after some seconds,the ROMS is broken.the problem is:
ubar 1 Flather Flather Flather Flather
vbar 1 Flather Flather Flather Flather
temp 1 Rad + Nud Rad + Nud Rad + Nud Rad + Nud
salt 1 Rad + Nud Rad + Nud Rad + Nud Rad + Nud
Maximum grid stiffness ratios: rx0 = 2.073358E-01 (Beckmann and Haidvogel)
rx1 = 5.496651E+00 (Haney)
Initial basin volumes: TotVolume = 7.4990725799E+15 m3
MinVolume = 1.3324713943E+08 m3
MaxVolume = 5.3901127752E+10 m3
Max/Min = 4.0451996181E+02
NL ROMS/TOMS: started time-stepping: (Grid: 01 TimeSteps: 00000001 - 00518400)
WRT_AVG - wrote averaged fields into time record = 0000004
GET_2DFLD - surface u-momentum stress, t = 165 00:00:00
(Rec=0000006, Index=1, File: scs_frc.nc)
(Min = -1.52879394E-05 Max = 6.40976909E-05)
GET_2DFLD - surface v-momentum stress, t = 165 00:00:00
(Min = -4.61810431E-06 Max = 5.52322843E-05)
GET_2DFLD - solar shortwave radiation flux, t = 165 00:00:00
(Min = 4.95683096E-05 Max = 6.59865548E-05)
GET_2DFLD - surface net heat flux, t = 165 00:00:00
(Min = -1.64383999E-06 Max = 3.50775806E-05)
GET_2DFLD - sea surface temperature climatology, t = 165 00:00:00
(Min = 2.42111849E+01 Max = 2.97641813E+01)
GET_2DFLD - surface net heat flux sensitivity to SST, t = 165 00:00:00
(Min = -1.19031127E-05 Max = -5.84449190E-06)
GET_2DFLD - surface net freswater flux, (E-P), t = 165 00:00:00
(Min = -1.02026145E-07 Max = 3.25167561E-08)
GET_2DFLD - sea surface salinity climatology, t = 165 00:00:00
(Min = 3.11149006E+01 Max = 3.46239759E+01)
GET_NGFLD - free-surface western boundary condition, t = 165 00:00:00
(Rec=0000006, Index=2, File: scs_bry_Y2001M1.nc)
(Min = 5.60409472E-01 Max = 6.39023517E-01)
GET_NGFLD - free-surface eastern boundary condition, t = 165 00:00:00
(Min = 5.88852402E-01 Max = 1.04070739E+00)
GET_NGFLD - free-surface southern boundary condition, t = 165 00:00:00
(Min = 5.88852402E-01 Max = 6.77450558E-01)
GET_NGFLD - free-surface northern boundary condition, t = 165 00:00:00
(Min = 2.50057099E-01 Max = 6.32251028E-01)
GET_NGFLD - 2D u-momentum western boundary condition, t = 165 00:00:00
(Min = -4.90975438E-02 Max = 1.05009940E-01)
GET_NGFLD - 2D v-momentum western boundary condition, t = 165 00:00:00
(Min = -1.01857701E-01 Max = 7.76587735E-02)
GET_NGFLD - 2D u-momentum eastern boundary condition, t = 165 00:00:00
(Min = -2.90631022E-01 Max = 1.05943795E-01)
GET_NGFLD - 2D v-momentum eastern boundary condition, t = 165 00:00:00
(Min = -7.84070213E-02 Max = 7.51479399E-02)
GET_NGFLD - 2D u-momentum southern boundary condition, t = 165 00:00:00
(Min = -9.49848125E-02 Max = 2.23045097E-02)
GET_NGFLD - 2D v-momentum southern boundary condition, t = 165 00:00:00
(Min = -4.46944747E-02 Max = 9.61045627E-02)
GET_NGFLD - 2D u-momentum northern boundary condition, t = 165 00:00:00
(Min = -5.24680274E-02 Max = 9.89935547E-02)
GET_NGFLD - 2D v-momentum northern boundary condition, t = 165 00:00:00
(Min = 2.81153644E-03 Max = 1.36988327E-01)
GET_NGFLD - 3D u-momentum western boundary condition, t = 165 00:00:00
(Min = -8.38915360E-02 Max = 1.98316200E-01)
GET_NGFLD - 3D v-momentum western boundary condition, t = 165 00:00:00
(Min = -1.86986273E-01 Max = 1.42603979E-01)
GET_NGFLD - 3D u-momentum eastern boundary condition, t = 165 00:00:00
(Min = -8.34006718E-01 Max = 4.99532897E-01)
