I have a problem with the time step in my forcing files. I force my model with hourly wind stress data (amongst other parameters, but wind is the one I am having troubles with). I save the hourly output into a his file. Generally, this should look like this - it writes the history fields and then reads the wind data.
37980 17 14:00:00 1.131793E-02 9.759933E+03 9.759945E+03 7.130870E+14
(658,089,02) 6.483382E-03 6.013216E-02 8.986419E-02 1.737858E+00
WRT_HIS - wrote history fields (Index=1,1) into time record = 0000062
GET_2DFLD - surface u-momentum stress, t = 17 15:00:00
(Rec=0000051, Index=2, File: wind_660_hourly_2.nc)
(Tmin= 15.5417 Tmax= 31.0000)
(Min = -6.20686378E-05 Max = 2.05079991E-05)
GET_2DFLD - surface v-momentum stress, t = 17 15:00:00
(Min = 3.52449282E-06 Max = 1.80098321E-04)
37981 17 14:00:40 1.131755E-02 9.759932E+03 9.759943E+03 7.130868E+14
(658,089,02) 6.493260E-03 6.013627E-02 8.986523E-02 1.738505E+00
38159 17 15:59:20 1.121282E-02 9.759445E+03 9.759456E+03 7.130385E+14
(658,089,02) 7.599435E-03 5.546764E-02 7.901981E-02 1.818735E+00
GET_2DFLD - surface u-momentum stress, t = 17 17:00:00
(Rec=0000053, Index=2, File: wind_660_hourly_2.nc)
(Min = -5.52865726E-05 Max = 3.50237938E-05)
GET_2DFLD - surface v-momentum stress, t = 17 17:00:00
(Min = 9.49741635E-07 Max = 1.56484781E-04)
38160 17 16:00:00 1.121220E-02 9.759441E+03 9.759452E+03 7.130381E+14
(658,089,02) 7.605224E-03 5.541070E-02 7.889061E-02 1.819470E+00
WRT_HIS - wrote history fields (Index=1,1) into time record = 0000064
38161 17 16:00:40 1.121159E-02 9.759437E+03 9.759449E+03 7.130377E+14
(658,089,02) 7.610932E-03 5.535294E-02 7.875988E-02 1.820202E+00
I force the model with multiple wind files, the first one ends at 15.5 days and the second one starts at 15.5 days and 1 hour, the switch between writing and reading happens after 17 days and 15 hours. I also noticed that before the switch occurs, some time steps read 1 second less than what it should be
38070 17 15:00:00 1.127038E-02 9.759732E+03 9.759743E+03 7.130677E+14
(658,089,02) 7.065296E-03 5.917806E-02 8.663790E-02 1.771234E+00
WRT_HIS - wrote history fields (Index=1,1) into time record = 0000063
GET_2DFLD - surface u-momentum stress, t = 17 15:59:59
(Rec=0000052, Index=1, File: wind_660_hourly_2.nc)
(Min = -6.01463465E-05 Max = 2.65203679E-05)
GET_2DFLD - surface v-momentum stress, t = 17 15:59:59
(Min = 2.61984313E-06 Max = 1.63034716E-04)
GET_2DFLD - surface air pressure, t = 17 18:00:00
(Rec=0000143, Index=1, File: slp_660_1.nc)
(Tmin= 0.0000 Tmax= 120.0000)
(Min = 1.01034822E+03 Max = 1.02795589E+03)
38071 17 15:00:40 1.126974E-02 9.759729E+03 9.759741E+03 7.130675E+14
(658,089,02) 7.074547E-03 5.915217E-02 8.658294E-02 1.771600E+00
First I assumed it was a rounding error somewhere in the code so I changed sms_time from days to seconds. It didn't help. In both runs the change between reading and writing occurs at the same time. When I use 3-hourly wind fields this problem does not occur.
