can not input the climatology Temp & Salinity
- Location: the state key lab of marine environment science, Xiamen,P.R.China
when I defined 'CLIMA_TS_MIX', and set the climatology file in the '*.in', it would pause after read the boundary file, and could not continue to read the climatology data. It is also found there is not 'idTclm' entrance in 'varinfo.dat'. Where shall I set the entrance for the T&S climatology data? Thanks for any help.
Re: can not input the climatology Temp & Salinity
The Vname entries for the climatology fields now happens in inp_par.F:
If the time variable is not say temp_time, you *have* to set the "time" attribute for your temperature climatology variable. If you don't, ROMS should fail with an error rather than hang, though. How big is your climatology file? Perhaps it's just slow to read it.
IF (ANY(LtracerCLM).or.ANY(LnudgeTCLM)) THEN
DO i=1,MT
varid=varid+1
IF (varid.gt.MV) THEN
WRITE (stdout,130) MV, varid
STOP
idTclm(i)=varid
DO ng=1,Ngrids
Fscale(varid,ng)=1.0_r8
Iinfo(1,varid,ng)=r3dvar
WRITE (Vname(1,varid),'(a)') &
& TRIM(ADJUSTL(Vname(1,idTvar(i))))
WRITE (Vname(2,varid),'(a,a)') &
& TRIM(ADJUSTL(Vname(2,idTvar(i)))), ' climatology'
WRITE (Vname(3,varid),'(a)') &
& TRIM(ADJUSTL(Vname(3,idTvar(i))))
WRITE (Vname(4,varid),'(a,a)') &
& TRIM(Vname(1,varid)), ', scalar, series'
WRITE (Vname(5,varid),'(a,a)') &
& TRIM(ADJUSTL(Vname(1,idTvar(i)))), '_time'
thanks Kate
the variable for climatology time is 'tclim_' so I modified the inp_par.F by adding two lines in the DO loop
if (Vname(5,varid).eq.'temp_time') Vname(5,varid)='tclm_time'
if (Vname(5,varid).eq.'salt_time') Vname(5,varid)='sclm_time'
it is ok now, the best way is modified the climatology file.
the previous error is listed in the qsub linpack file, and I missed it
