malloc: *** error: pointer being freed was not allocated
bingzhang_chen
Location: Japan Agency for Marine-Earth Science & Tech.
#1 Unread post by bingzhang_chen »
Hi ROMS Users:
I am a new user of ROMS. I am trying to run the default upwelling test case, but now I got a problem:
Wednesday - March 18, 2015 - 1:41:58 PM
Wind-Driven Upwelling/Downwelling over a Periodic Channel
Operating system : Darwin
CPU/hardware : x86_64
Compiler system : ifort
Compiler command : /usr/bin/ifort
Compiler flags : -heap-arrays -fp-model source -openmp -fpp -ip -O3 -free -free -free
SVN Revision : 758
Local Root : /Users/apple/ROMS
Header Dir : /Users/apple/ROMSTEST/upwelling_bz
Header file : upwelling.h
Analytical Dir: /Users/apple/ROMSTEST/upwelling_bz
Resolution, Grid 01: 0041x0080x016, Parallel Threads: 12, Tiling: 003x004
288 ntimes Number of timesteps for 3-D equations.
300.000 dt Timestep size (s) for 3-D equations.
72 nRST Number of timesteps between the writing of data
into restart fields.
to standard output.
72 nHIS Number of timesteps between the writing fields
into history file.
time-averaged data.
72 nAVG Number of timesteps between the writing of
1 ntsDIA Starting timestep for the accumulation of output
72 nDIA Number of timesteps between the writing of
(m2/s) for tracer 01: temp
(m2/s) for tracer 02: salt
0.0000E+00 nl_visc2 NLM Horizontal, harmonic mixing coefficient
(m2/s) for momentum.
for tracer 02: salt
25.000 Tcline S-coordinate surface/bottom layer width (m) used
for tracer 02: salt
for 3D momentum.
of State.
T Aout(idDano) Write out averaged density anomaly.
T Dout(M2rate) Write out 2D momentum acceleration.
T Dout(M2pgrd) Write out 2D momentum pressure gradient.
T Dout(M2fcor) Write out 2D momentum Coriolis force.
T Dout(M2hadv) Write out 2D momentum horizontal advection.
T Dout(M2xadv) Write out 2D momentum horizontal X-advection.
T Dout(M2yadv) Write out 2D momentum horizontal Y-advection.
T Dout(M2hvis) Write out 2D momentum horizontal viscosity.
T Dout(M2xvis) Write out 2D momentum horizontal X-viscosity.
T Dout(M2yvis) Write out 2D momentum horizontal Y-viscosity.
T Dout(M2sstr) Write out 2D momentum surface stress.
T Dout(M2bstr) Write out 2D momentum bottom stress.
T Dout(M3rate) Write out 3D momentum acceleration.
T Dout(M3pgrd) Write out 3D momentum pressure gradient.
T Dout(M3fcor) Write out 3D momentum Coriolis force.
T Dout(M3hadv) Write out 3D momentum horizontal advection.
T Dout(M3xadv) Write out 3D momentum horizontal X-advection.
T Dout(M3yadv) Write out 3D momentum horizontal Y-advection.
T Dout(M3vadv) Write out 3D momentum vertical advection.
T Dout(M3hvis) Write out 3D momentum horizontal viscosity.
T Dout(M3xvis) Write out 3D momentum horizontal X-viscosity.
T Dout(M3yvis) Write out 3D momentum horizontal Y-viscosity.
T Dout(M3vvis) Write out 3D momentum vertical viscosity.
T Dout(iTrate) Write out rate of change of tracer 01: temp
T Dout(iTrate) Write out rate of change of tracer 02: salt
T Dout(iThadv) Write out horizontal advection, tracer 01: temp
T Dout(iThadv) Write out horizontal advection, tracer 02: salt
T Dout(iTxadv) Write out horizontal X-advection, tracer 01: temp
T Dout(iTxadv) Write out horizontal X-advection, tracer 02: salt
T Dout(iTyadv) Write out horizontal Y-advection, tracer 01: temp
T Dout(iTyadv) Write out horizontal Y-advection, tracer 02: salt
T Dout(iTvadv) Write out vertical advection, tracer 01: temp
T Dout(iTvadv) Write out vertical advection, tracer 02: salt
T Dout(iThdif) Write out horizontal diffusion, tracer 01: temp
T Dout(iThdif) Write out horizontal diffusion, tracer 02: salt
T Dout(iTxdif) Write out horizontal X-diffusion, tracer 01: temp
T Dout(iTxdif) Write out horizontal X-diffusion, tracer 02: salt
T Dout(iTydif) Write out horizontal Y-diffusion , tracer 01: temp
T Dout(iTydif) Write out horizontal Y-diffusion , tracer 02: salt
T Dout(iTvdif) Write out vertical diffusion, tracer 01: temp
T Dout(iTvdif) Write out vertical diffusion, tracer 02: salt
Output Diagnostics File: ocean_dia.nc
Tile partition information for Grid 01: 0041x0080x0016 tiling: 003x004
tile Istr Iend Jstr Jend Npts
0 1 14 1 20 4480
1 15 28 1 20 4480
2 29 41 1 20 4160
3 1 14 21 40 4480
4 15 28 21 40 4480
5 29 41 21 40 4160
6 1 14 41 60 4480
7 15 28 41 60 4480
8 29 41 41 60 4160
9 1 14 61 80 4480
10 15 28 61 80 4480
11 29 41 61 80 4160
(interior points only)
tile Xmin Xmax Ymin Ymax grid
0 -1.50 43.50 0.50 82.50 RHO-points
