I have made the grid, initial, forcing, etc files according to training_25aug2014, compiled the coawstM file, but when I ran the file "mpirun -np 1 coawstM Projects_My/Sandy/ocean_sandy.in > cwstv3.out", there were errors, maybe there are some errors in the ocean_sandy.in file.
can somebody help me, thanks a lot
Thursday - June 11, 2015 - 6:37:14 AM
Hurricane Sandy
Operating system : Linux
CPU/hardware : x86_64
Compiler system : pgi
Compiler command : /usr/local/pgi/linux86-64/2010/mpi/mpich/bin/mpif90
Compiler flags : -fastsse -Mipa=fast -tp k8-64 -Mfree
Input Script :
SVN Revision : 890:894M
Local Root : /home/limaolin/model/COAWST_140823
Header Dir : /home/limaolin/model/COAWST_140823/Projects_My/Sandy
Header file : sandy.h
Analytical Dir: /home/limaolin/model/COAWST_140823/Projects_My/Sandy
Resolution, Grid 01: 0082x0062x016, Parallel Nodes: 4, Tiling: 002x002
5760 ntimes Number of timesteps for 3-D equations.
28 ndtfast Number of timesteps for 2-D equations between
60 nRST Number of timesteps between the writing of data
into restart fields.
to standard output.
60 nHIS Number of timesteps between the writing fields
into history file.
time-averaged data.
432 nAVG Number of timesteps between the writing of
2.0000E-01 nl_tnu2(01) NLM Horizontal, harmonic mixing coefficient
(m2/s) for tracer 01: temp
2.0000E-01 nl_tnu2(02) NLM Horizontal, harmonic mixing coefficient
(m2/s) for tracer 02: salt
1.0000E-01 nl_visc2 NLM Horizontal, harmonic mixing coefficient
(m2/s) for momentum.
for tracer 02: salt
for turbulent energy.
0.000 wec_alpha WEC factor for roller/breaking energy distribution.
56229.500 dstart Time-stamp assigned to model initialization (days).
for tracer 02: salt
1.0000E+00 M3nudg Nudging/relaxation time scale (days)
for 3D momentum.
T Hout(idMtke) Write out turbulent kinetic energy.
T Hout(idMtls) Write out turbulent generic length-scale.
T Aout(idSdif) Write out averaged vertical diffusion: AKt(isalt).
Output Restart File: Sandy_ocean_rst.nc
Output History File: Sandy_ocean_his.nc
Output Averages File: Sandy_ocean_avg.nc
Input Grid File: Projects_My/Sandy/roms_grid/Sandy_roms_grid.nc
Nesting grid connectivity File: Projects_My/Sandy/roms_grid/Sandy_roms_contact.nc
Input Nonlinear Initial File: Projects_My/Sandy/3D_BC/Sandy_ini.nc
Input Forcing File 01: Projects_My/Sandy/surface_forcings/Sandy_frc.nc
Input Forcing File 02: Projects_My/Sandy/surface_forcings/Sandy_frc_ref3.nc
Input Boundary File 01: Projects_My/Sandy/3D_BC/Sandy_bdy.nc
Resolution, Grid 02: 0114x0084x016, Parallel Nodes: 4, Tiling: 002x002
Physical Parameters, Grid: 02
11520 ntimes Number of timesteps for 3-D equations.
15.000 dt Timestep size (s) for 3-D equations.
120 nRST Number of timesteps between the writing of data
to standard output.
into history file.
time-averaged data.
for tracer 02: salt
for tracer 02: salt
for 3D momentum.
