Hi Kate
I added a bottom stress option
but now its failed by
Wednesday - December 31, 2014 - 12:52:13 PM
ISLAND WAKE
Operating system : Linux
CPU/hardware : i686
Compiler system : gfortran
Compiler command : /usr/bin/gfortran
Compiler flags : -frepack-arrays -g -fbounds-check -ffree-form -ffree-line-length-none -ffree-form -ffree-line-length-none -ffree-form -ffree-line-length-none
SVN Revision : 700M
Local Root : /home/sima/Ocean
Header Dir : /home/sima/Ocean
Header file : island_wake.h
Analytical Dir: /home/sima/Ocean/ROMS/Functionals/
Resolution, Grid 01: 0300x0300x010, Parallel Threads: 1, Tiling: 001x002
60000 ntimes Number of timesteps for 3-D equations.
145.000 dt Timestep size (s) for 3-D equations.
40 ndtfast Number of timesteps for 2-D equations between
288 nRST Number of timesteps between the writing of data
into restart fields.
to standard output.
72 nHIS Number of timesteps between the writing fields
into history file.
0.0000E+00 nl_visc2 NLM Horizontal, harmonic mixing coefficient
(m2/s) for momentum.
for tracer 02: salt
25.000 Tcline S-coordinate surface/bottom layer width (m) used
for tracer 02: salt
for 3D momentum.
of State.
0.0000E+00 Scoef Saline contraction coefficient (1/PSU).
Tile partition information for Grid 01: 0300x0300x0010 tiling: 001x002
tile Istr Iend Jstr Jend Npts
0 1 300 1 150 450000
1 1 300 151 300 450000
(interior points only)
tile Xmin Xmax Ymin Ymax grid
0 0.50 301.50 0.50 302.50 RHO-points
1 0.50 301.50 -0.50 301.50 RHO-points
0 0.00 301.00 0.50 302.50 U-points
1 0.00 301.00 -0.50 301.50 U-points
0 0.50 301.50 0.00 302.50 V-points
1 0.50 301.50 -0.50 301.00 V-points
zeta 1 Clamped Closed Clamped Closed
ubar 1 Clamped Closed Clamped Closed
vbar 1 Clamped Closed Clamped Closed
u 1 Clamped Closed Clamped Closed
v 1 Clamped Closed Clamped Closed
temp 1 Clamped Closed Clamped Closed
salt 1 Clamped Closed Clamped Closed
ISLAND_WAKE ISLAND WAKE
ANA_GRID Analytical grid set-up.
NONLINEAR Nonlinear Model.
PRSGRD31 Standard density Jacobian formulation (Song, 1998).
RHO_SURF Include difference between rho0 and surface density.
TS_C4HADVECTION Fourth-order centered horizontal advection of tracers.
UV_ADV Advection of momentum.
UV_COR Coriolis term.
Process Information:
Thread # 0 (pid= 1790) is active.
10 0.0000000 0.0000000 -0.000 0.000 0.000 0.000
9 -0.1000000 -0.0050000 1.633 -1.313 -1.752 -2.400
8 -0.2000000 -0.0204535 3.197 -2.756 -3.806 -5.636
7 -0.3000000 -0.0477616 4.682 -4.347 -6.203 -9.821
6 -0.4000000 -0.0894007 6.071 -6.118 -9.015 -15.152
5 -0.5000000 -0.1491465 7.339 -8.114 -12.350 -21.932
4 -0.6000000 -0.2324164 8.451 -10.405 -16.366 -30.593
3 -0.7000000 -0.3467612 9.355 -13.085 -21.281 -41.741
2 -0.8000000 -0.5025493 9.983 -16.282 -27.395 -56.204
1 -0.9000000 -0.7139071 10.241 -20.174 -35.117 -75.113
0 -1.0000000 -1.0000000 10.000 -25.000 -45.000 -100.000
Time Splitting Weights for Grid 01: ndtfast = 40 nfast = 56
1-0.0006038999279304 0.0250000000000000-0.0006038999279304 0.0250000000000000
2-0.0011053727845635 0.0250150974981983-0.0017092727124939 0.0500150974981983
3-0.0015044206959555 0.0250427318178123-0.0032136934084494 0.0750578293160106
4-0.0018010519301026 0.0250803423352112-0.0050147453385520 0.1001381716512218
5-0.0019952879837948 0.0251253686334638-0.0070100333223467 0.1252635402846856
6-0.0020871735042116 0.0251752508330587-0.0090972068265583 0.1504387911177443
7-0.0020767890452586 0.0252274301706640-0.0111739958718169 0.1756662212884082
8-0.0019642666586465 0.0252793498967954-0.0131382625304634 0.2009455711852036
9-0.0017498083197106 0.0253284565632616-0.0148880708501740 0.2262740277484652
10-0.0014337071879729 0.0253722017712543-0.0163217780381469 0.2516462295197196
11-0.0010163717024450 0.0254080444509537-0.0173381497405919 0.2770542739706733
12-0.0004983525116731 0.0254334537435148-0.0178365022522649 0.3024877277141881
13 0.0001196277614762 0.0254459125563066-0.0177168744907887 0.3279336402704947
14 0.0008366419202876 0.0254429218622697-0.0168802325705011 0.3533765621327644
15 0.0016515227599278 0.0254220058142625-0.0152287098105733 0.3787985679470269
16 0.0025628247984349 0.0253807177452643-0.0126658850121384 0.4041792856922913
17 0.0035687831729657 0.0253166471253035-0.0090971018391727 0.4294959328175947
18 0.0046672697013015 0.0252274275459793-0.0044298321378712 0.4547233603635741
