minimum X-grid spacing, DXmin = 8.31956155E+00 km
Maximum X-grid spacing, DXmax = 9.23851059E+00 km
Minimum Y-grid spacing, DYmin = 8.32752431E+00 km
Maximum Y-grid spacing, DYmax = 9.23803707E+00 km
Minimum Z-grid spacing, DZmin = 1.87946450E-01 m
Maximum Z-grid spacing, DZmax = 8.28028490E+02 m
Minimum barotropic Courant Number = 7.65400315E-03
Maximum barotropic Courant Number = 2.03630778E-01
Maximum Coriolis Courant Number = 2.30020631E-02
Horizontal mixing scaled by grid size, GRDMAX = 9.23827383E+00 km
(Grid 01, File: ssc12_ini.nc, Rec=0001, Index=1)
- free-surface
(Min = -1.48966948E-01 Max = 3.61947780E-01)
(Min = -6.00885394E-01 Max = 4.97978379E-01)
(Min = -9.50324788E-01 Max = 3.26700159E-01)
- u-momentum component
(Min = -1.05035297E+00 Max = 8.54699225E-01)
- v-momentum component
(Min = -1.33850665E+00 Max = 1.10605943E+00)
- potential temperature
(Min = 1.14820875E+00 Max = 2.94470631E+01)
- salinity
(Min = 3.24921652E+01 Max = 3.49794372E+01)
GET_NGFLD - tidal period
(Min = 4.30819210E+04 Max = 9.67262421E+04)
(Min = 1.05619027E-04 Max = 2.04697708E+01)
(Min = 8.09572363E-06 Max = 6.28317033E+00)
(Min = 2.46404577E-06 Max = 6.28318082E+00)
(Min = 1.82233990E-06 Max = 6.28318114E+00)
(Min = 3.85134858E-06 Max = 1.81928232E+01)
(Min = -1.04224347E+00 Max = 1.16227576E+00)
forrtl: severe (408): fort: (3): Subscript #1 of the array TVAL has value 0 which is less than the lower bound of 1
oceanG 0000000001D7107D Unknown Unknown Unknown
oceanG 0000000001D6FB85 Unknown Unknown Unknown
oceanG 0000000001D16409 Unknown Unknown Unknown
oceanG 0000000001CD4A8F Unknown Unknown Unknown
oceanG 0000000001CD4E92 Unknown Unknown Unknown
oceanG 00000000018CBDBF get_cycle_ 224 get_cycle.f90
oceanG 000000000163732F inquire_ 277 inquire.f90
oceanG 00000000015CA9C0 get_2dfld_ 102 get_2dfld.f90
oceanG 00000000012C728B get_data_ 100 get_data.f90
oceanG 00000000006930BF initial_ 282 initial.f90
oceanG 00000000004131ED ocean_control_mod 130 ocean_control.f90
oceanG 000000000041235F MAIN__ 95 master.f90
oceanG 00000000004121FC Unknown Unknown Unknown
libc.so.6 00002AE0D133CCDD Unknown Unknown Unknown
oceanG 00000000004120F9 Unknown Unknown Unknown
222 ELSE
223 i=MIN(ntime,Tindex+1)
224 Tend=Tval(i)
225 END IF
the first forcing file :ssc12_blkm1.nc
lrf_time = -2, -1.75, -1.5, -1.25, -1, -0.75, -0.5, -0.25, 0, 0.25, 0.5,
0.75, 1, 1.25, 1.5, 1.75, 2, 2.25, 2.5, 2.75, 3, 3.25, 3.5, 3.75, 4,
4.25, 4.5, 4.75, 5, 5.25, 5.5, 5.75, 6, 6.25, 6.5, 6.75, 7, 7.25, 7.5,
7.75, 8, 8.25, 8.5, 8.75, 9, 9.25, 9.5, 9.75, 10, 10.25, 10.5, 10.75, 11,
11.25, 11.5, 11.75, 12, 12.25, 12.5, 12.75, 13, 13.25, 13.5, 13.75, 14,
14.25, 14.5, 14.75, 15, 15.25, 15.5, 15.75, 16, 16.25, 16.5, 16.75, 17,
17.25, 17.5, 17.75, 18, 18.25, 18.5, 18.75, 19, 19.25, 19.5, 19.75, 20,
20.25, 20.5, 20.75, 21, 21.25, 21.5, 21.75, 22, 22.25, 22.5, 22.75, 23,
23.25, 23.5, 23.75, 24, 24.25, 24.5, 24.75, 25, 25.25, 25.5, 25.75, 26,
26.25, 26.5, 26.75, 27, 27.25, 27.5, 27.75, 28, 28.25, 28.5, 28.75, 29,
29.25, 29.5, 29.75, 30, 30.25, 30.5, 30.75, 31, 31.25, 31.5, 31.75, 32,
32.25, 32.5, 32.75 ;
the last forcing file :ssc12_blkm12.nc
lrf_time = 332, 332.25, 332.5, 332.75, 333, 333.25, 333.5, 333.75, 334,
334.25, 334.5, 334.75, 335, 335.25, 335.5, 335.75, 336, 336.25, 336.5,
336.75, 337, 337.25, 337.5, 337.75, 338, 338.25, 338.5, 338.75, 339,
339.25, 339.5, 339.75, 340, 340.25, 340.5, 340.75, 341, 341.25, 341.5,
341.75, 342, 342.25, 342.5, 342.75, 343, 343.25, 343.5, 343.75, 344,
344.25, 344.5, 344.75, 345, 345.25, 345.5, 345.75, 346, 346.25, 346.5,
346.75, 347, 347.25, 347.5, 347.75, 348, 348.25, 348.5, 348.75, 349,
349.25, 349.5, 349.75, 350, 350.25, 350.5, 350.75, 351, 351.25, 351.5,
351.75, 352, 352.25, 352.5, 352.75, 353, 353.25, 353.5, 353.75, 354,
354.25, 354.5, 354.75, 355, 355.25, 355.5, 355.75, 356, 356.25, 356.5,
356.75, 357, 357.25, 357.5, 357.75, 358, 358.25, 358.5, 358.75, 359,
359.25, 359.5, 359.75, 360, 360.25, 360.5, 360.75, 361, 361.25, 361.5,
361.75, 362, 362.25, 362.5, 362.75, 363, 363.25, 363.5, 363.75, 364,
364.25, 364.5, 364.75, 365, 365.25, 365.5, 365.75, 366, 366.25, 366.5,
366.75 ;
the first bry file:ssc12_brym1.nc
temp_time = -16, 14, 44 ;
the last bry file:ssc12_brym12.nc
temp_time = 318, 348, 378 ;
the initial file:ssc12_ini.nc
ocean_time = 0 ;
and the relative parameters:
NTIMES == 87600
DT == 360.0d0
NDTFAST == 72
DSTART = 0 ! days
TIDE_START = 0.0d0 ! days
TIME_REF = 20090101.0d0 ! yyyymmdd.dd
How should I do? Looking forward to your reply
I don't think the problem is in the time indexing. What is at line 100 of your get_data.F?
Which field is it trying to read there? You're right in that it's trying to read the time associated with that variable.
the position of the get_data.f90 line 100 is try to read the variable Uwind of Surface wind components.kate wrote:I don't think the problem is in the time indexing. What is at line 100 of your get_data.F?Which field is it trying to read there? You're right in that it's trying to read the time associated with that variable.Code: Select all
!Surface wind components.
100 CALL get_2dfld (ng, iNLM, idUair, ncFRCid(idUair,ng), &
101 & nFfiles(ng), FRC(1,ng), update(1), &
102 & LBi, UBi, LBj, UBj, 2, 1, &
103 & GRID(ng) % rmask, &
104 & FORCES(ng) % UwindG)
105 IF (exit_flag.ne.NoError) RETURN
106 CALL get_2dfld (ng, iNLM, idVair, ncFRCid(idVair,ng), &
! If appropriate, inquire about the contents of input NetCDF file and
! fill information arrays.
IF (Linquire) THEN
job=2
102 CALL inquire (ng, model, job, Iout, Irec, 1, ifield, ncid, &
& Lmulti, nfiles, S)
! Determine initial time record to read and cycling switch.
IF (foundit) THEN
277 CALL get_cycle (ng, model, ifield, job, Lmulti, &
& ncfile, Tname(ifield), Nrec, tdays(ng), &
& Tid, Liocycle, Clength, Trec, &
& Tstr, Tend, Tmin, Tmax, Tscale)
You can't have negative time, you can't have a cycle_length of zero, and you can't have this:
in the forcing file , the time index is all the same.
I have remove the cycle attribute, and just use bulkm2.nc and brym2.nc. but also the same problem.How to check the error.kate wrote:You can't have negative time, you can't have a cycle_length of zero, and you can't have this:in the forcing file , the time index is all the same.
No need to double post - I answered your other one. But what I'd really do is run this in a debugger and figure out exactly what's going on. This can be solved in serial mode, so the free gdb would work.
Sorry, I am just too worry about my research. I used the blkm2.nc and brym2.nc which time index from 29 to 61 also cause this question. And I also change the cycle_length to 28 days of Feb., it can read the wind,but it down with error that Tend>Tstart. At last, I remove the attribute of cycle because I saw a page that you say when split the ncfile with time the model canot use cycle. But it doesnot work. I will use serial mode to try. Thanks very much.kate wrote:No need to double post - I answered your other one. But what I'd really do is run this in a debugger and figure out exactly what's going on. This can be solved in serial mode, so the free gdb would work.