1 -2.50 43.50 0.50 82.50 RHO-points
2 -2.50 42.50 0.50 82.50 RHO-points
3 -1.50 43.50 -0.50 82.50 RHO-points
4 -2.50 43.50 -0.50 82.50 RHO-points
5 -2.50 42.50 -0.50 82.50 RHO-points
6 -1.50 43.50 -0.50 82.50 RHO-points
7 -2.50 43.50 -0.50 82.50 RHO-points
8 -2.50 42.50 -0.50 82.50 RHO-points
9 -1.50 43.50 -0.50 81.50 RHO-points
10 -2.50 43.50 -0.50 81.50 RHO-points
11 -2.50 42.50 -0.50 81.50 RHO-points
0 -2.00 43.50 0.50 82.50 U-points
1 -2.50 43.50 0.50 82.50 U-points
2 -2.50 42.00 0.50 82.50 U-points
3 -2.00 43.50 -0.50 82.50 U-points
4 -2.50 43.50 -0.50 82.50 U-points
5 -2.50 42.00 -0.50 82.50 U-points
6 -2.00 43.50 -0.50 82.50 U-points
7 -2.50 43.50 -0.50 82.50 U-points
8 -2.50 42.00 -0.50 82.50 U-points
9 -2.00 43.50 -0.50 81.50 U-points
10 -2.50 43.50 -0.50 81.50 U-points
11 -2.50 42.00 -0.50 81.50 U-points
0 -1.50 43.50 0.00 82.50 V-points
1 -2.50 43.50 0.00 82.50 V-points
2 -2.50 42.50 0.00 82.50 V-points
3 -1.50 43.50 -0.50 82.50 V-points
4 -2.50 43.50 -0.50 82.50 V-points
5 -2.50 42.50 -0.50 82.50 V-points
6 -1.50 43.50 -0.50 82.50 V-points
7 -2.50 43.50 -0.50 82.50 V-points
8 -2.50 42.50 -0.50 82.50 V-points
9 -1.50 43.50 -0.50 81.00 V-points
10 -2.50 43.50 -0.50 81.00 V-points
11 -2.50 42.50 -0.50 81.00 V-points
zeta 1 Periodic Closed Periodic Closed
ubar 1 Periodic Closed Periodic Closed
vbar 1 Periodic Closed Periodic Closed
u 1 Periodic Closed Periodic Closed
v 1 Periodic Closed Periodic Closed
temp 1 Periodic Closed Periodic Closed
salt 1 Periodic Closed Periodic Closed
UPWELLING Wind-Driven Upwelling/Downwelling over a Periodic Channel
ANA_GRID Analytical grid set-up.
ANA_VMIX Analytical vertical mixing coefficients.
NONLINEAR Nonlinear Model.
_OPENMP OpenMP parallel shared-memory directives.
SALINITY Using salinity.
UV_ADV Advection of momentum.
UV_COR Coriolis term.
Process Information:
Thread # 0 (pid= 6708) is active.
Thread # 11 (pid= 6708) is active.
Thread # 3 (pid= 6708) is active.
Thread # 10 (pid= 6708) is active.
Thread # 4 (pid= 6708) is active.
Thread # 6 (pid= 6708) is active.
Thread # 8 (pid= 6708) is active.
Thread # 5 (pid= 6708) is active.
Thread # 9 (pid= 6708) is active.
Thread # 2 (pid= 6708) is active.
Thread # 7 (pid= 6708) is active.
Thread # 1 (pid= 6708) is active.
oceanO(6708,0x10f67d000) malloc: *** error for object 0x7fc425b03420: pointer being freed was not allocated
*** set a breakpoint in malloc_error_break to debug
oceanO(6708,0x110e8f000) malloc: *** error for object 0x7fc425b03420: pointer being freed was not allocated
oceanO(6708,0x111292000) malloc: *** error for object 0x7fc425b03420: pointer being freed was not allocated
oceanO(6708,0x110286000) malloc: *** error for object 0x7fc425b03420: pointer being freed was not allocated
oceanO(6708,0x110a8c000) malloc: *** error for object 0x7fc425b03420: pointer being freed was not allocated
oceanO(6708,0x10fe83000) malloc: *** error for object 0x7fc425b03420: pointer being freed was not allocated
oceanO(6708,0x110689000) malloc: *** error for object 0x7fc425b03420: pointer being freed was not allocated
oceanO(6708,0x111e9b000) malloc: *** error for object 0x7fc425b03420: pointer being freed was not allocated
Abort trap: 6
I googled the error of "pointer being freed was not allocated", which seems be caused by a problem in in the C++ code. Since I only changed the upwelling.h file, is this a problem related to the head file?
Any advice would be appreciated!
Bingzhang
bingzhang_chen
Re: malloc: *** error: pointer being freed was not allocated
#2 Unread post by bingzhang_chen »
I find that it is related with the parallel computing. If I disable parallelism, the model runs normally. But I wonder why...
#3 Unread post by kate »
What exactly did you change? Just turning on the OpenMP option or anything else? I haven't run ROMS in OpenMP mode in many, many years, but I thought it should be working. If you want it to work, you have to be very careful in your ROMS modifications not to break it.
bingzhang_chen
#4 Unread post by bingzhang_chen »
Yes. I just turned on the openmp option. My platform is a Mac Pro with 6 physical CPUs, so I thought I should use the shared-memory parallelism... I may need to learn more about OPENMPI...
#5 Unread post by kate »
I know the OpenMPI works - but that's something else again entirely. Did you mean OpenMP or the OpenMPI implementation of MPI?
bingzhang_chen
#6 Unread post by bingzhang_chen »
Sorry, I meant the OpenMP implementation.