19 0.0058557461086128 0.0251107458034468 0.0014259139707416 0.4798341061670209
20 0.0071312144194823 0.0249643521507315 0.0085571283902239 0.5047984583177524
21 0.0084901645151857 0.0247860717902444 0.0170472929054096 0.5295845301079968
22 0.0099285188562319 0.0245738176773648 0.0269758117616416 0.5541583477853615
23 0.0114415743701613 0.0243256047059590 0.0384173861318029 0.5784839524913205
24 0.0130239415046020 0.0240395653467049 0.0514413276364049 0.6025235178380254
25 0.0146694804455856 0.0237139668090899 0.0661108080819904 0.6262374846471153
26 0.0163712345011199 0.0233472297979502 0.0824820425831104 0.6495847144450655
27 0.0181213606500220 0.0229379489354222 0.1006034032331323 0.6725226633804877
28 0.0199110572560077 0.0224849149191717 0.1205144604891400 0.6950075782996594
29 0.0217304889470413 0.0219871384877715 0.1422449494361814 0.7169947167874309
30 0.0235687086599425 0.0214438762640955 0.1658136580961238 0.7384385930515264
31 0.0254135768502523 0.0208546585475969 0.1912272349463761 0.7592932515991233
32 0.0272516778673573 0.0202193191263406 0.2184789128137333 0.7795125707254639
33 0.0290682334948725 0.0195380271796567 0.2475471463086058 0.7990505979051206
34 0.0308470136562825 0.0188113213422849 0.2783941599648883 0.8178619192474054
35 0.0325702442858409 0.0180401460008778 0.3109644042507291 0.8359020652482831
36 0.0342185123647286 0.0172258898937318 0.3451829166154578 0.8531279551420149
37 0.0357706681224704 0.0163704270846136 0.3809535847379282 0.8694983822266285
38 0.0372037244036097 0.0154761603815518 0.4181573091415379 0.8849745426081802
39 0.0384927531996420 0.0145460672714616 0.4566500623411799 0.8995206098796418
40 0.0396107793462069 0.0135837484414705 0.4962608416873868 0.9131043583211123
41 0.0405286713855386 0.0125934789578153 0.5367895130729254 0.9256978372789276
42 0.0412150295941741 0.0115802621731769 0.5780045426670996 0.9372780994521045
43 0.0416360711759210 0.0105498864333225 0.6196406138430206 0.9478279858854270
44 0.0417555126200830 0.0095089846539245 0.6613961264631036 0.9573369705393515
45 0.0415344492249439 0.0084650968384224 0.7029305756880475 0.9658020673777740
46 0.0409312317865102 0.0074267356077988 0.7438618074745578 0.9732288029855728
47 0.0399013404525124 0.0064034548131361 0.7837631479270702 0.9796322577987089
48 0.0383972557416642 0.0054059213018233 0.8221604036687344 0.9850381791005322
49 0.0363683267281804 0.0044459899082817 0.8585287303969148 0.9894841690088138
50 0.0337606363915535 0.0035367817400771 0.8922893667884684 0.9930209507488909
51 0.0305168641315885 0.0026927658302883 0.9228062309200569 0.9957137165791792
52 0.0265761454486959 0.0019298442269986 0.9493823763687528 0.9976435608061778
53 0.0218739287894439 0.0012654405907812 0.9712563051581966 0.9989090013969589
54 0.0163418295573680 0.0007185923710451 0.9875981347155646 0.9996275937680040
55 0.0099074812890402 0.0003100466321109 0.9975056160046047 0.9999376404001149
56 0.0024943839953957 0.0000623595998849 1.0000000000000004 0.9999999999999998
ndtfast, nfast = 40 56 nfast/ndtfast = 1.40000
1.000000000000 1.039265571007 0.519632785503 1.000000000000 1.000000000000
Power filter parameters, Fgamma, gamma = 0.28400 0.21300
Minimum X-grid spacing, DXmin = 1.00000000E+00 km
Maximum X-grid spacing, DXmax = 1.00000000E+00 km
Minimum Y-grid spacing, DYmin = 1.00000000E+00 km
Maximum Y-grid spacing, DYmax = 1.00000000E+00 km
Minimum Z-grid spacing, DZmin = -1.63333318E+00 m
Maximum Z-grid spacing, DZmax = 2.48874290E+01 m
Minimum barotropic Courant Number = 5.07758863E-02
Maximum barotropic Courant Number = 1.60567451E-01
Maximum Coriolis Courant Number = 4.36450000E-04
At line 74 of file get_data.f90
Fortran runtime error: Array referenc
I checked line 74 of get_data.f90 file,the following lines shows line 74 and its upper and downer lines.
! Read in forcing data from FORCING NetCDF file.
! Surface wind stress components.
CALL get_2dfld (ng, iNLM, idUsms, ncFRCid(idUsms,ng), &
line 74 & nFfiles(ng), FRC(1,ng), update(1), &
& LBi, UBi, LBj, UBj, 2, 1, &
& FORCES(ng) % sustrG)
CALL get_2dfld (ng, iNLM, idVsms, ncFRCid(idVsms,ng), &
& FORCES(ng) % svstrG)
I don't have any netcdf forcing file, even i commented the " NFFILES == 1" in the ocean.in file
thanks again for your help
Sima
