I've found what appears to be a small bug in ad_v2dbc_im.F (svn revision 758). When using the ADM_DRIVER option and periodic boundary conditions I get segmentation fault. Changing
I found this problem too after extensive debugging. But the bug has not been fixed yet. Hope it can be fixed soon, so people like me won't speed too much time on debugging. Thanks a lot.
kaihc wrote:I've found what appears to be a small bug in ad_v2dbc_im.F (svn revision 758). When using the ADM_DRIVER option and periodic boundary conditions I get segmentation fault. Changing
I don't know what are you talking about. I checked the code and it already have that correction! I think that you need to update. As you see below, ad_v2dbc_im.F already have the change as shown on trac for Revision 767:
Thanks a lot for the update. My post (Jul. 9) is before the update (Jul.10). That's the reason. Thanks.
arango wrote:I don't know what are you talking about. I checked the code and it already have that correction! I think that you need to update. As you see below, ad_v2dbc_im.F already have the change as shown on trac for Revision 767:
