Bug in get_3dfldr.F
austinctodd
Bug in get_3dfldr.F
#1 Unread post by austinctodd »
I noticed through some extensive debugging that there is a sign error in get_3dfldr.F where it checks if data that has a cycle_length needs to be read. Lines 149-154 say the following:
        IF (Liocycle) THEN
          Trec=MOD(Trec,Nrec)-1
          IF (Trec.le.0) Trec=Nrec-Trec
        ELSE
          Trec=Trec-1
The issue seems to be
Trec=Nrec-Trec
which makes Trec greater than nrec instead of cycling the integer. It should actually be
Trec=Nrec+Trec
to be consistent with get_2dfldr.F