GET_NGFLD - 3D v-momentum eastern boundary condition, t = 165 00:00:00
(Min = -3.91903841E-01 Max = 3.54905029E-01)
GET_NGFLD - 3D u-momentum southern boundary condition, t = 165 00:00:00
(Min = -1.74823680E-01 Max = 8.80813603E-02)
GET_NGFLD - 3D v-momentum southern boundary condition, t = 165 00:00:00
(Min = -3.26053837E-01 Max = 2.74518056E-01)
GET_NGFLD - 3D u-momentum northern boundary condition, t = 165 00:00:00
(Min = -8.21044156E-02 Max = 2.58711342E-01)
GET_NGFLD - 3D v-momentum northern boundary condition, t = 165 00:00:00
(Min = -4.70567820E-02 Max = 2.17430385E-01)
GET_NGFLD - temperature western boundary condition, t = 165 00:00:00
(Min = 2.64734438E+01 Max = 3.04281569E+01)
GET_NGFLD - salinity western boundary condition, t = 165 00:00:00
(Min = 3.16394171E+01 Max = 3.36542383E+01)
GET_NGFLD - temperature eastern boundary condition, t = 165 00:00:00
(Min = 1.19861020E+00 Max = 2.97552779E+01)
GET_NGFLD - salinity eastern boundary condition, t = 165 00:00:00
(Min = 3.36431738E+01 Max = 3.48619570E+01)
GET_NGFLD - temperature southern boundary condition, t = 165 00:00:00
(Min = 2.86765619E+00 Max = 3.04214697E+01)
GET_NGFLD - salinity southern boundary condition, t = 165 00:00:00
(Min = 3.21528550E+01 Max = 3.47526188E+01)
GET_NGFLD - temperature northern boundary condition, t = 165 00:00:00
(Min = 6.81671213E+00 Max = 2.71948512E+01)
GET_NGFLD - salinity northern boundary condition, t = 165 00:00:00
(Min = 3.21829639E+01 Max = 3.47287497E+01)
WRT_AVG - wrote averaged fields into time record = 0000005
GET_2DFLD - surface u-momentum stress, t = 195 00:00:00
(Rec=0000007, Index=2, File: scs_frc.nc)
(Min = -1.05936577E-05 Max = 7.39921924E-05)
GET_2DFLD - surface v-momentum stress, t = 195 00:00:00
(Min = 6.88273658E-06 Max = 5.83811057E-05)
GET_2DFLD - solar shortwave radiation flux, t = 195 00:00:00
(Min = 4.99713362E-05 Max = 7.10750755E-05)
GET_2DFLD - surface net heat flux, t = 195 00:00:00
(Min = -3.80987919E-06 Max = 4.56062488E-05)
GET_2DFLD - sea surface temperature climatology, t = 195 00:00:00
(Min = 2.66514053E+01 Max = 2.96063976E+01)
GET_2DFLD - surface net heat flux sensitivity to SST, t = 195 00:00:00
(Min = -1.22702114E-05 Max = -5.99364157E-06)
GET_2DFLD - surface net freswater flux, (E-P), t = 195 00:00:00
(Min = -1.26891164E-07 Max = 4.74972469E-08)
GET_2DFLD - sea surface salinity climatology, t = 195 00:00:00
(Min = 3.15641003E+01 Max = 3.45120414E+01)
GET_NGFLD - free-surface western boundary condition, t = 195 00:00:00
(Rec=0000007, Index=1, File: scs_bry_Y2001M1.nc)
(Min = 5.41284062E-01 Max = 6.26281486E-01)
GET_NGFLD - free-surface eastern boundary condition, t = 195 00:00:00
(Min = 5.85367811E-01 Max = 1.08700983E+00)
GET_NGFLD - free-surface southern boundary condition, t = 195 00:00:00
(Min = 5.85367811E-01 Max = 6.75306109E-01)
GET_NGFLD - free-surface northern boundary condition, t = 195 00:00:00
(Min = 1.93854451E-01 Max = 6.64718183E-01)
GET_NGFLD - 2D u-momentum western boundary condition, t = 195 00:00:00
(Min = -5.21068446E-02 Max = 1.20445283E-01)
GET_NGFLD - 2D v-momentum western boundary condition, t = 195 00:00:00
(Min = -1.15020468E-01 Max = 1.00295033E-01)
GET_NGFLD - 2D u-momentum eastern boundary condition, t = 195 00:00:00
(Min = -2.62560567E-01 Max = 1.10089264E-01)
GET_NGFLD - 2D v-momentum eastern boundary condition, t = 195 00:00:00