Here is the ncdump of my wind file
nc{'sms_time'} = ncdouble('sms_time'); %% 372 elements.
nc{'sms_time'}.units = ncchar(''seconds since 2011-01-01 00:00:00'');
nc{'sms_time'}.cycle_length = ncdouble(1);
nc{'sms_time'}.long_name = ncchar(''surface momentum stress time'');
nc{'sms_time'}.field = ncchar(''time, scaler, series'');
nc{'sustr'} = ncdouble('sms_time', 'eta_u', 'xi_u'); %% 161797680 elements.
nc{'sustr'}.long_name = ncchar(''surface u-momentum stress'');
nc{'sustr'}.units = ncchar(''Newton meter-2'');
nc{'sustr'}.field = ncchar(''time, scaler, series'');
nc{'svstr'} = ncdouble('sms_time', 'eta_v', 'xi_v'); %% 161797680 elements.
nc{'svstr'}.long_name = ncchar(''surface v-momentum stress'');
nc{'svstr'}.units = ncchar(''Newton meter-2'');
nc{'svstr'}.field = ncchar(''time, scaler, series'');
66869 30 22:59:20 1.250382E-02 9.758100E+03 9.758113E+03 7.129026E+14
(303,131,27) 3.552772E-02 4.469029E-02 4.346825E-03 1.761728E+00
GET_2DFLD - surface u-momentum stress, t = 31 00:00:00
(Rec=0000372, Index=1, File: wind_660_hourly_2.nc)
(Min = -1.28229279E-04 Max = 1.00735645E-07)
GET_2DFLD - surface v-momentum stress, t = 31 00:00:00
(Min = 1.57125796E-08 Max = 1.50005876E-04)
66870 30 23:00:00 1.250372E-02 9.758101E+03 9.758113E+03 7.129026E+14
(303,131,27) 3.555137E-02 4.467106E-02 4.347965E-03 1.761094E+00
WRT_HIS - wrote history fields (Index=1,1) into time record = 0000023
66871 30 23:00:40 1.250363E-02 9.758101E+03 9.758114E+03 7.129027E+14
(303,131,27) 3.557501E-02 4.465168E-02 4.348950E-03 1.760443E+00
66959 30 23:59:20 1.249512E-02 9.758175E+03 9.758188E+03 7.129111E+14
(654,101,14) 1.133461E-02 7.481265E-03 6.876530E-02 1.653952E+00
GET_2DFLD - surface u-momentum stress, t = 15 13:00:00
(Rec=0000001, Index=2, File: wind_660_hourly_2.nc)
(Min = -1.37587066E-04 Max = 3.19810309E-06)
GET_2DFLD - surface v-momentum stress, t = 15 13:00:00
(Min = 6.50465756E-07 Max = 2.35191210E-04)
SET_2DFLD - current model time exceeds ending value for variable: sustr
TDAYS = 31.0000
Data Tmin = 15.5417 Data Tmax = 31.0000
Data Tstr = 15.5000 Data Tend = 15.5417
TINTRP1 = 31.0000 TINTRP2 = 16.5417
FAC1 = -14.4583 FAC2 = 0.0000
Elapsed CPU time (seconds):
Node # 0 CPU: 240636.915
number of time records written in HISTORY file = 00000023
number of time records written in RESTART file = 00000002
number of time records written in AVERAGE file = 00000030
Analytical header files used:
Node # 1 CPU: 242843.089
Node # 11 CPU: 243082.092
Node # 20 CPU: 243248.110
Node # 21 CPU: 243311.202
Node # 12 CPU: 243087.696
Node # 3 CPU: 242938.395
Node # 4 CPU: 242823.280
Node # 5 CPU: 243146.420
Node # 6 CPU: 243165.121
Node # 7 CPU: 242816.411
Node # 16 CPU: 243138.767
Node # 18 CPU: 243328.923
Node # 22 CPU: 243183.510
Node # 10 CPU: 243001.091
Node # 23 CPU: 243193.583
Node # 15 CPU: 243058.018
Node # 17 CPU: 243341.240
Node # 19 CPU: 243368.746
Node # 8 CPU: 242778.929
Node # 9 CPU: 242838.724
Node # 14 CPU: 243012.967
Node # 2 CPU: 242821.871
Node # 13 CPU: 242905.345
ROMS/Functionals/ana_btflux.h
/home/mwandres/ROMS/Projects/sixsixty/ROMS/Run_07/ana_nudgcoef.h
REASON: No error
