Error when restart from 'ocean_his.nc' with WET_DRY
takashi
#1 Unread post by takashi »
Hello all,
When I tried to restart from 'ocean_his.nc' file with WET_DRY,
'wetdry_mask_psi' data was required with error message.
Maybe this request is related to recent modification of wetting & drying algorithm.
The 'wetdry_mask_psi' recording codes for 'ocean_rst.nc' has been already incorporated,
so to restart from 'ocean_rst.nc' has been no problem.
But the 'wetdry_mask_psi' recording codes for 'ocean_his.nc' has not been incorporated.
Thus, if we want to restart from 'ocean_his.nc' with WET_DRY,
we need to add the codes in def_his.F according to the manner of def_rst.F.
In my solution, firstly add the declaration statement to line 55 in def_his.F:
      integer :: p2dgrd(3)
Then insert the following codes to line 301:
!  Define dimension vectors for staggered type variables at PSI-points.
        p2dgrd(1)=DimIDs( 4)
        p2dgrd(2)=DimIDs( 8)
        p2dgrd(3)=DimIDs(12)
Then, insert the following codes to line 458 ( inside #ifdef WET_DRY ~ #endif statement):
!  Define wet/dry mask on PSI-points.
        Vinfo( 1)=Vname(1,idPwet)
        Vinfo( 2)=Vname(2,idPwet)
        Vinfo( 3)=Vname(3,idPwet)
        Vinfo( 9)='land'
        Vinfo(10)='water'
        Vinfo(14)=Vname(4,idPwet)
        Vinfo(16)=Vname(1,idtime)
        Vinfo(22)='coordinates'
        Aval(5)=REAL(Iinfo(1,idPwet,ng),r8)
        status=def_var(ng, iNLM, HIS(ng)%ncid, HIS(ng)%Vid(idPwet),     &
     &                 NF_FOUT, nvd3, p2dgrd, Aval, Vinfo, ncname,     &
     &                 SetFillVal = .FALSE.)
Similarly, insert the following codes to line 154 ( inside #ifdef WET_DRY ~ #endif statement) in wrt_his.F:
!  Write out wet/dry mask at PSI-points.
      scale=1.0_r8
      gtype=gfactor*p2dvar
      status=nf_fwrite2d(ng, iNLM, HIS(ng)%ncid, HIS(ng)%Vid(idPwet),   &
     &                   HIS(ng)%Rindex, gtype,                         &
     &                   LBi, UBi, LBj, UBj, scale,                     &
# ifdef MASKING
     &                   GRID(ng) % pmask,                              &
     &                   GRID(ng) % pmask_wet,                          &
      IF (status.ne.nf90_noerr) THEN
        IF (Master) THEN
          WRITE (stdout,10) TRIM(Vname(1,idPwet)), HIS(ng)%Rindex
        exit_flag=3
        ioerror=status
        RETURN
To restart from 'ocean_his.nc' has been success after these modifications.
Re: Error when restart from 'ocean_his.nc' with WET_DRY
also need to add in def_his.F
1) near lines 3572
[#if defined WET_DRY] (this ifdef is already there)
ELSE IF (TRIM(var_name(i)).eq.TRIM(Vname(1,idPwet))) THEN
got_var(idPwet)=.TRUE.
HIS(ng)%Vid(idPwet)=var_id(i)
2) near line 4184
IF (.not.got_var(idPwet)) THEN
IF (Master) WRITE (stdout,60) TRIM(Vname(1,idPwet)), &
& TRIM(ncname)
exit_flag=3
RETURN
