For seamount case, the model domain was set as a rectangular with incoming flow from the western boundary. The incoming flow decreases in vertical direction (z-axis) and it is that
u(z)=0.2+0.1tanh((z+hs)/hd)
its definition in ana_m2obc.h was given as below,
#if defined SEAMOUNT
IF (LBC(iwest,isUbar,ng)%acquire.and. &
& LBC(iwest,isVbar,ng)%acquire.and. &
& DOMAIN(ng)%Western_Edge(tile)) THEN
DO k=1,N(ng)
DO j=JstrT,JendT
BOUNDARY(ng)%ubar_west(j)=0.2_r8+0.1_r8*TANH((z_r(IstrT,j,k)+ &
& 2250.0_r8)/1500.0_r8)
DO j=JstrP,JendT
BOUNDARY(ng)%vbar_west(j)=0.0_r8
z_r was defined before, and it was that
#include "tile.h"
CALL ana_m2obc_tile (ng, tile, model,
GRID(ng) % z_r,
#ifdef ASSUMED_SHAPE
real(r8), intent(in) :: h(LBi:,LBj:,:)
#else
real(r8), intent(in) :: h(LBi:UBi,LBj:UBj,:)
! Local variable declarations.
integer :: i, j, k
And I also give its definition in ana_m3obc.h just like that,
IF (LBC(iwest,isUvel,ng)%acquire.and. &
& LBC(iwest,isVvel,ng)%acquire.and. &
DO k=1,N(ng)
DO j=JstrT,JendT
BOUNDARY(ng)%u_west(j, k)=0.2_r8+0.1_r8*TANH((z_r(IstrT,j,k)+ &
DO k=1,N(ng)
DO j=JstrP,JendT
BOUNDARY(ng)%v_west(j, k)=0.0_r8
And z_r was also defined before,
#include "tile.h"
CALL ana_m3obc_tile (ng, tile, model,
… GRID(ng) % z_r)
! Imported variable declarations.
real(r8), intent(in) :: z_r(LBi:,LBj:,:)
#else
real(r8), intent(in) :: z_r(LBi:UBi,LBj:UBj,:)
The oceanM can be generated after successful compilation and it was performed well. The initial flow field for the entire domain was set equal to the upstream boundary condition, that is u(z)=0.2+0.1tanh((z+hs)/hd). However, the obtained flow filed indicated that the flow could keep the vertical velocity changes even if the seamount was removed. I think the velocity definition was wrong. could someone give me some help, thank you in advance!
how to set velocity with vertical changes in ana_m2obc.h?
Re: how to set velocity with vertical changes in ana_m2obc.h
The way you set u at the boundary should work, but you can't set ubar that way. Because it doesn't depend on k, you will only have set it for k=N (the last of the k loop). ubar is the depth-integrated flow field - it just doesn't depend on k.
Now maintaining a vertical sheer is going to depend on many things, including the density structure and the boundary condition options you picked in LBC. What was your question about a seamount? You have a straight channel with a seamount in it?
Thank you for your advice, Kate. My case is a straight channel with a seamount in it. For LBC, I set the western incoming flow boundary as Cla boundary for U, V momentum in both 2D and 3D, while the eastern boundary condition was set as Rad boundary for both 2D and 3D. The density structure was set the similar changes vertically with the reverse changing trend, that’s to say, density increases vertically and velocity decreases with depth. However, I just still don’t understand how to set ubar. I made three trials. But they couldn’t work at all.kate wrote:The way you set u at the boundary should work, but you can't set ubar that way. Because it doesn't depend on k, you will only have set it for k=N (the last of the k loop). ubar is the depth-integrated flow field - it just doesn't depend on k.
1) I set Do k=N
Do j=JstrT, JendT
BOUNDARY(ng)%ubar_west(j)=0.2_r8+0.1_r8*TANH((z_r(IstrT,j,k)+2250.0_r8)/1500.0_r8)
2) I give z_r(IstrT,j,k) as a fixed value, -4500, that is the maximum depth, it was wrong.
And ubar is that:
BOUNDARY(ng)%ubar_west(j)=0.2_r8+0.1_r8*TANH((-4500.0_r8+2250.0_r8)/1500.0_r8)
3) I made the depth-integrated flow velocity of u(z)=0.2+0.1tanh((z+2250)/1500), for -4500<z<0. And the integral value u was obtained. then I set ubar as u/4500=0.2m/s and give the following flow boundary.
Do j=JstrT, JendT
BOUNDARY(ng)%ubar_west(j)=0.2_r8 …
I want to set the correct boundary condition, how can I realize it?
Your first one gives ubar as u at the surface (too strong) while the second one gives ubar as u at the bottom (too weak). What exactly do you get with all these? Do you get the ubar you ask for (but not what you expected)?
Anyway, a vertical shear with Coriolis forces balanced by a pressure gradient depends on a pressure gradient that is a function of depth. There exists some density structure that will be in balance with your velocity structure, but I'm not going to calculate it for you. It isn't level isopycnals.
Kate, Thank you for your help!