Output Restart File: Sandy_ocean_ref3_rst.nc
Output History File: Sandy_ocean_ref3_his.nc
Output Averages File: Sandy_ocean_ref3_avg.nc
Input Grid File: Projects_My/Sandy/roms_grid/Sandy_roms_grid_ref3.nc
Input Nonlinear Initial File: Projects_My/Sandy/3D_BC/Sandy_ini_ref3.nc
Tile partition information for Grid 01: 0082x0062x0016 tiling: 002x002
tile Istr Iend Jstr Jend Npts
Number of tracers: 2
0 1 41 1 31 20336
1 42 82 1 31 20336
2 1 41 32 62 20336
3 42 82 32 62 20336
Tile partition information for Grid 02: 0114x0084x0016 tiling: 002x002
0 1 57 1 42 38304
1 58 114 1 42 38304
2 1 57 43 84 38304
3 58 114 43 84 38304
(interior points only)
tile Xmin Xmax Ymin Ymax grid
0 0.50 41.50 0.50 31.50 RHO-points
1 41.50 82.50 0.50 31.50 RHO-points
2 0.50 41.50 31.50 62.50 RHO-points
3 41.50 82.50 31.50 62.50 RHO-points
0 1.00 41.50 0.50 31.50 U-points
1 41.50 82.00 0.50 31.50 U-points
2 1.00 41.50 31.50 62.50 U-points
3 41.50 82.00 31.50 62.50 U-points
0 0.50 41.50 1.00 31.50 V-points
1 41.50 82.50 1.00 31.50 V-points
2 0.50 41.50 31.50 62.00 V-points
3 41.50 82.50 31.50 62.00 V-points
Tile minimum and maximum fractional coordinates for Grid 02:
0 0.50 57.50 0.50 42.50 RHO-points
1 57.50 114.50 0.50 42.50 RHO-points
2 0.50 57.50 42.50 84.50 RHO-points
3 57.50 114.50 42.50 84.50 RHO-points
0 1.00 57.50 0.50 42.50 U-points
1 57.50 114.00 0.50 42.50 U-points
2 1.00 57.50 42.50 84.50 U-points
3 57.50 114.00 42.50 84.50 U-points
0 0.50 57.50 1.00 42.50 V-points
1 57.50 114.50 1.00 42.50 V-points
2 0.50 57.50 42.50 84.00 V-points
3 57.50 114.50 42.50 84.00 V-points
HaloSizeI(1) = 162
HaloSizeJ(1) = 132
TileSide(1) = 48
TileSize(1) = 1824
HaloSizeI(2) = 216
HaloSizeJ(2) = 171
TileSide(2) = 66
TileSize(2) = 3366
zeta 1 Gradient Chapman Imp Gradient Closed
2 Nested Nested Nested Nested
ubar 1 Gradient Flather Gradient Closed
vbar 1 Gradient Flather Gradient Closed
u 1 Gradient Clamped Gradient Gradient
v 1 Gradient Rad + Nud Gradient Gradient
temp 1 Gradient Rad + Nud Rad + Nud Closed
salt 1 Gradient Rad + Nud Rad + Nud Closed
tke 1 Gradient Gradient Gradient Closed
SANDY Hurricane Sandy
MASKING Land/Sea masking.
NESTING Nesting grids: Composite and Refinement.
NONLINEAR Nonlinear Model.
SALINITY Using salinity.
UV_ADV Advection of momentum.
UV_COR Coriolis term.
Process Information:
Node # 0 (pid= 5835) is active.
Node # 1 (pid= 5846) is active.
Node # 3 (pid= 5895) is active.
Node # 2 (pid= 5866) is active.
15 -0.0625000 -0.0048948 -3.172 -3.125 -3.697 -4.222
14 -0.1250000 -0.0119914 -6.365 -6.250 -7.651 -8.937
13 -0.1875000 -0.0230908 -9.595 -9.375 -12.073 -14.550
12 -0.2500000 -0.0409944 -12.891 -12.500 -17.289 -21.687
11 -0.3125000 -0.0696342 -16.290 -15.625 -23.761 -31.231
10 -0.3750000 -0.1133185 -19.832 -18.750 -31.989 -44.146
9 -0.4375000 -0.1742175 -23.539 -21.875 -42.229 -60.920
8 -0.5000000 -0.2489214 -27.377 -25.000 -54.082 -80.787
7 -0.5625000 -0.3284417 -31.261 -28.125 -66.498 -101.734
6 -0.6250000 -0.4042644 -35.110 -31.250 -78.481 -121.852
5 -0.6875000 -0.4744488 -38.905 -34.375 -89.806 -140.706
4 -0.7500000 -0.5437741 -42.692 -37.500 -101.030 -159.368
3 -0.8125000 -0.6205544 -46.551 -40.625 -113.126 -179.701
2 -0.8750000 -0.7145184 -50.573 -43.750 -127.229 -203.884
1 -0.9375000 -0.8366254 -54.864 -46.875 -144.620 -234.376
