problems of building with pgi
i have build upwelling with gfortran correctly, but when i build it with pgi, there are erros,i have past the build.bash and build.log, can someone help me, thanks a lot
build.log
- build.log
- (754.99 KiB) Downloaded 419 times
build.bash
- build.bash
- (16.92 KiB) Downloaded 421 times
Re: problems of building with pgi
This is the source of your troubles:
You need to be able to clean out the gfortran files before starting a fresh build with pgi. Can you try these?
rm -f -r core *.ipo /home/limaolin/model/roms/projects/upwelling/Build /home/limaolin/make_macros.mk
rm: cannot remove `/home/limaolin/model/roms/projects/upwelling/Build/nf_fread3d_mod.mod': Permission denied
rm: cannot remove `/home/limaolin/model/roms/projects/upwelling/Build/def_diags.f90': Permission denied
rm: cannot remove `/home/limaolin/model/roms/projects/upwelling/Build/step2d.f90': Permission denied
ls -ld /home/limaolin/model/roms/projects/upwelling/Build
rm -rf /home/limaolin/model/roms/projects/upwelling/Build
thanks for your reply.
i found that i have build netcdf by gfortran and pgi twice. one installed in /usr/local, another in /usr/local/netcdf. i delate one, and installed again. after that, compiled by gfortran was right, i will compiled by pgi later.