(Min = -7.81628386E-02 Max = 7.95966388E-02)
GET_NGFLD - 2D u-momentum southern boundary condition, t = 195 00:00:00
(Min = -1.23535612E-01 Max = 2.18107207E-02)
GET_NGFLD - 2D v-momentum southern boundary condition, t = 195 00:00:00
(Min = -5.50588877E-02 Max = 1.13645397E-01)
GET_NGFLD - 2D u-momentum northern boundary condition, t = 195 00:00:00
(Min = -6.20944778E-02 Max = 8.88765042E-02)
GET_NGFLD - 2D v-momentum northern boundary condition, t = 195 00:00:00
(Min = 6.01659993E-03 Max = 1.88722315E-01)
GET_NGFLD - 3D u-momentum western boundary condition, t = 195 00:00:00
(Min = -8.98586236E-02 Max = 2.28061184E-01)
GET_NGFLD - 3D v-momentum western boundary condition, t = 195 00:00:00
(Min = -2.12672031E-01 Max = 1.76295640E-01)
GET_NGFLD - 3D u-momentum eastern boundary condition, t = 195 00:00:00
(Min = -7.58688083E-01 Max = 5.41575720E-01)
GET_NGFLD - 3D v-momentum eastern boundary condition, t = 195 00:00:00
(Min = -3.89539775E-01 Max = 3.81860148E-01)
GET_NGFLD - 3D u-momentum southern boundary condition, t = 195 00:00:00
(Min = -2.26398974E-01 Max = 6.73357726E-02)
GET_NGFLD - 3D v-momentum southern boundary condition, t = 195 00:00:00
(Min = -3.24876498E-01 Max = 3.03098959E-01)
GET_NGFLD - 3D u-momentum northern boundary condition, t = 195 00:00:00
(Min = -9.38644844E-02 Max = 2.60052975E-01)
GET_NGFLD - 3D v-momentum northern boundary condition, t = 195 00:00:00
(Min = -4.93375862E-02 Max = 2.31014726E-01)
GET_NGFLD - temperature western boundary condition, t = 195 00:00:00
(Min = 2.58768280E+01 Max = 3.00370776E+01)
GET_NGFLD - salinity western boundary condition, t = 195 00:00:00
(Min = 3.17351468E+01 Max = 3.38036455E+01)
GET_NGFLD - temperature eastern boundary condition, t = 195 00:00:00
(Min = 1.19836398E+00 Max = 2.97644582E+01)
GET_NGFLD - salinity eastern boundary condition, t = 195 00:00:00
(Min = 3.36719047E+01 Max = 3.48471544E+01)
GET_NGFLD - temperature southern boundary condition, t = 195 00:00:00
(Min = 2.86867930E+00 Max = 3.00368819E+01)
GET_NGFLD - salinity southern boundary condition, t = 195 00:00:00
(Min = 3.23155646E+01 Max = 3.47614262E+01)
GET_NGFLD - temperature northern boundary condition, t = 195 00:00:00
(Min = 6.76454056E+00 Max = 2.86756648E+01)
GET_NGFLD - salinity northern boundary condition, t = 195 00:00:00
(Min = 3.34817645E+01 Max = 3.47158838E+01)
WRT_AVG - error while writing variable: zeta
into averages NetCDF file for time record: 6
can everyone help me to solve the problem?
thanks in advance!
Run problem!
Re: Run problem!
Did you just update to a new version of ROMS? If that's the situation, you can read this thread[viewtopic.php?f=14&t=2511]. This happened to me before, but my simulation broken at the very beginning. So before updating your compiler, you can turn off the average output of ubar, vbar and zeta to make sure that is the problem.
Qianqian
Qianqian
Qianqian@URI
Re: Run problem!
Thanks!justina0622 wrote:Did you just update to a new version of ROMS? If that's the situation, you can read this thread[viewtopic.php?f=14&t=2511]. This happened to me before, but my simulation broken at the very beginning. So before updating your compiler, you can turn off the average output of ubar, vbar and zeta to make sure that is the problem.
Qianqian
I will have a try!