0 -1.0000000 -1.0000000 -59.549 -50.000 -166.832 -274.115
Vertical S-coordinate System, Grid 02:
15 -0.0625000 -0.0048948 -0.707 -0.707 -0.781 -0.855
14 -0.1250000 -0.0119914 -1.415 -1.415 -1.595 -1.776
13 -0.1875000 -0.0230908 -2.122 -2.122 -2.470 -2.818
12 -0.2500000 -0.0409944 -2.830 -2.830 -3.447 -4.064
11 -0.3125000 -0.0696342 -3.537 -3.537 -4.585 -5.634
10 -0.3750000 -0.1133185 -4.244 -4.244 -5.951 -7.657
9 -0.4375000 -0.1742175 -4.952 -4.952 -7.575 -10.198
8 -0.5000000 -0.2489214 -5.659 -5.659 -9.407 -13.155
7 -0.5625000 -0.3284417 -6.367 -6.367 -11.312 -16.257
6 -0.6250000 -0.4042644 -7.074 -7.074 -13.161 -19.248
5 -0.6875000 -0.4744488 -7.781 -7.781 -14.925 -22.068
4 -0.7500000 -0.5437741 -8.489 -8.489 -16.676 -24.863
3 -0.8125000 -0.6205544 -9.196 -9.196 -18.540 -27.883
2 -0.8750000 -0.7145184 -9.904 -9.904 -20.662 -31.420
1 -0.9375000 -0.8366254 -10.611 -10.611 -23.208 -35.804
0 -1.0000000 -1.0000000 -11.318 -11.318 -26.375 -41.431
Time Splitting Weights for Grid 01: ndtfast = 28 nfast = 40
1-0.0008549076326633 0.0357142857142857-0.0008549076326633 0.0357142857142857
2-0.0014558918889834 0.0357448181297380-0.0023107995216466 0.0714591038440237
3-0.0018029740646893 0.0357968142686302-0.0041137735863359 0.1072559181126539
4-0.0018962369765050 0.0358612061995120-0.0060100105628409 0.1431171243121659
5-0.0017358959479127 0.0359289289486729-0.0077459065107536 0.1790460532608388
6-0.0013223981892219 0.0359909252325269-0.0090683046999755 0.2150369784933657
7-0.0006565505719430 0.0360381537392849-0.0097248552719185 0.2510751322326505
8 0.0002603242025330 0.0360616019739971-0.0094645310693855 0.2871367342066476
9 0.0014262030399493 0.0360523046810495-0.0080383280294362 0.3231890388876971
10 0.0028381494958941 0.0360013688581942-0.0052001785335421 0.3591904077458913
11 0.0044920724242039 0.0359000063761979-0.0007081061093382 0.3950904141220892
12 0.0063824562310637 0.0357395752181907 0.0056743501217255 0.4308299893402799
13 0.0085020627348001 0.0355116303527955 0.0141764128565256 0.4663416196930754
14 0.0108416046313699 0.0352079852551241 0.0250180174878955 0.5015496049481994
15 0.0133893905655432 0.0348207850897180 0.0384074080534387 0.5363703900379174
16 0.0161309418077813 0.0343425925695201 0.0545383498612200 0.5707129826074375
17 0.0190485805368085 0.0337664875049564 0.0735869303980285 0.6044794701123939
18 0.0221209897278798 0.0330861810572133 0.0957079201259083 0.6375656511696072
19 0.0253227446467419 0.0322961457097890 0.1210306647726502 0.6698617968793962
20 0.0286238159492901 0.0313917619724053 0.1496544807219403 0.7012535588518015
21 0.0319890443869185 0.0303694828313593 0.1816435251088588 0.7316230416831608
22 0.0353775871175665 0.0292270169603979 0.2170211122264253 0.7608500586435587
23 0.0387423356224582 0.0279635317061991 0.2557634478488834 0.7888135903497578
24 0.0420293052285376 0.0265798768625399 0.2977927530774210 0.8153934672122977
25 0.0451769962365983 0.0250788302472350 0.3429697493140193 0.8404722974595327
26 0.0481157266551073 0.0234653660959279 0.3910854759691266 0.8639376635554605
27 0.0507669365397241 0.0217469472868169 0.4418524125088507 0.8856846108422775
28 0.0530424639385140 0.0199338424103982 0.4948948764473646 0.9056184532526756
29 0.0548437924428562 0.0180394686983084 0.5497386688902208 0.9236579219509841
30 0.0560612703440465 0.0160807618253492 0.6057999392342673 0.9397386837763333
31 0.0565733013955950 0.0140785735987762 0.6623732406298624 0.9538172573751095
32 0.0562455071812177 0.0120580985489335 0.7186187478110800 0.9658753559240429
33 0.0549298610885233 0.0100493304353186 0.7735486088996034 0.9759246863593615
34 0.0524637938883948 0.0080875496821570 0.8260124027879983 0.9840122360415184
35 0.0486692709200651 0.0062138427575715 0.8746816737080633 0.9902260787990900
36 0.0433518408818878 0.0044756545104263 0.9180335145899510 0.9947017333095163
37 0.0362996562278024 0.0029273744789303 0.9543331708177534 0.9976291077884466
38 0.0272824651694943 0.0016309581850802 0.9816156359872477 0.9992600659735268
39 0.0160505752842493 0.0006565844290269 0.9976662112714969 0.9999166504025536
40 0.0023337887285027 0.0000833495974465 0.9999999999999997 1.0000000000000000
ndtfast, nfast = 28 40 nfast/ndtfast = 1.42857
1.000000000000 1.049755056052 0.524877528026 1.000000000000 1.000000000000
Power filter parameters, Fgamma, gamma = 0.28400 0.18257
Time Splitting Weights for Grid 02: ndtfast = 28 nfast = 40
Minimum X-grid spacing, DXmin = 1.68750522E+01 km
Maximum X-grid spacing, DXmax = 2.59079178E+01 km
Minimum Y-grid spacing, DYmin = 2.73970787E+01 km
Maximum Y-grid spacing, DYmax = 2.76447334E+01 km
Minimum Z-grid spacing, DZmin = 3.17174065E+00 m
Maximum Z-grid spacing, DZmax = 3.97397355E+01 m
Minimum barotropic Courant Number = 1.53115909E-03
Maximum barotropic Courant Number = 3.28374281E-03
Maximum Coriolis Courant Number = 3.01243415E-03
Metrics information for Grid 02:
Minimum X-grid spacing, DXmin = 5.66495225E+00 km
Maximum X-grid spacing, DXmax = 8.23383855E+00 km
Minimum Y-grid spacing, DYmin = 9.13697426E+00 km
Maximum Y-grid spacing, DYmax = 9.23740213E+00 km
Minimum Z-grid spacing, DZmin = 7.59811771E-01 m
Maximum Z-grid spacing, DZmax = 1.25488777E+01 m
Minimum barotropic Courant Number = 0.00000000E+00
Maximum barotropic Courant Number = 2.66841783E-03
Maximum Coriolis Courant Number = 1.44105731E-03
NETCDF_CHECK_VAR - inconsistent value of variable: hc 7.628548E+00 5.000000E+01
in file: Projects_My/Sandy/3D_BC/Sandy_ini.nc
Elapsed CPU time (seconds):
Node # 0 CPU: 0.094
Node # 3 CPU: 0.094
Node # 0 CPU: 0.094
Node # 2 CPU: 0.094
Node # 3 CPU: 0.094
Node # 2 CPU: 0.094
Node # 1 CPU: 0.094
Total: 0.375
Allocation and array initialization .............. 0.218 (58.1750 %)
Total: 0.218 58.1750
Message Passage: 2D halo exchanges ............... 0.009 ( 2.3570 %)
Message Passage: 3D halo exchanges ............... 0.002 ( 0.5827 %)
Message Passage: data broadcast .................. 0.034 ( 8.9458 %)
Message Passage: data reduction .................. 0.000 ( 0.0718 %)
Message Passage: data scattering.................. 0.019 ( 5.1511 %)
Message Passage: point data gathering ............ 0.001 ( 0.3625 %)
Total: 0.066 17.4709
All percentages are with respect to total time = 0.375
ROMS/TOMS - Output NetCDF summary for Grid 02:
ERROR: Illegal model configuration.
Problem of "Sandy of COAWST"
ocean_sandy.in
- (116.18 KiB) Downloaded 541 times
Re: Problem of "Sandy of COAWST"
I have check the 'hc' of 'Sandy_ini_nc' is 7.628548, but the variable 'hc' is not exist in grid file. Maybe it's not been creat in 'create_sandy_application.m'.
